tbirkey214
- Joined
- Mar 24, 2025
- Messages
- 188
So I got this cast iron base that had some weird diamond plate brace to it and a bench grinder on it. I checked the bench grinder cuz it was garbage and I'm trying to use this for my big vise. I bought some 4x8 plate off of some dude way out in the country and I'm pretty sure that this is AR plate because it's impossible to drill into so now I got all this time into this cast iron base in this AR top plate and I'm trying to make this work. I bought some super missile weld rods which are part nickel and used for cast iron, and I clean this thing up real good and got my rose bud out of my torch and heated it up for like 20 minutes and I could just kind of barely get it to go back and forth from glowing red and I figured I'd be good enough so I use the super missile rod and it was very nasty but I've let this thing cool for about 3 hours I called it down with the torch until it was just kind of hot and I saw the plate was bent so I hit it with a hammer and it broke right through the weld.
Was I supposed to let this thing cool overnight, is because I hit it with the hammer, or maybe I didn't get this thing hot enough. I laid on that torch for a while until it seemed like it wasn't going to get any hotter, but I tried to braise it with some lfb rod and I just could never get it hot enough to melt into the joints so I'm curious which part went wrong? I can't imagine I was supposed to let this thing cool till morning, am I right in assuming that's too long to let cast iron cool to make it crack like that?
Single let me add pictures, but it busted right through the center of the weld
