WoodsTruck
- Joined
- Jan 12, 2013
- Messages
- 1,032
Does your model of Wheel Horse have a rear PTO?
Nice tractor!
What is the story on this? I don’t recall you working on it before.
Paint job looks good.
You don't carry a spare tire in your truck? Or is it tucked in the bed?
Ran into the same thing with Patch, the Wonder Yota. Larger OD tire didn't fit under the bed. Hated having it laying down flat in the bed because no matter where it was, it was in the way of something. So I built a mount for the spare that stood it up in the LR corner of the bed. I called it the "Pro-Farm" spare tire mount.
Mike, those UV covers are interesting, how much do they really help the life of the tires? I’ve never used them but I do try to park my trailer tires on pieces of leftover Trex decking. I was talking with a tire rep and he told me that tires parked long term on dirt or concrete can suffer from the oils in the rubber being sucked out. You ever heard that before?
I've attempted to keep the spare tire on my utility trailer covered, however the neighbor's horse would pull the cover off and chew them up out of boredom.
The spare recently had a spectacular failure, complete blowout of tread and belts. Never touched the road or had any dry rot or cracks, just cheap junk.
9 years!! The HORROR!!9+ years out of my last set and they showed absolutely no signs of sidewall cracking.
Repeat a fallacy often enough and it becomes the 'truth' no matter what the real experts have to say.
RV folks are nuts for the 5 year or whatever "rule" they've been told by the internet.... I'm a firm believer that if you keep your coach tires properly inflated and stored properly they can last. Well, that, and a quality tire to begin with.
Repeat a fallacy often enough and it becomes the 'truth' no matter what the real experts have to say. Applies to politicians too.
Old friend of mine used to cut two pieces of plywood the *just* fit up inside the fender wells of his trailers. This was decades before such tire covers were available.
My pickup has a set of Cooper tires on it. 10 years old and about 15K total miles. Traction *****, they are riding super hard and create some noises I thought were differential bearings failing. My tire guy said the Coopers crack in the face of the tire between the lugs and not necessarily on the sidewall where you would typically look for issues.
Snow tires will be going on in the next month and new summer tires will be purchased when those come off next spring.
I don’t miss the 16.5”, I had a hard time finding them at the end of the 90’s!
Does anyone remember when most (if not all) 3/4 ton and up pickups all came with split ring wheels and tube type tires?I don't miss the 16.5's either, nor that split ring.![]()
The first tubeless 8 lug wheels I remember seeing from the factory were on a ‘75 GMC 3/4 ton.
I worked in a gas station/garage from ‘71 thru ‘75. I wonder how many 100s of split rings I did from the 16.5 size all the way thru school bus and gravel train tires. Never had a problem
Can you imagine today’s 16 year olds changing truck tires?
Farm kids maybe, but certainly not the vast majority.
“I was about 12 years old”
You’ve got me, I was 15 when I started doing split rings.
I was so fortunate to have been taught by the station owner’s Dad that was about 70 years old.
He told me he was going to teach me the smart way because both he and I didn't have “enough ***” to try and muscle those tires.
No safety cage.
We put the assembled rim and tire under one of the hoist arms, used a locking air chuck and an air pressure regulator on the air line to inflate the tire.
I was pretty scared at first and was always respectful even after I got more confident.
I was working almost full time at the local Texaco as a nozzle jockey when I was 16. After a couple of months I was doing oil changes, tire rotations, mounting new tires and fixing flats. Glued in a lot of patches, sidewall bootsCan you imagine today’s 16 year olds changing truck tires?
Saw a big split rim come apart in the bay at the old Texaco station. The mechanic had it stuck under the arms of the in floor single post lift and when the split rim blew the hoist flew all the way up against the stop! I’ve also seen many a safety cage with a large bulge too. And it’s not just split rims that can kill ya, had a customer filling a patched tire on his tire machine that blew the sidewall out. He was leaning over it when it blew, the rim pretty much scalped him from his eyebrows up!
Nope, he got lucky, but he wasn’t the same, goofier than before!Scalped as in fatality ??
Where did you source your trailer tire protectors?
