SilverJimmy
Mike, how critical do you think having brakes on both axles is? I’ve only had brakes on one axle with all the trailers I’ve had, what am I missing?
I know some folks thinks that building a trailer is no big deal, but it's time consuming and I'm sure you have other things you would rather spend your time doing.
Agreed, a Mike built trailer would be badass.Very true, but I'm sure I'm not the only one that would have loved to follow a trailer build thread by Mike.
I'm sure his new trailer is nice, but I'm positive that a 100% Mike-built one would be superior.![]()
Great find on the trailer, Mike! Although, like others, I was looking forward to you documenting your own build!!!
It’s somewhat similar to mine, a 2011 JimGlo tilt bed trailer, although yours has a greater capacity. I have had all of the Corvettes other than the 2023 on this at one time or another, including bringing the ‘69 home from Nashville, the ‘13 home from the dealer in Tulsa and the ‘19 ZR1 home from the Houston dealership (in honesty, I did have to build the approach angle up a little for this one). If you’re only half as happy with yours as I have been with this one, you'll have made a great purchase!!!
Do the fenders unclip then lift straight up and off?
That's a really nice trailer!
Congrats on finding one for sale that was so close to your wish list.
Trailer looks great, Mike. But we were ALL looking forward to your building g one. What are you going to do with all that steel you bought?
I feel as if Mike just disappointed a few people including myself by not building a trailer.
Congrats on the new trailer !!
Mike, trailer looks great nice find! I too will miss the build thread.
Mike, I will also agree with the others that I'm slightly sad to hear you will not be building a trailer. However, I have pulled one of those before but it was the 14k variety, 102 Ironworks does a really good job with theirs and I was impressed with it. The only fault I had was that it was not mine.
JB
Glad you found a trailer that was close to what you were looking for! I know some folks thinks that building a trailer is no big deal, but it's time consuming and I'm sure you have other things you would rather spend your time doing.
Beautiful trailer Mike, Congrats on the nice find.
It’s just as I get older, I’m getting to the point of is it really necessary to build that or just buy one already built? Projects come and go, but Saturday morning breakfast with grandson are limited.
I've seen some towing operations that didn't have the hitch at proper height and hence weight was not distributed well across both axles. I would think in those cases that having brakes on both axles would be leaving flat spots on one set of tires, but likely they only had one set of brakes... If they worked at all.
Mike, beautiful trailer. wish mine had that deck on it, I've got boards to replace SOON. I just know you'll be adding more anchor points.![]()
One of these days if the opportunity presents itself Mike I’d luv a picture of how they set up the springs. My 20ft open trailer is rated at 10k and rides like a brick unloaded but loaded like a dream. One of these days I’ll tear into it and figure out a solution. It’s got to be more than just a spring issue…I think.
Mike, have you considered a bulkhead on the front of the trailer? Reason I ask is, I hauled a car on my flatbed trailer after they sanded the roads, and the hood had a bunch of chips from rocks being thrown off the tires. I always thought a bulkhead would have solved that and wished I would have had one. You could make it removable? Just spitballin!
Any evidence that a braked rear axle under a tandem axle trailer will tend to be the first to lock up in a panic stop? I know on my grandparent's GMC Coach that was the case, but that's a radically different suspension design.
Like this?Thom, I can irrefutably say with a high level of confidence that under a tandem axle trailer, the "braked" axle will lock up well before an idle axle in a panic stop situation.![]()
As for whether it will lock up before the tow rig, I would say there are too many variables to say one way or the other. Much would depend on how the trailer was loaded, how the brakes were adjusted, how the trailer brake controller was adjusted and how the tow rig was loaded. As a standard rule of thumb, the front brakes do the majority of the braking on vehicles, but I have seen very poorly loaded trailers cause the front end to be so light that they lock up first because in an emergency braking situation, the trailer weight is pushing down on the hitch, therefore decreasing weight on the steer axle. I'm sure I am not the only one who has seen so many scenarios that make you scratch you head pertaining to what people are thinking. Between the races, snowmobiling and duning for several decades, I thought I had seen it all, but occasionally I see a new one.![]()
Another scenario to noodle on:
Trailer comes loose from the hitch and pops the breakaway system. Now the trailer is ideally locking up those tires with brakes to slow/stop the incoming accident. Would 2 wheels or 4 wheels be better?
I have felt that 4 brakes are a bit more forgiving than just 2 where they will lock up less on loose surfaces creating a more uniform braking experience. I can say that since I had the brake wires snag on one axle pulling the joint loose leaving me with only brakes on 1 axle.
Wish I could comment, I’ve only dealt with center mounted winch. But I’ve used shackles to route my steel cable off to the side when I needed to pull a dead vehicle over when the trailer can’t be placed in front of the car. Is it possible to just use a shackle to redirect the cable as needed?
Have you considered building an under deck box mount for the winch ? It'll basically be hidden until you need it, pop cover off and unspool cable.
The only time I would worry about the cable stacking up if it started to put it in a bind. . . as too much cable. I'd be more of get it home, unload, unspool cable and re-spool it back in.
Figured you would already be ahead of the gaming thinking this one out Mike. I started building the winch box for my enclosed trailer and when NMRA/NMCA ceased operations, it got put on hold. Enclosed trailer now holds the '98 Cobra donor car, 4 wheeler and is in winter storage. That "on-hold" project patiently sits on the pallet racking shelf.Eric, I've been kicking around a tilt up style of winch that would fold flush with the floor except when needed. Just sketching a few ideas on paper at this point as that was the plan for the trailer build. I don't think it would be too difficult to incorporate into this one other than I'm sure I would have to add some reinforcements. Figured it would be a bit more work but look nicer than having an enclosure on top of the deck. Also will more than likely need to convert over to a powered hydraulic ram as once I add a winch it will throw the weight off for the gravity/hydraulic assist system. For long wheelbase vehicles, powered hydraulics are a bit more predictable anyways.
The wife looked at me a few times when I was building out he enclosed trailer after buying a bare trailer. After going to a few races and swapping plugs or making a jet change in the carb, she would sit on the fold over couch and watch. . . she began to understand.Oh I have a lot of ideas Eric, just not sure how many actually come to fruition though.
I keep telling myself that one day I will have another enclosed trailer, but unfortunately, at this point in my life, an enclosed trailer really isn't necessary. But man, oh man, did I love hauling around my enclosed race trailer all those years.There's something about having a rolling workshop with everything clean inside.
I used to tell my wife and son that thinking outside the box was a bit more difficult for me because my whole life was in a box. Worked in a box at home (shop), traveled in a box (coach) and worked out of a rolling box (trailer) while at the track.![]()
I also knew a guy that laughed at the little 3' Wilton vise I put on the work top. . . . . ha ha ha what are you going to use that thing for ? I'm not rebuilding an engine at the track, if it's anything major, I pack up and go home. He ran Top Sportsman, liked to spend big $$ and did win a Wally with the help of one of his former friends. Unfortunately for him, he got caught with the wife of his crew chief friend, he sold everything in a fire sale and moved to Florida with no more racing for him . . . . then his 2-3 pack a day Marlboro habit caught up with him.
Former co-worker of mine set his flat-bed's deck winch with the fair-lead facing up and flush with the deck. There's good and bad in that, depends on what the priorities are. His was a hawse, but if I did that I'd want a roller fair-lead with a larger diameter roller on the "bottom."
As to offset vs. centered I can see a valid argument for either. If you have the room for it then centered with a 'Y' spreader to two pull points seems like the best bet. That's a long trailer deck, so I think offset and a single pull-point makes a heck of a lot of sense on a more typical length deck.
As I'm sure that you're aware, this isn't off-road recovery, with very rare exceptions you aren't going to need a lot of pulling power. Also likely that most pulls will use a max of twice the deck length's worth of line at the most. Could likely run a lower pull weight winch with the line shortened so as to reduce the number of wraps (& increase the pulling power) while also buying you some 'bunching' room on the spool. If you do put on a nose box and/or guard then can easily carry a line extension for the rare times when more cable length is needed.
ETA: Years ago there was a thread on wives & girlfriend's 'surviving a desert race' on Race-Dezert. The best post that I saw in that thread, and there were a couple that altered how I did things as a bachelor, was from a gal who was a vet of many races. She said "Guys can talk about shock valving forever, bring a book."
