mop or squeegee for snow melt in the garage?
Innovate1
The guy that did the epoxy floor suggested a squeegee for dealing with water. Floor has a significant slope and snow brought in on vehicles is about the only time it's an issue. I knocked off the snow from wheel wells, etc and got a little water on the floor and now have dried spots of dirt from the evaporated snow. Thinking a mop and bucket with wringer (which I have) may be better - at least this time. May end up with both as an 18" squeegee is under $10 at the big box stores.
Jazz1
Thunder Bay On.
I use my shop vac for sucking up the water in garage in winter i also have a 1” wide strip of plastic going around the inside perimeter of garage to keep water from flowing under work benches and to the walls.. my vehicles only come into garage if they need service.
Mrdix18
New York
I respect your cleanliness habits and only wish I could follow that effort with my garage , I am not familiar with the weather in your state as well .
I live in upstate - central new York area , on average we recieve around 120 inches of snow a year … I typically push the big piles of snow out of the garage with a snow shovel as it falls off vehicles or falls into the garage as one opens the overhead door .
in the spring I pressure wash the epoxy coated floor to remove the seasons accumulated debris.
Stuart in MN
Minneapolis
A squeegee pushes water around, while a mop picks it up. If you want the water to go down a drain or out the door, use a squeegee, if you don't have a place for it to go use a mop.
I use a squeegee (or a shovel, depending on the temperature) to get slush and melted water out the door.
racecougar
Missouri
In my attached garage, I squeegee out the majority and let the dehumidifier deal with the rest. Mopping would be a waste of time, as more dirt will track in as soon as a car moves in/out. The floor gets swept semi-often, but I've never considered mopping it.
The squeegee works well, IMO.
finn
The UP, God's country
Flat bottom snow shovel, followed by a squeegee if the ice on the floor melts. Then, if everything dries out, use a push broom.
Mop the floor in April when the daily snowfall ends. Anytime earlier is futile and a waste of effort if you live in the snow belt.
charbar
Midwest
These Flex Blade squeegees are the bees knees. On my floor they work way better than a normal rubber or silicone bladed one.
Byrdnyrd
Taxachusetts
Squeegee is the Answer! I use a flex blade like the one above, works awesome! I typically open my garage door about 3” and send the water outside! It’s a heated garage so snow on the Cars quickly turns to a lot of water.
Mop-Bucket-wringing-emptying……..fugetaboutit
Cheers,
BN
jhelrey
MN
I have a floor drain. I'll use a squeegee to help things along a little faster or because I want it to dry out sooner.
MOS3522
Colorado
Push broom to move big water and squeegee to finish. Then a box fan/ventilator fan to keep it dry.
ETA: Big water means ice and snow chunks.
thammel
Maryland
I bought and still have a snow melt catch mat. It's large enough to fit under my car. Has raised edges to contain the water. It then evaporates and keeps salt off the floor.
lolaetype
North Western Arkansas
You can get work done and have a clean work space. They aren't mutually exclusive
I agree. In my opinion, a clean garage is a safer garage. Fewer trip and slip hazards, less chance to contaminate projects, easier to find dropped items. It's also easier to get things done and get them done more efficiently.
csp
Franktown, CO
I wished I had kept up with the snow melt in my old garage which had an epoxy floor. I did have a couple of areas of damage from welding and moving a Dana 60 front axle across that floor and the mag chloride in that snowmelt was causing the epoxy to lift.
I
Innovate1
I wouldn't say we live in the snow belt. We get a few snows a season usually and they are pretty small. No reason to leave crud on the floor for months between snows. The garage is mostly for parking cars and light work - nothing too messy. Have a detached garage for more serious work.
mikedodge
Squeegee. Mop and bucket takes too long and you'll never use it.
If the snow is only from driving and not bringing something in to clear off you'll probably find that if evaporates pretty quickly or you end up not squeeging it too, we never did.
mikedodge
OK, disregard the end of my last comment. Here pretty much every time you go out in the winter you're dragging something cold and messy back in.
shade
(Formerly)Phoenix, AZ: (Current) SW MI
Being new to the snow I was irritated how snow melt leaves such a mess.
Being from AZ never had to think about things like this.
After the first snow and having it pool in the barn, I got a car containment mat
Snow drops onto that and evaporates quicker than on the concrete, but I can yank it outside and empty the water quickly.
Squeegee on hand just in case
