1/2” diameter and drilling through the diamaterWhat size hole? Drilling the end or through the diameter? How many holes? How accurate do your holes need to be?
I’d make a flat spot with a grinder so the bit won’t walk then go 3/16” as a pilot and right to 1/2” for your finished size1/2” diameter and drilling through the diamater
Doesn’t need to be accurate at all
Until you know the material your dealing with then we are all guessing at what you may have. If you don't know then do a file test to see if it can be cut. If you file it then you can drill it. If the file just skips across the surface then you have a whole 'nother level of difficulty.Need to drill some holes in hardened chrome rod, rod is 2.5” diameter. What kind of drill bit is best for this job using drill press?
Assuming it is something like a hydraulic cylinder rod, The chrome layer is not that deep. Mill a flat spot (even by hand), center punch and use a starter bit. Then a typical good quality twist drill is all you need. At least until you hit the other side !1/2” diameter and drilling through the diameter
I agree. Getting started is the hardest part if you do it right and manage to push hard and keep making chips. OTOH, if you start to burn up bits and let the material work harden, you'll never get through.Assuming it is something like a hydraulic cylinder rod, The chrome layer is not that deep. Mill a flat spot (even by hand), center punch and use a starter bit. Then a typical good quality twist drill is all you need. At least until you hit the other side !
I use those terms interchangeably. What is the difference ?... use a spotting drill or even a centering drill ...
Starting with the image from the post above, true spotting drills have a more obtuse angle at the tip than drill bits (typically 140 degrees vs 135). The effect is that the dimple they produce brings your drill bit towards the center BY the center, rather than by the edges. Refer to this image:I use those terms interchangeably. What is the difference ?
Chrome is just below a diamond for hardness. Then the hardness of the rod. Lots of opinions here but no one has actually done it?
We had a Lucas a size or two bigger than that one and they were nice jig mills. I personally like the two DeVliegs better because they spindle feed but some of the guys were rabid about the Lucas and the table/saddle feed!
The parts done at work were small parts. They had 3 of the old Van Norman 22L mills. I built tooling and established production setups on them. They were sweet to run and were convertible from horizontal to vertical use.We had a Lucas a size or two bigger than that one and they were nice jig mills. I personally like the two DeVliegs better because they spindle feed but some of the guys were rabid about the Lucas and the table/saddle feed!
-What you posted is true but excessive heat should be kept in mind. The carbide tip is brazed/silver soldered onto the steel, much like with masonry drills. When heated enough, the brazed/soldered joint becomes soft enough to let the carbide go. An appropriate speed and/or using an interrupted/peck cycle is advised. When drilling hardened tool steel I've had one or two carbide tips let go in the past. Digging shattered carbide fragments out of a hole is no bueno. This not only applies to the start of the hole but also as you're exiting the other chromed side of the rod. Just an FYI for others here.Carbide tipped drills are available for tougher or hardened materials. The HHS steel shank is more forgiving than a solid carbide tool against shattering.
