micromind
Fernley, Nevada, about 30 miles east of Reno.
Been trying to get some more work done on the new Vanagaru... Westfaru?--while cleaning a Rinnai--again. I did it weekend before last so I could take off a couple of days to drive over and get the new rig.
It's 43-45F and raining constantly--not hard, but non-stop. I guess everyone in the NW is in the same boat (gawd, I hope not--get your own boat!). I hear the West Side is getting clobbered--over six inches already today in places.
Between that and the Rinnai throwing me curves--I just spent 30 minutes fixing a clogged water-flow turbine on it--I'm not getting much done on the Van.
Now I'm wondering how high the rain is? If it's falling much above 6,000' ASL, it's falling on snow... that can turn ugly. Supposed to keep it up for days.
I grew up in Albany Oregon..........I don't miss all the rain at all........
Beerhippie
Far NE Oregon
My eyes!
6775914587968855735-jpeg.2452353
That ceiling texture is giving me intense flashbacks to the seventies....
budo55
Pure Michigan
Started the headstock rebuild of the Logan, and whoever designed this must of had six baby monkey hands to put it together. But I persevered, and the most difficult part, the back gear, is done. Having a vintage lathe that is full benchtop sized, but compact, necessitates some clearance compromises, and most of them are in the head.
Also, came up with a workable plan for the shop layout once this goes in, but still need to get rid of junk to get there.
Kay, what size is the Logan?
niget2002
Josephine, TX
battery replaced. PS hooked back up to charger. Everything back installed in laundry room. Did a quick test-pull on the vacuum to make sure it worked, but need to fully charge the battery before first 'use'.
I forgot the follow up... Wife got home from work. I told her I swapped the battery. She tested it out. Vacuum works and floors are clean :)
Before you ask why I didn't test it myself... I was cooking dinner.
Beerhippie
Far NE Oregon
Cleaning a kitchen appliance:
The kind that requires a forklift. Brilliant. I don't know what the flattop weighs, but last time we used four hale young lads to lift and move it--and it was touch-and-go the whole way. Those kids have since become convinced that college wasn't a bad beginning of a career path.
Not only do we need the forklift, but there are lots of little complications, requiring the damned thing to be almost completely disassembled to remove and clean the burner tubes.
These little capillary tube senders for the thermostats are held to the top with brackets and nuts:
What a great design for something requiring regular maintenance.
This is why I took it apart:
The Bunsen tubes fill with carbon deposits over a couple of years and quit working properly.
All five of them:
Ol' Chas on the job.
How to clean the inside of u-shaped Bunsen tubes?
The Milwaukee Pow-R-Snake!
I've mentioned before that heat will make stainless steel no longer stainless. Here's proof:
Clean and waiting for the kitchen staff to clean the rest of the flattop.
Matt018888
Shelby TWP Michigan
Did some work on the Silverado. Valve covers, PVC valve, cleaned MAF, cleaned throttle body, new coils, spark plugs, wires, oil change and replaced oil cooler lines. Still have tires, coolant flush and trans oil to do.
Skyman
Central Maryland
The kind that requires a forklift. Brilliant. I don't know what the flattop weighs, but last time we used four hale young lads to lift and move it--and it was touch-and-go the whole way. Those kids have since found better jobs.
All five of them:
I hope the ownership appreciates you as much as they should, Timm. I can't help thinking that, when you eventually depart, they might be best off to just bulldoze the place and sell the property. At the very least, they'll be writing large checks to an army of maintenance and repair personnel.
Skyman
Central Maryland
It's too damned cold again today to do much out in the garage. I rolled the Blazer out of the way, then trimmed the excess length from the two strips of LED lighting so that they'll now fit fully within the channels along the inboard sides of the runways on the new four-post. They were several inches too long, as-furnished. After that, I spent some time developing a plan for where to mount the power supply for those strip lights, and how to dress all of the associated wiring. Then placed an order from the jungle for extension cables, and various tie mounts to be used for that chore.
kaymccampbell
Upstate New York
Finally finished the bespoke decoration, that's dragged out for literally months. Between my lack of energy, competing Dr appointments, the PC cooling fan dying, you-name-it, the damn thing is in the box and out the door.
After way too long trying to accurately draw an Alco C420, etc, here's a first burn to prove out my design. Too much detail.
After several iterations.
After paint. In it's 1960s livery. The LIRR pulling out of Babylon station. I took a few liberties.
And I cleaned my brushes, and opened up my new little burrs.
Some smalls today:
Cleaned the camp (Weber box) BBQ after using it last light for lamb chops. decided it needed some other maintenance after noticing a missing washer on the legs against the damper on one corner. removed everything cleaned and straightened the bent aluminum dampers, found the washer in the middle of the leg, and got those back in the right place.
Cleaned the outside with Grez-Off, and lemon oiled the 3 wood handles.
Refilled the 3 lb Skippy jar with briquettes and put it inside the small starter can, and got everything , including starter paper back inside the box for travel and immediate use.
The trick to pulling that off is to:
o cut the top grill in half so it can be stowed stacked and
o put one end of the bottom charcoal grill under the leg stubs
o and the fire starter can goes on that end with the Skippy jar inside it. (the only plastic jar I have found to fit inside the starter can...)
Depending on what you are cooking and for how many, one Skippy jar full can go for up to two meals....
Then I emptied our top "Knife (or any sharps) drawer" and re-glued the de-laminated veneer. When I un-clamped it I discovered the other end had some more veneer de-lamination, and the ply was splitting/de laminating! So its drying on round 2...
Mother's polished a rolled penny souvenir for a stocking stuffier.
More leaves pickup on parkway and terrace at the corner (2 barrels), getting to the "home stretch" on the oaks.
bugnut
Central Ohio
Parts languished on the bench for the prusa. Finally got time to put it back together, proceeded to get everything up and running. First test print and the new nozzle put a nice grove pattern on the print plate. Stopped and reset the superprinda. Tried again and the nozzle is higher and off the plate but not flowing enough. More fiddling to come
I truly believe the whole 3d print world would benefit if the hotend of printers were a cassette type item that just bolts/snaps in with tight tolerances, and then a tool setter type feature were the nozzle touches a z axis setpoint, so they could literally be changed on the fly. Wishful thinking.....
kaymccampbell
Upstate New York
I do believe that Bambu already has that covered.
LeeG
Phoenix, AZ
I picked up most of this Dumont E size broach kit at a sale a while back, and filled in the missing pieces from eBay. It’s been taking up bench space for months. I finally got a case built for it. Just waiting on the latches and handles, and I can put it away until I need it.
Lee
rharman
SoCal
Actually, a side box would be a good place to mount a bench top drill press and you could keep all the bits etc. in one draw and all the hand held drill's in the other drawers. Thanks for that idea LOL!
I have a HF side cabinet mounted on casters that I roll under the table of my floor model drill press. Keep all my drill bits & DP table clamping thingies in it. It's been really handy.
