why di they drain inside? temps?
I assume temps and otherwise they would have to drain external and downpipes down the side of the house. There is a network of heat tape as well for the flat roof.
Wow, its just keeps getting more and more amazing!
Thanks!
Jeff, what about the snow accumulation on the flat roofs? I have no idea how to build a house in the Teton's but is that an issue? Im sure its been addressed, i guess I'm just curious.
The build looks great and Im really enjoying the updates. Its hard to believe you are having to go through this excitement remotely.
The house was spec'd with certain load rating for snow - so I would assume that is taken care of. They also accounted for earthquakes but not sure how that was determined.
Very cool seeing the detailed pictures of handling the slope for the flat roof drainage. I am also surprised about flat roofs with all the snow
out there.
Thanks - definitely a process. They intend to flood the flat roofs to check for leaks and drainage at some point.
Fantastic! In every way, Jeff!
Such amazing views you'll have! The drone footage really adds perspective to the site.
Drains inside are common in commercial buildings. Or where cold is as advertised...
Thanks! Yes I believe routing inside due to cold. Again there is some thermal system for the flat roofs, need to see how that works.
Im jealous of the floor drain in the shop. I wasnt allowed to have one without installing a grease trap and all that mess. So I just opted for a flat floor and a squeegee.
There is some type of trap system it drains to, I think it amounts to a big box of sand with a catch basin that will require periodic maintenance or cleaning.
Such a great thread, really appreciate the time you put into updating. Keep’em rolling!
Thanks will try to be more diligent with updates!
Why do you have so many control joints? That seems like a lot!
Well I said no cracks...so maybe they took that to the next level. Honestly I was never consulted on the control joints. I think the concrete guys took some "artistic liberties" That concrete is final finish so there will be a degree of polish - nothing crazy, matte finish. I do know they come back and seal those joints. You can do seam sealer of metal - that later might be cost prohibitive.
Some stats from the structural calculations on the project: (yes I fed the entire 45 page structural assessment document into ChatGTP for plain English)
Snow
Your home is engineered for
122 psf ground snow and
85 psf roof snow, which is extremely robust and appropriate for Teton Valley’s heavy-snow climate. This is a
high design load.
Earthquake
The project is designed under
Seismic Design Category D, meaning:
- The house must resist strong earthquake forces.
- It uses engineered wood shearwalls to take lateral loads.
- The engineer applied standard IBC 2021 seismic parameters with a base shear equal to ≈ 9% of the structural weight.
This is a solid and typical structural strategy for your region and site class.
Couple other other updates. After losing our dog Ruckus back in February the house seemed a bit empty and our other lab McCrae seemed a bit lonely. We arrived at the conclusion with everything going on with work and the house build we determined the best thing to do was to get a puppy.
introducing "Disco"...cousin of McCrae...he is the one in the middle - trying to escape.
Brought him home Aug 1
Disco is doing great and really enjoying McCrae and vice versa.
Then - it was around the first part of October we decided to head out west for a trip to see what all the fuss was about.
I'll be honest, it was a bit of a dream of mine to one day head west on my bike to see this thing being built. With work being crazy I was only able to sneak away for about 10 days on the bike.
My better half had crazy work going on also but flew into Jackson Hole and we met up there for a few days...
But first some bike maintenance:
I think the spark plugs where changed at around 12k miles...and I was coming up on 50k fast.
I think they were due - 4-5 hours at 85+ mph and 5,500 RPMS and you get this: still running great and no issues with the old ones.
More to come...
