tooljunkie4
The short version:
Looking for others' experience with modern wood stoves, as well as recommendations for stoves to look at / avoid.
The long version:
A chimney fire has necessitated the replacement of the chimney pipe in the house. It has been suggested that the wood stove insert should be replaced while we're at it (20% efficiency, not insulated, currently installed too close to wood framing).
Turnaround time on whatever we may order (including the pipe) runs about 5 weeks. The sooner decisions are made, the sooner the order goes in, and the sooner we have heat in the house.
I am not up to speed on modern wood stove offerings. If we were to replace what we have, I would look for options that check the following boxes:
- Has blower (ideally a plug-in unit which can be run by generator during power outages).
- Has a casting that can be used to heat water (kettle, pot) either to add humidity, or for use in heating water during power outages.
- Low annual maintenance costs (no catalyst).
- Built for heavy, constant use.
- Capable of heating 3000 sq. ft. with ease.
The house is electric only (by chance rather than by choice). Gas is not an option.
Current insert is an old Timberline. Same as this one (but not this one).
The long version:
