rharman
SoCal
Been trying to get some more work done on the new Vanagaru... Westfaru?--while cleaning a Rinnai--again. I did it weekend before last so I could take off a couple of days to drive over and get the new rig.
It's 43-45F and raining constantly--not hard, but non-stop. I guess everyone in the NW is in the same boat (gawd, I hope not--get your own boat!). I hear the West Side is getting clobbered--over six inches already today in places.
Between that and the Rinnai throwing me curves--I just spent 30 minutes fixing a clogged water-flow turbine on it--I'm not getting much done on the Van.
Now I'm wondering how high the rain is? If it's falling much above 6,000' ASL, it's falling on snow... that can turn ugly. Supposed to keep it up for days.
My niece's husband works for the railroad in Washington. She told us there's a 400' section of track where the ground underneath just washed away. Track is dangling. :yikes:
bmwrd0
Beaver Fever Oregon
Spent the last bit making a prototype drum switch mount for the Logan
Not happy as it stands, as it is very ugly, but it does work exactly as I want. I will probably replace the bit of angle with a piece that goes over everything and tidies it up but this is what I had on hand. And I was going to wire it up, but I am not sure how I want to run the wiring. I am getting an idea, but want to sleep on it.
It is starting to look like a real lathe though
kaymccampbell
Upstate New York
Be careful that the apron can't crash into the switch.
I agree, that will interfere with the carriage apron.
Not much today. just a little needed for leaves as I had the barrels full for "garbage collection prep" -Tomorrow is PU day.
I did start late today trying to polish scratches out of the little Queen knife I got a few months ago. the PO was bad at honing... I started with 2000, then down to 1000, still a long way to go, so next is 800, and maybe 600 before going back up and polishing.
I did deliberately; start with the lightest to see how bad it needed a heavier grit.
I will say this; I cannot feel any scratches with my fingertips anymore, so any burrs are gone!
bugnut
Central Ohio
More fiddling with the prusa, gonna keep at it, for some reason it quits feeding the filament. Need to check temps and insure it is properly calibrated.
I do believe that Bambu already has that covered.
@kaymccampbell, Kay have an x1c with ams and have been using it, so the prusa languishes. I have needed nothing for it since its arrival. Considerable difference between printing and fiddling. I'll withhold judgement till repairs are required.
bmwrd0
Beaver Fever Oregon
No, it is just a hair past the carriages furthest travel when in its final spot. Right now I need to be able to wire in the switch, so I gave myself space.
But good looking out!
kaymccampbell
Upstate New York
Microplanes are my tool of choice. Also great for garlic!
I would love to use a microplane, but my heel calluses are atypical. Instead of bulging out of my heel, my heel looks normal, and they bulge in, giving me a horseshoe of pain around the heel. I have to grind a 3/8 wide by 1/8 deep groove around my heel. It fills in with regular heel overnight, and looks and feels normal-ish, if a touch tender, the next day. Then 6 months later, it starts to hurt again.
kaymccampbell
Upstate New York
I was thinking of the H2C with the Vortex nozzle changer, where it can swap out clip in induction driven nozzles on the fly.
rzims
Grass Valley, CA
Not in the shop but on the new property nextdoor.
We bought as-is which means I've spent the week cleaning and emptying the 480sf cabin.
Did find a couple of cool old treasures...
Wooden ax box from Army Corp of Engineers and a couple of old Tonka toys
DGersic
DeKalb, IL
All of this talk of lathes. Wishing I had one (and space for one).
Fixing my push broom. Broke the plastic hanger handle end.
Found some 7/8” dowel in my stash of spare bits of wood. Fits the broom handle ID. Doesn’t fit the broken off plastic top. No lathe, but I do have a pull saw, and a chisel.
Some fine finishing work with a rasp to make it fit.
Some JB Weld. I did score up the plastic inside, so even if it doesn’t hold, the grooves filled with epoxy should keep it from pulling out. Probably.
I measured the OD of the plastic topper at an inch. I found some 1 1/8” shrink tube. Seems that their rough measurements are less correct than mine, couldn’t get the tube to go on. Milwaukee PEX expander helped make the tubing a little bit bigger, and it went on.
Ready to return to garage service.
GreenIron
A bit north of the GOA
You have lots of patience. (y)
In the garage shop two days ago:
I had spare time from my unusually-busy retired work schedule to weld together a somewhat-looking?? silhouette of a '66 Impala(36'' long). This is my first try at a silhouette project, so it may not look exact. :unsure:
I flung flat-black paint on it and called it good'nuf to hang in my home office. ;)
Beerhippie
Far NE Oregon
Be advised that orange paint does not taste like oranges.
You kids don't know what you're missing!
When I was your age, we had real lead paint! That sweet, sweet taste of lead sulfide--just like sugar, but less fattening....
Today's library paste doesn't hold a candle to what we had, either.
budo55
Pure Michigan
I do have a lot of ****, but no Logan lathe. I wish, but I'd have no place to put it.
I have restored 2 South Bend 9x36 lathes and each time regretted selling them when I stopped doing gunsmith work. Years and a couple of house moves later I felt the need for a bench top lathe and got a vintage Craftsman (Atlas) 6x18 that sits nicely on my bench but will be moved to a stand when I get around to putting the stand from Rockler together.
Beerhippie
Far NE Oregon
Picked up the last ten parts I need for the brake swap tomorrow:
I was in a bit of a panic today when I realized that I needed ten new conical-base 14mm 1.5 lug nuts for the job. The original front hubs use lug bolts. I tried everywhere else first, to be told they could have then by next Thursday. Les for the win--at $4.10 each, but they're perfect matches--one of those is original and I can't tell which.
Having studs up front will make tire changes much easier. The lug bolts were a VW thing I always hated.
Just waiting on the local machine shop to get the new studs pressed into the new hubs. I tried using my antique Reed 404 1/2 and a socket to press them in--and decided that I preferred the old vise in one piece.
Crazyjake8493
Upstate NY
Got the tractor out to clean up snow drifts from yesterday.
Serviced the Ariens walk behind a bit. It had been stalling out occasionally under load. Pulled the main jet out of the carb and cleaned that. Had a bit of gunk in the idle transfer passage. Runs great now. Also changed the gearbox oil and snugged up the auger belt a bit by adjusting the idler pulley.
