YesIHaveAHammer
- Joined
- Jun 1, 2025
- Messages
- 847
I've always considered 160mm (6.3") to be the "standard" size, and models of this size are most popular at my usual online tool store. It's a good size in the hand, not cumbersome but not weak either. It's ok from vehicle electrics to some gauges of fencing wire, so if you're only going to have one at hand, it's probably a good choice for many (depends what you do, of course).
One thing I've come to appreciate is to have the best size tool for the task, even if a mid size would be satisfactory. Recent ones for me have been hammers (got a set of all the common oz sizes), and end cutters (got a 200mm and a 140mm). It's just easier, more comfortable, safer, less fatiguing. Seems the same would do well for diagonal cutters - small one for small or soft things, big one for bigger or harder things.
So what do you have, and what do you tend to use?
edit - and for what kind of stuff?
Relative comparison for reference:
- 140mm (5.5") - 0.88x length
- 160mm (6.3") - 1x
- 180mm (7") - 1.13x
- 200mm (8") - 1.25x
- 250mm (10") - 1.56x
- High leverage ones seem to be same cutting spec as the next size up in standard
- Special mechanism ones (e.g. TwinForce) seem to be same as the next size up again
