bugnut
Mike, thanks for sharing. Like you my faith and the bursar, are and continue to be the wellspring, on which we have built this wonderful life we continue to enjoy.
I used to have a wife like that...What would you do with all that vacation?
My service calendar runs out at Dec 31 and I won't have all my 2024 vacation burnt by then.
Carry over 5 weeks for '25 and add the 5 weeks for '26.
I'd go on more trips. Most of the group that I go with on "Guy Trips" (as my wife calls them) have recently retired. They're going on a lot more trips than I can.What would you do with all that vacation?
Some good family pictures Mike. Glad you guys had a nice weekend. ***** about the tires, hopefully they work out for you.
Pfffft...Dig out the tire groover and make them a 3 rib?
Those'll be nicer on your yard anyways for the little time it may actually see grass.
Unfortunately wheelweights for a WheelHorse will be harder to find, but blank suitcase weights are easier to get ahold of, and you can hang more of them than wheelweights. Esp with your 3pt hitch.
Would it be possible to put chains on your front tires?The only reason I chose to go with the 3-rib was because it won't see any times on the grass as this will be used solely for snow removal and not mowing the lawn. The 3-rib would give a bit better lateral control vs. the 5-rib, but not quite sure just how much better. I think that's the only reason I am willing to run the 5-rib, as they should still perform well.
Chains can leave marks on concrete surfaces, something picky people may not be excited about.Would it be possible to put chains on your front tires?
I use rear chains on my lawn tractor in the snow, but I never considered front chains before.
Good point -- my chains are used in snow over gravel or dirt.Chains can leave marks on concrete surfaces, something picky people may not be excited about.
Chains on the front either need v-bars, or diagonal cross links to aid in steering, "X's" are better yet. Regular ladder bars turn into skate runners when the tires are turned, especially without drive power to them.
If you are running the blade at a good angle and pushing a good pile of snow, the ladder bar style links will allow the front end to wash in the direction of the blade angle.
While I can't understand why you prefer an empty 3pt, I would think a weightrack/trailer mover would be a practical answer for you in the same ways it is for me. The ability to hang weights for snow removal and slide anything into a 2" receiver is pretty handy. With your two trailers, being able to back up the tractor and grab one to pull it out of the way is easier than wrestling it onto a truck hitch or rolling it on your own.
Just one man's two cents....unless you count the last couple posts, then maybe its getting closer to 10cents...
Here's mine Mike. Don't even need to touch the trailer jack if I have the 3pt height set right. Just back up and lift up, then pull away.I'm not gonna lie or pretend that I had thought of that, because I hadn't. I usually have things thought out pretty well in advance, but the thought of using the tractor to move the car trailer around didn't occur to me. Not sure I will because it is so easy and convenient where it is parked to hook up to with the truck where it is located alongside the shop, but it is an option I hadn't thought about. I may have to rig up a ball mount on the tractor just in case.
Mike are you going with the Air Force One braking system? It's a pretty good system, but the actuator that goes on the brake pedal in the Jeep can get in the way of your foot. I've learned to live with mine, but it takes some getting used to. I've got it mounted up about as high as I could get it and I still hit it with my foot from time to time. Anyone else that drives the Jeep has issues with it.
The other thing that I had trouble with was confirming that when I hit to coach brakes, the brake pedal actually moved. At the slow speed in the parking lot where I tested it, there wasn't much movement. I propped my phone up and recorded a video. To some level, I just had to trust that in a hard braking event that it actuated more than I saw on the video. I will say that I haven't had any events where I felt the Jeep "push" on the back of the coach, so it seems to work well.
Thanks Keith, I've installed several of the Air Force One kits on a few different coaches as a couple of the M&G kits over the years. I really like the M&G because it is non-intrusive into the cabin area, but with my configuration it may be too tight in an already tight engine bay so it will be the AFO.
I just don't like the cheap setup that the kit comes with on the coach side. I know most haven't had any issues, but I prefer to use an actual heavy truck brake relay and PPV valve vs. the smaller non-commercial components in the AFO kits, which is why I'm going the route I am to be 100% in compliance with the FMVSS 121 requirements. I'm sure it's overkill, but you know what they say.....![]()
One of those projects that is best in the "done" column!Last night I was finally able to finish up the PPV valve replacements on the rear air tank on our coach. As much as I hate to admit this, but I have been procrastinating crawling up under there again. There is not much room under these things and it seems like once I get positioned under the coach I have either forgot something or I can't reach what I need so any work under the coach is less than enjoyable. I finally told myself last night that I should be grateful that it is a simple replacement of parts and not something outside of my wheelhouse and just dive in, so I suited up and got after it.
I also prepped the air supply line to cut into it for my supplemental braking system, so the bright green air line at the far right in the picture is nice and clean where I removed the paint and undercoating in preparation to cut and install a T fitting.
I then moved to the front air tank and marked the lines going to the two PPV valves that will get replaced.
Air lines disconnected and PPV removed. After taking this picture, I cleaned the ends of each of the lines back to remove the paint and undercoating a little further back and then cut about 1/4" to 3/8" off each air line to remove the small groove from the previous fittings so they are ready to reconnect once I install the new PPV valves.
I realized that when I bought the fittings for the rear air tank PPV valves, I doubled up on the fittings, but the front has two different fitting configurations and sizes so I need to stop on the way home and exchange a few fittings. Plus I need to purchase a 25' package of 1/4" DOT air line to run my supplemental braking line from the auxiliary air tank that I will be installing back to the hitch area of the coach.
Thanks for looking.
Might be too late but did you see these tires?
18x8.50-8 Hartford 3-Rib Front Tractor Tire 6 Ply
18x8.50-8 Hartford 3-Rib Front Lawn & Garden Tractor Tire for sale online, 300-850www.millertire.com
(All my zip ties are the same color....I feel so inadequate)![]()
. They just work well for identification purposes, I don't know that I would trust them for anything more than that.
