Between 485 & 705 SQ/FT 240Zed's Garage
240zed
Maine
Latest update:
Walls and roof went up for the most part.
The old garage door wall was 2x4 and I wanted to change it to 2x6 and frame it up for a taller door. I framed to receive the existing door s for now to get through the winter.
Weather is not co-operating here in Maine. Snow, thaw, more snow, then rain and then freezing!!
dcg9381
Austin, TX
Educate me:
Zip-R was not "approved" for roof panels? But that **** is red.
Not that it couldn't be used as roof panels.... Or shouldn't... I love the stuff.
240zed
Maine
Educate me:
Its Zip 5/8" roof sheathing on the roof, ZIP-R on the walls.
240zed
Maine
A little update:
On the exterior - Ice & Water, drip edge and Shingles installed. Both garage doors back in and operational. New garage side entry installed in place of an existing window. Insulate the little knee wall - very awkward job as it had to be done from the outside. Edit: Even with Zip I'm going to wrap the house with Hydrogap for under the LP siding and possible cedar shingles on the shed dormer.
While we wait for the windows we start framing up the interior walls. Bathroom and small change to the way the two roof lines meet in the interior.
larry4406
Northern Virginia
Wow!
Very nice addition!
I think it will blend well with the house once done.
Smart temp re-use of the old garage doors while construction is going on.
I am part way thru a master bath addition at our home and the weather here has been too cold for me to want to work out there. Its weather tight, so no harm short of having to use an alternate bathroom for now.
Always loved the old Z's. Friend of mine's dad had a 240z he bought new.
240zed
Maine
I got some catch up to do here. Doing a lot myself with friends help so the timeline is constantly getting stretched.
The windows showed up while we were away on February holiday. Late Feb/March we ended up getting weather tight. I ended up removing all the old Tyvek wrap and used the BO Hydra-gap wrap to cover old and new sheathing for additional moisture mitigation.
I also installed the two new garage doors. 9'x8', R18 insulation, windows in top panel, high lift track and Jack shaft lifting motors.
240zed
Maine
Once we got out of Winter - I started to pick away at the siding. We have the original vinyl on the house so I wanted to get the match close but refuse to install vinyl. So as we are eventually going to reside the whole house we went with a pre-finished LP siding lap. Costly but such an easy product to work with. The shed dormers with get kiln dried Grade A cedar shakes for a little pop.
240zed
Maine
The only trade I'm 100% subbing out is plumbing. He's been working away roughing in the bathroom fixtures and the heat pump heads. As the primary is now above the garage I elected to add a head in there. With all the walls open we were able to get the reefer lines and condensate drains hidden. I wanted a min amount showing on the exterior walls. I'll get the pad and riser for the condesanoe installed next week after I finish up electrical rough-in.
240zed
Maine
On the electrical rough-in; I already have a 100amp subpanel in the garage so everything on the primary suite and any of the upgrades in the a garage are terminating back there. I'm going to preplan a little and run some 6/3 over to my wife's side of the garage for a future EV charger. I have wanted to tidy un the wiring for a few years now and took the opportunity last weekend. Nailer plates, garage lighting and finishing upstairs is next on the list for this weekend. Going to call for a rough-in inspection next week.IMG_9550.JPGIMG_9594.JPGIMG_9605.JPG
