evapo rust wtf hard to find?
slowtwitch73
Hellgate
Evapo rust used to be sold everywhere. Just tried my local Ace, Blowes, and Home Despot with no luck. Grainger doesn't even have it, Mcmaster is a mystery as usual.
It's available other places online, but it's odd it's not at local stores anyomore. Big push by Rustoleum or other competitor? Direct to consumer?
First world problems to start of '26 lol.
My local Ace no longer carries it, but some auto parts stores, and HF both list it online as in stock. All much further away.
Nessism
Torrance, CA
Mix up some of this stuff instead. Cheaper, and arguably better.
1 liter of water
100 grams of citric acid (available on Amazon)
One of the following: 40 grams sodium carbonate (washing soda), or 63 grams sodium bicarbonate (baking soda), or 30 grams sodium hydroxide (lye)
Scale volume of solution as needed.
FrankLee
seMI, 48317
First world problems to start of '06 lol.
'06 ??????
Try citric acid... works great and so much cheaper.
GeoBruin
I see it at Harbor Freight all the time if that helps.
BillK
Beautiful Southern Maryland
Where are you located ? I just checked their web page and there is a bunch of places near me that have it including Tractor Supply and Harbor Freight ?
PCustoms
VT
5 second search and it shows in stock at 2 of the 3 stores I checked
Another few seconds to find it at McMaster
Grainger has it too:
(note link is auto-correcting to that, they have it)
jblnut
In the Middle of MN
1 liter of water
You had me until I needed to measure in liters and grams.
Ultradog MN
Twin Cities
1 liter of water
I just discovered that video this week.
Look at the number of views, thumbs up and positive replies. I found enough of the citric acid at the hardware store and baking soda at the grocery store to make a 3 quart test batch. It worked good and I ordered enough ingredients from Amazon to make 5 gallons - which was about the cost of 1 gal of evaporust. It should be here Monday.
An cleaning up an old lathe and will need a bunch of it.
Rustoleum has no equivalent (non-toxic, acid-free, alkali-free) solution. The only truly equivalent solution is Metal Rescue. If you ever do get skunked on Evaporust at all your usual places (my most consistent source, by far, is Tractor Supply), I have found NO difference in potency or endurance between Evaporust and Metal Rescue.
FrankLee
seMI, 48317
I use straight CA. Regardless, depending on what your de-rusting, the hottest tap water works better and faster.
mrvm
PA
Local Harbor Freight has Evapo-rust 1 qt and 1 gallon sizes. Picked up a quart last week using the 30% off
Vinny
Simi Valley, CA
1 liter of water
Isn't the addition of the alkaline just neutralizing the acid? Why not just put in less citric acid to start with?
M.Brane
1 hr N/W of LA LA Land
It's to create the churning in the mixture to help scrub the rust away for you while you do other things. Just make sure you add it slowly so you don't get a foamy mess.
finn
The UP, God's country
I switched to Citric acid about four or five years ago. Got the powder in a five pound bag from Amazon.
Started by mixing it straight with water, but grabbed a box of washing soda from Walgreens last spring when I saw it on the shelf, so that’s what I use now.
Still have half a jug of Evaporust I should use up. I’m hooked on the citric acid mid. It’s almost free compared to what Evaporust costs.
Beerhippie
Far NE Oregon
The reaction of sodium-based alkalis with the citric acid yields sodium citrate--an excellent rust remover. I use lye and mix it so that the solution is just a little alkaline to better cut through residual grease.
BUT! DO NOT use it to clean copper or copper alloys! It will turn your rust remover into a combo rust remover/cold copper plating solution!
I now need to throw mine out and mix up a new batch.
Beerhippie
Far NE Oregon
I like Evaporust because you can set it and forget it. After it converts the rust, it goes to sleep and won’t eat into the metal. With acid, you have to monitor the process and remove the part when the rust is gone.
Sodium citrate (the magic solution above) acts in the same way. I've forgotten a pocket knife I put in my bucket and found it a couple of weeks later, undamaged and rust-free. It was still a POS, just not a rusty POS.
sparky 1971
Central Iowa
Vinny
Simi Valley, CA
Interesting! Thanks for the explanation.
nadogail
Coronado, CA
If you get a MSDS, (Material Safety Data Sheet) for the product; you may glean enough information to make an equivalent product.
KnurledNut
n/a
I’ve been using Thermocure.
It’s concentrated Evaporust.
1 quart bottle will make 3 gallons of solution.
Its intended to be a cooling system rust remover, but I just use it for general soaking.
It takes up less room to store and it works out to be a little cheaper too.
Brandon_Lutz
Forest Hill, Louisiana
Was in the local HF yesterday and they have Evaporust.
Had never heard of Thermocure. I'll check it out.
Made by the same people that makes Evaporust. It works really well in cleaning up old cooling systems. I used it on my old 95 GMC K2500 a couple of years ago to help flush out the rust in the system. Should have seen the **** that came out, it was impressive.
I tried Thermocure back in 2019 due to the cost differential. At that time, I paid about the same price (~$20) for 1 quart of Thermocure as 1 gallon of Evaporust, but the quart of Thermocure would ostensibly result in 3 gallons of Evaporust with water, and therefore, I should be getting 3 x more product at 1/3rd of the cost per fluid ounce. But the diluted Thermocure did not work nearly as well for me as the same amount of straight Evaporust formula. In fact, it reminded me of experiments I conducted to stretch Evaporust with water, which only separates the chelating molecules, slowing down the process. When I heated the Thermocure, it worked a little better. When I periodically disturbed it, too. But then again, so does Evaporust. I bought another quart and tried it with only a gallon of water. It worked just as well and just as quickly as Evaporust, but at that volume, there was no cost benefit.
I have stuck with Evaporust (or Metal Rescue) ever since.
Not to argue with @KnurledNut. That was several years ago, results will vary based on what is being de-rusted, and he may be more patient than I am.
YMMV
slowtwitch73
Hellgate
HF and Oreillys were the hot tip. They are both off my radar for some reason. Got a nice Oreillys coupon so it worked out.
Not hard to find online in the least.. and Grainger does indeed have it.
The box stores and Ace seem to have moved to the Rustoleum equivalent which I have no experience with.
