BurtEggley
- Joined
- Oct 8, 2024
- Messages
- 915
Have American Standard 2021 water heater installed early January 2022. Model GN50T1-3-6. (it is GN and not GSN) Low NOX 50 gallon residential. No where can I find an actual parts list for this unit after hours of searching. At 4 years it is time to check the Anode rod and flush it. The flush drain opening is small and we wanted to upgrade it to a large size opening on the drain valve. Most water heater drain valves are 3/4 in size but this one is stamped 21/31 and has AS (American Standard?) on the other side. What the heck size is a 21/31 plumbing size/thread? 3/4 would be same as 21/28 so my concern is a 3/4 might be loose, although MNPT is tapered.
As to the anode rode, the manual says they all ship with aluminum anode rods but there is no length. I don't want to buy a longer one and cut it, or have to pull it out once to measure, see if I already have one or go shopping if I don't. Anyone know the length of the anode rod on a 50 gallon natural gas American Standard water heater?
Happy New Year to all.
