Finallygotit
Thant's great mileage! Just curious, do you know the last time the engine had a tune-up?
Fortune has favoured the braveBack home.
This car is waaay better, beyond what those people who hate on it would like you to believe. I am now convinced half the haters never even sat in one.
An absolutely great ride out on motorway in in town.
Calculator says about fuel consumption
216 miles and 29.6 liters
UK Gallons - 33 MPG
US Gallons - 27.5 MPG
Metric
11.7 km/l
8.5 l/100km
****** HELL !!!!
Happy New Year, Grizzly.
I'm off to bed!
Happy New Year Rian, looking forward to whatever you've got planned for this one
Those spoke wheels look an awful lot like Pontiac mags, wonder if you would find a set over there?I took apart one of the wheels just to understand how the wheel nuts and hubcaps interact.
You will see the hubcap actually has plastic domed nuts holding it down. Threaded around the wheel nuts.
Also, the protrusion in the centre under it all.
I have realised that I am going to need 5x115 to 5x114.3 adapters that would also act as spacers.
I certainly still want to go with the three spoke wheels.
I would think it’s highly unlikely that someone in the UK would have a set of 4 adapters to get me to 5x114.3
My crazy non engineering head has also asked me the question whether one could widen the hub facing bores on a set of 5x114.3 spacers to fit the 5x115 hubs and then delivering the desired PCD of 5x114.3 to take those Mk1 Freelander wheels.
Feedback, input, advice and donations accepted.
Perhaps, been a long minute since my brain saw one, I thought the 2 spoke variety was also on 90s Pontiac?These?
This chart shows your battery is at about 10% or so capacity for a lithium unit, likely needs replacing as you suspect.Time to start spending money.
Of course the Oldsmobile has behaved impeccably till 1st January 2026
At least it had got me home 260 miles at 33mpg on old years eve.
Seller had told me is sometimes would struggle to start, clicking a couple of times before it fired up
I was not bothered by this
Also, car came with an old used starter in a new box one assumes it was replaced before I have not looked under the car
So when I couldn’t start it on Thursday, I got the multimeter out…. 11.3 volts. Jumpers got it going instantly. Problem temporarily solved
This morning, -2’C and now about 3’c bonnet still frosted over…… the reading is 11.84 volts.
AND………..
It is a Lion battery.
We discussed them before.
So would the agreement be that one needs a replacement for the car?
While we’re spending money…..
Front tyres
They look a bit (very)iffy on the edges.
So I will see about finding and fitting a pair of part worns because I will be changing the wheels outright to alloys.
Obviously alignment etc needs setting too.
We’ll get that done.
Still not washed the car.
Because COLD.
Not Alaska cold, Not Scotland cold, just Kent cold.
Soon.
You might want to check to be sure the alternator is actually charging the battery after you install it. You should see around 13.6 to 14.7 volts at the battery when the engine is running with no lights or other accessories on.
Noice work![]()
Or decent adhesiveAlso needs a passenger side mirror cover
Noice work![]()
As usual, Rian’s karma point pot is so overfilled that is spilling over!
Rian, you are a helluva guy! I know from your past adventures that this will pay forward to you sometime in the future.
Life is good!
I had a comment on another forum about “being lucky” when I had two new Continental tyres fitted for under half price on the Oldsmobile.
I need to go back and highlight to him how karma really works.
There are no invoices, receipts or lists of debt in Karmas world.
