Campbell Hausfeld VT0403
JasonB.
North Alabama
My compressor recently ran away due to a blown hose that was left connected until the pressure switch overheated and threw the breaker. When I started it back up, it built pressure but it was pressurizing the crank case. Here are some pictures from the teardown. I'm not sure where I should be focused. 1000010483.jpg1000010475.jpg1000010474.jpg1000010473.jpg1000010472.jpg
5ubtle
Spartanburg, SC
Here is a similar thread:
Air in the crankcase comes past leaking rings. Some air in the crankcase is OK. How much air is coming out of the breather (i.e. is it really a problem)?
I'll call some other members who are interested in this sort of thing:
@GeoBruin @micromind @Jswain
kams1973
Amarillo, TX
Air compressor pump crankcases normally breath. Same question asked above, how much air is coming out of the breather?
J
JasonB.
North Alabama
Thanks for the link. It pressurized the crankcase enough that the top of the dipstick breather blew off. So, it made me think too much. I suspected rings, but it really didn't seem too bad when I tore it down. I did notice the torn gasket pointed out by @The Cobbler and I don't think I did that during teardown.
I don't think the valves look too bad. But, I have literally zero experience with this, so I'm hoping some folks with more experience and expertise might chime in.
The Cobbler
it looks to me like the gasket was flopping back & forth with the way the mating surface looks polished .
it wouldn't hurt to clean up the reed valves ( get the carbon off of them) while you have it apart.
the cylinders look decent, you can check the rings for wear by taking them off of the piston and placing them in to the cylinders ( squarely) and measuring the end gap , I suspect they are OK but a check would be wise .
J
JasonB.
North Alabama
So, a light hone and put it back together with a new head gasket? I ordered a head gasket only, just in case. It should be here today.
Beerhippie
Far NE Oregon
Check the head for flatness. You overheated it and blew a head gasket. A warped head is a possibility.
But none of that will cause pressure to build in the case. Check your breather tube--it should never blow the dipstick out.
Jswain
Calgary, AB
New head gasket, clean everything well & give it some fresh oil. Make sure the piston rings are staggered when you install them.
Retorque the head bolts from inside to outside after a few heat cycles. Probably good for 20 years
J
JasonB.
North Alabama
Can anyone point me to a procedure for reinstalling the cylinders on the pistons? I've looked around, but I haven't found anything. Maybe I'm just not hitting the right search terms. What ring compressor should I use, and do I do them one at a time, or both at once? Thanks.
J
JasonB.
North Alabama
I just came across this post while searching.
I think I'm going to give the abs pipe ring compressor a try. I guess I need to block the pistons so that they are sitting at the same height and hopefully the cylinders have enough chamfer at the bottom to start them both at the same time.
