Menard's Display to Bodywork Cart Conversion
SouthernIllinois
I had been sharing bits and pieces of this on my shed / retirement post but I thought I'd put it all together in one post in case anyone found it interesting.
I came across a used, over-the-range microwave display Menard's was selling for $5. I figured I could always use the square tubing for something so I drug it home.
After thinking about it awhile, I decided to turn it into a mobile bodywork cart to be used with my Crusty Corvair project car.
Anyhow, here are the before, during and after pictures of the project.
I am declaring it done for now - I am debating adding hangers for 4.5" grinders but to be honest, I rarely use them - I prefer air cut off saws and die grinders.
A friend that has a bodyshop gave me a Snap-On tool box badge he had, I figured that added at least some value...lol. JK
Be gentle - I am a Submariner and fisherman, not a welder or fabricator.
As it sat at Menards
Wheels going on. 1" angle stock and Menard's wheels
Shelf brackets out of 1/8" angle stock and 1/2" square tubing.
Test fitting shelves. 1" glued edge pine with I forgot how many coats of clear urethane.
Finished product. 1/8" flat expanded metal across the back, vise grip hangers from Etsy and air tool hanger from Mac Tools.
SouthernIllinois
Very nice conversion!
I like that Etsy vise grip rack!
Thanks - FWIW, I ran a #32 rubber band across it to keep the Milwaukee locking pliers in place. With their flat, red thumbscrew on the end they would fall out otherwise.
They work fine with regular vise grips with a round thumbscrew.
Old tool guy
Interesting, i wouldn’t have guessed there were many submarines in southern illinois …
Nice conversion. Only have two thoughts: are the casters large enough to roll easily? They look like urethane wheels on concrete so they are probsbly good. And do you think the base extensions that the casters are mounted to might need braces back to the uprights?
SouthernIllinois
I got as far away from submarines as I could. I spent 25+ years on them, I had my fill.
Time will tell about the casters. It rolls well now of course it is a brand new, sealed concrete floor. They were cheap at Menards and they would be easy to change out if needed.
It is stable and sturdy. The base extensions the wheels are on are welded to the existing horizontal legs and those legs are braced to the upright tubing with welded 16 gauge steel triangles at the base. It doesn't have any flex.
Meames01
Back Yard
Looks great. The only thing I would do differently is to mount my 110V Mig on the bottom shelf and build a tank holder on the back as it already has the offset steel for the casters back there. Nice project.
HogDude
Nebraska
Outstanding project. I would have found another "name" to put on it.
