dwm
I'm moving in March (and currently in a rental), so had to come up with a temporary setup for the compressor.
I built a rolling platform for the compressor so I can move it. Fingers crossed that it's big enough and that the dimensioned drawing I got from IR support is correct with respect to mounting holes. I don't have room for a larger platform, so if it's not stable enough I'll cargo-strap the compressor to the wall. Platform is a piece of .75" birch plywood sandwiched to a piece of .75" oak plywood with wood glue and 28 #12x1.25" wood screws (from the bottom, not seen in pics). Trimmed with .75"x1.5" poplar. Four coats of spar urethane; I don't care what it looks like, only that it's essentially impervious to water. Casters are 4" rated for 400 lbs each; two fixed, two swiveling with brakes. Hole in center is 4.5" diameter, which permits my Parker 06D1NA self-activating drain with room to screw it on (and off when it needs servicing).
1/2"-20 stainless steel hex head cap screws, nylon-insert locknuts, and neoprene-backed stainless washers. 1/2" thick 55A durometer fabric-reinforced neoprene pads to go between the compressor feet and the platform (hopefully reduce vibration transmission to the floor).
Parker 06D1NA drain for tank.
1/2" air hoses (one to compressor, one to hose reel), Polyconn aluminum air manifold with a Prevost safety coupler in one of the 4 ports (other ports are plugged for now), regulator, filter, and black iron drip leg cable-tied to pegboard to make it easy to take with me in March.
I can't wait for the compressor to arrive. Fingers crossed that the liftgate driver will help me get it from the pallet to my rolling platform.
