The technique may have been lest then absolutely perfect, obviously had the rotation in the wrong direction if the kickback came at me as someone has pointed out, but it was not sloppy or careless, there was no side pressure, piece was very well secured, wasn’t rocking grinder across the surface, didn’t have the disc buried in the cut, it was on the surface, didn’t go straight down on the vertical leg, stayed on the outside and will admit if technique was absolutely perfect the kickback might not have happened. But as of right now, I firmly believe, that if during that very cut I had a top quality disc in that grinder, Walter, Pferd, Lennox, that kickback would not have happened. Might be wrong.While there are cheap grinding/cutting discs out there I find most accidents with grinders are the result of improper use/technique. I’ve had good and bad cutting discs come apart before and it’s always the result me doing something I shouldn’t have.
Did the disc disintegrate then kickback, or did the disc just kickback and disintegrated went it grabbed my pants leg?
Thanks
mjac
