newpain01
Hey everyone!
I had another thread on this forum with questions trying to make a decision what kind of car lift to get for my 2 car residential garage. (link here).
And now that I finally purchased and received the lift, I have a bunch of questions about it.
First, about the unit. I got a Katool X-90E 220V unit. I chose the 220V unit because I have an outlet ready, lower amps and hopefully a stronger pump?
I really feel stoked that I have this half a ton of steel sitting in garage right now, but I have not tried to connect it or use it yet.
The reason is that on the side where the hydraulic hoses are coming out, I have a bunch of tool cabinets stacked up to the wall and do not have space to put that pump/head unit. The factory hydraulic hose that this lift comes with is way too short to permanently install it anywhere in my garage.
I have contacted the manufacturer asking for advice about the type of hose to use for an extension and they replied that they don't recommend extending the hose because they don't know how the lift is going to work with a longer hose. They don't know if that will affect the functionality of the lift due to a pressure drop or a possible strain on the motor. Which tells me that extending the hose might work just fine. I've seen a lot of people extending hoses on the MaxJax lifts, so I am assuming this should be similar?
So the main question is, Can I extend the original hose and if I can, by how much?
My head unit is set at a spot next to my garage entrance and if I run the hose from there under my tool cabinets and into the lift it's around 16ft-18ft. Is that too long? If that is ok, what kind of couplers should I be looking at? I cannot figure out the size and threads on these?
Another option would be to install quick disconnects, wheel the pump cabinet next to the lift, lift a car and set it on the locks, then disconnect and move away. I cannot permanently leave the pump cabinet around the lift due to space constraints, it's just blocking my drawers.
If you have extended the hose from the pump to the lift on one of these units, please let me know. I am also trying to figure out what type of connectors they use as it doesn't seem to be standard?
Photos attached and I really appreciate anyone's input!
