Dan in Pasadena
Pasadena, CA
@Dan in Pasadena had one he used to drag behind his motorhome...😉
My Fiat 500 isn't the Abarth version but I did test drive one when I was considering junking mine (a long story but it was due to my idiocy).
That thing was VERY impressive. Yeah not a real sports car but a very fun pocket rocket. I ultimately chose not to buy it but I'd have been happy having one.
rharman
SoCal
I ordered a thumb for my backhoe for Christmas. When it arrived, the company said they had not received one of the pins that should have been plated. They shipped it with an unplated pin so I could use it until the proper one could be shipped. I received it today, but it had visible machine marks that I could feel on it. I didn't want to mess up the bearing surface of my bucket, so I made a makeshift polishing lathe out of my drill press. The pin was nearly 1" in diameter so I found the closest socket in diameter, then used a 1/2" ratchet bit on the socket which was attached to the drill's chuck. Hit it with 400 grit first, then polished it with 1500 grit. Turned out perfect and only took about 15 minutes.
Back around 1976'ish, I wanted to reprofile the inner cylinder on the forks of my YZ-125 to alter the dampening. No lathe, so I used my drill press as a lathe just like that. Worked surprisingly well. (y)
LanceMc
Texas
Please keep us updated, I have been thinking of the same thing, would appreciate your opinion when you get yours set up.
I will do that. I took all the Tool Box Widget (TBW) stuff out that I bought and installed on Monday. I asked for a return. It's decent enough stuff but it's a little flimsy, seems kinda bulky for smaller sockets, the small and large wrenches don't fit too well, and it's kinda pricey at about $1.67/socket or wrench. The build quality is good and the magnets are strong. The TBW drawer liner is very nice. I turned it upside down so it's an M.
I'm planning on trying out Ernst next. Ernst isn't cheap either at about $200 for just the sockets.
LanceMc
Texas
You're cutting grass. I'm wasting fuel while waiting for the sheath of ice to melt off my windows so I can go home.
Same planet?
Yeah I think so. The grass isn't actually growing though. It's tall native grasses that are dormant. I cut it once a year so that the wildflowers are visible in the spring. I'd prefer a prescribed burn but that takes too much coordination and the neighbors would probably come apart at the seams.
niget2002
Josephine, TX
My wife had the turbo version. It wasn't the Abarth, but still had a surprising amount of power for its weight. I really enjoyed driving it.
Sadly, we had to get rid of it when the kids literally outgrew it.
kaymccampbell
Upstate New York
Same planet?
Timm, they make "frost guard" covers for windshields and they work great - I'm kicking myself for leaving mine up at hunting camp last fall... :withstupi
I've got one of those vinyl shields for my car. We all do. They're the nuts. Judy's unwilling to spend the 30 seconds to put hers on, but not to spend half an hour trying to clear her windshield. :dunno:
I find it's fun to watch her struggle.:evil:
WisJim
Menomonie, WI
Before we had a garage for the car in winter, I always saved a piece of cardboard to put over the windshield until one of the boys bought me an actual made-for-the-purpose windshield cover. The cardboard worked well and usually one piece lasted the season.
Jeff Ivers
Oklahoma
They're handy for removing supports, cutting parts off sprues, and trimming the back of circuit boards, among other things. And they disappear faster than 10mm sockets. I'll distribute them to all the different tool kits, and by Xmas they'll be mostly missing. At least they're cheap.
I have often seen on here threads about missing 10 mm sockets or a mention of the same in another thread. Lowes is listening!! I was in the local store the other day looking for a socket and discovered a 10 piece 10mm socket set - 1/4 drive, 3/8 drive, 1/2 drive, regular, deep, impact - their set has you covered. Just thought I should post this PSA.
Beerhippie
Far NE Oregon
I've tried using a tarp on my old Vanagon windshield (apprx 1.5 acre). The windshield would frost over in the first few hundred yards of driving. The old Van took about five miles of driving to get any heat at all. The new Van seems to warm up much faster with the EJ 25 in it.
I'll give the windshield cover a try again, as I'm really wasting fuel warming up for five-ten minutes each morning and evening.
Snow, yes. Ice? No way.
They also sell 12V heater defrosters, many under $20. that should shorten up the "warm up" period?
this one may be a better lower profile?
Beerhippie
Far NE Oregon
I park close enough to the cabin I can run an xcord out for a 120V heater. I used to do that with the Van on really cold mornings.
What bugs me is that the early morning sun used to shine straight onto the windshield of the rig. By this time of year, the sun was rising early enough to mostly defrost the windows by the time I leave. Then the neighbors to the SE of me planted a row of Ponderosa pine. The largest one has now grown to the point it completely shades my parking spot until about ten AM. Sometimes I fondle my chainsaw when I see the shadow across the rig in the morning. They couldn't have just planted Larch, could they?
I guess I've been living in the same place for a while now....
Nofries
Charlotte Area
Beerhippie
Far NE Oregon
I installed the new 3 bbl fermenter in the fermenter hall today. Some fiddle-fartin' around getting the little fellow transferred from the wood pallet it arrived on to a plastic pallet--which we'll be leaving it on, as it's missing the leveling pads and it'll be easier to level the pallet than the footless legs. Used a couple 3' pieces of 4X4 as the legs were just the perfect spacing to not allow a pallet jack or forklift forks to fit in between.
That did the job. Used a pallet jack to get it into the ferm hall and placed where we wanted it.
Now I need to plumb it in and make up a temp controller for it. I'm pretty sure there's a spare Johnson A419 out in the container....
Yep. But it was last used in the kitchen and the kitchen staff can be rough on things.
That will be difficult to render drip-proof. I also had a couple of 24V A419s, but no 24 V power supply and no 24V coils for the Asco Red Hat solenoid I wanted to use.
Brain transplant time!
The operation was a success.
The brains from the case donor:
Installed:
Ooh! Look at the cute bebe fermenter!
Jgaz
Installed:
They might as well turn off the lights when you retire.
That place won’t last 6 weeks
LanceMc
Texas
Worked on some more organization of the mess of tools I have. Impact sockets and bits today. These Craftsman V-Series magnetic socket holders are nice but I need more of the little plastic thingamabobs that slide into the extrusion and hold the socket. Maybe I can find someone with a 3D printer that can make some. Maybe someone already has.
Josh Dekubber
Bothell Washington, Peoria Arizona
Recently finished restoration on my Warm Morning Broilmaster G2000D from the early 1970s. My second oldest grill. Also added a flip up table for the front similar looking to the fixed version they came with back then. I used IPE Ironwood (Brazilian Walnut) that I have been liking to use on my restorations lately. This old grill was originally built like a tank and built to last as a lot of things use to be. The original heavy cast iron burners and all the grates were in great shape and just needed to be cleaned up. I found new temp gages that were almost identical and converted it from NG to LP. Also switched out the old lava rock for ceramic tiles. It's ready to go another 50+years
Screenshot_20260115_172538_Photos.jpgScreenshot_20260115_172526_Photos.jpgScreenshot_20260115_172507_Photos.jpgScreenshot_20260115_172607_Photos.jpgScreenshot_20260115_173300_Photos.jpgScreenshot_20260115_172916_Photos.jpgScreenshot_20260115_172813_Photos.jpgScreenshot_20260115_172640_Photos.jpg
SMOKEYBEAR
Yesterday, worked on an idea for new power for my drill press. New switch arrived, used a scrap piece of aluminum which will be replaced by one of the proper size to get an idea of my plan. New Baldor 1/2 HP motor is scheduled to be delivered Saturday. I'm going to do a full mock up/ fit before I paint the drill press pieces. I expect the motor to mount to the aluminum plate with counter sunk fasteners and the plate through bolted for the motor mount on the two pins. I believe it will take two sets of fasteners to complete the solution. Motor to plate, plate to mounting bracket.
The modern switch/ plate idea I borrowed from a member that posted their version, can't find the post currently or I'd give them credit.
bmwrd0
Beaver Fever Oregon
Spent the AM shop time getting my electrical connector box set up right: got rid of all the stupid blue, red, and yellow plastic sleaved crimp on stuff, which never really works, and replaced it all with good, solder/crimp connecters, with a good crimper and shrink tubing included.
Spent the evening time in air gun shooting, chewing a couple things over.
Beerhippie
Far NE Oregon
No 5h1t. @Beerhippie is there anyone there you can mentor so they can keep going after you move on?
I've tried. All they need to learn is carpentry, construction, design, welding, simple machining, electrical, electronics, brewing theory, high work, rigging, jury rigging....
Hasn't worked out yet.
