Says the man guilty as anyone here for influencing others into tool purchases.I need to quit hanging out with ya'll on this forum........
Can't wait to see the first use of your new tool!
Looks like you got a nice cleaner.
Enjoy the ulrasonic, says the guy who just ordered fluid film-i believe what does around comes around........
Anyways, not wanting to throw a ton of $$ at this, I found a shifter from a Chevy Malibu at a local scrapyard last summer that had a toggle button on the shifter knob and I played around with that a few months back but just wasn't pleased with the looks of the knob and boot with the Jeep shifter as it looked kind of hodge podge although I was able to get the buttons to work after removing the small circuit board inside. That being said, I prefer the OEM appearance in daily drivers as much as possible and more important, the functionality so I really didn't want to have something that was hideous to look at or something the wife would have to think about too much to drive. I like the fact that although our Jeep is completely custom in terms of powertrain to chassis/body, it is however, as OEM in functionality as I can make it and I'd like to keep it that way. To the untrained eye it just looks like every other Jeep JKUR on 37's.
Mike, you are going to love the ultrasonic.
I’ve had the larger one for a while now and it’s been a work horse. These all seem to be made by the same outfit and rebranded. My bearing supplier just gave me the small unit. I was always under the impression that you shouldn’t put bearings in an ultrasonic, but they assured me that they recommend it for their ceramic bearings and Sprague clutches prior to regressing. So the usage range for these just increased for me. For larger parts I just use water with a healthy pour of purple degreaser. For the bearings I just use straight aircraft grade simple green and it’s amazing how well it works.
We are just getting you back for all the stuff we have had to buy because you show us what we need.
Interesting idea. But since this was done, there is total silence from the hitch area, at least as far as our experience goes. Inside the SUV cabin heading out for our fishing trip is a whole nuther thing! Yap yap yap yap yap yap yip yap.......
Neat project Mike. It's those little things like this that make guys like us happy. My wife is the same way, "why do you need to do anything to it, it's working the way it is". Because I want it a different way and also because I'm not sure it will work but I think I can get it to work and really want to see if I actually can. LOL. I can't think of any examples off the top of my head but when you mentioned your wife saying that it brought back memories of very similar situations. But usually after it's done and I show her she will see and understand why I wanted it different.
You know you would miss us….
You know you would miss us….![]()
Nice update to the shifter Mike!
Your shifter project is pretty interesting to me. I have a 2011 jeep grand cherokee with the v6 and it has the same shifter your putting in. I wish the manual shifting worked the way yours will.
I'm sure it's all in the way the transmission module is programmed but on mine when you bump it down it goes to first gear no matter what gear you were in previously. I only use it when I'm pulling something and just put it in four before taking off to keep it out of overdrive. I wish I could shift it down going down the road.
I'm going to stop pulling with it anyhow. The transmission has started leaking fluid when I pull with it and the shift solenoids are starting to hang up every now and then.
Looks like you've got yours figured out. Nice job!!!
That is a great OEM+ mod on the shifter, Mike! I really like that it is from a very similar generation vehicle, I've never been a fan of mixing much newer tech into older cars, I also prefer the period correct upgrades.
Mike, I have to join the chorus of congratulations. This kind of thing, while well outside my skill set, does tickle that "Oh, that's neat. Well done!" nerve in me.
The thing is, I'm the one with the good hearing. The other three are constantly saying "What?" Should I be rude and put earbuds in?Have you thought about going deaf? I mean just enough you can’t hear without hearing aids I mean.
Well, I turn “my hearing aids off” and blame it on the wind noise and it’s over stimulating me. But in reality I switched to Bluetooth and start listening to Spotify with background noise off. Your results from said actions will vary.The thing is, I'm the one with the good hearing. The other three are constantly saying "What?" Should I be rude and put earbuds in?
Mike,
I assume Mike will agree with this. Transfer case in neutral, ****** in park. Otherwise, the parasitic drag will destroy the ******. Ask how I know - my company had what we called our Extreme Tailgaiting Vehicle with a matching Jeep for a toad. First trip out, they blew the transmission by leaving it in neutral while flat towing.Mike, when you flat tow the Jeep, do you just put the transfer case in neutral? Transmission neutral as well?
I just read a crazy long detailed post about a shifter and I was enthralled by it more than any book I've ever read.......
Always impressive! The tech side of the electronics is well out of my realm, but I can definitely appreciate the thought that went into making all of this work.
Mike,
10L or 15L model?
I have been window shopping one for a couple years now. For my use case it will be for small engine caburetors/atv and motorcycle carbs.
Thanks.
