Show your new tool arrivals
kyrbz
midwest US
I see these cleanable/reversing magnetic hex drivers being sold under many different brand names, but I'm assuming one manufacturer is private labeling them for different companies. I picked up a couple of the Malco version from Epsteins. I like the 4" length. Not too short, not too long. Seems like a good idea based on most of my hex drivers are full of metal crud or the magnets fall out. So far I'm digging them!
Beerhippie
Far NE Oregon
Thank you so much for spending my money--I've got to have a set of those. They'd cover about 90% of my SAE nut driver needs--and all of mine are also filled with metal dross.
Come to think of it, those can go on the company card....
Skyman
Central Maryland
I usually spray a little WD-40 into the joint of all of the new pliers I get and work it. It helps quite a bit, the joint will ooze black.
I will try some additional lube on it, but the joint isn't dry - it was lubed at the factory. I've been working it back and forth, and it's still oozing that factory lube. The trouble is that the joint isn't perfectly circular, thus the notchiness. It's disappointing, considering the cost, and the reputation of Knipex.
LXCam
Tools-consumables-I’ll let you guys decide.
Had a little project this week i needed to do since I didn’t trust my guys pulling it off without a major problem.
I needed to cut in a half dozen intercoms into a 1/8” wall steel column that is grouted with 5000psi er/um grout. Then drill n tap for the mounting screws. So I made sure to have plenty of consumables for such a task. As luck would have it, I didn’t need to get into this emergency stash 🤣
And a very nice Christmas gift from my inside salesman at graingers.
moemc
I still love the brand, but I found that the further astray you go from their halos that get all the exposure, you start finding tools that are not constructed with the same attention to detail. There are a few Knipex items I ended up returning because I didnt find them worth the price.
W-Cummins
Iowa
Snap On CTS561CHUCK on a blank handle SDD5R1R (1/4" hole drilled out to a letter K size). 2 part epoxy from Harbor Freight was used. Stuff works great for $3 or whatever it is.
How is the quality of the chuck? There is a place for it in my screwdriver set, and I was thinking about getting one, but it has the hex drill bits in it.
d.mcfarland
Western PA
High quality. There was a similar option on Amazon for one made by NEIKO (part number: 20753A) that is probably VERY similar. Currently $8 instead of $30+ for the Snap On if you want to start with a cheaper alternative.
KnurledNut
n/a
I've had mine for over a decade and with light use, I have not had any issues. It probably wouldn't handle hard use well. I've never used it in an impact driver, just hand use.
Mine mainly gets used with an interchangeable custom handle driver I made a long time ago for use with various sized long hex bits.
Steel_Rain
I couldn’t pass on the 30% off on the Icon Hammers:
I also had $50 HF cash, so I bought a few more of the rare as hens teeth mag mats and the SO knock off long reach slip joints.
Maddox stuff was 35% so I bought a few things:
terrific
Mine mainly gets used with an interchangeable custom handle driver I made a long time ago for use with various sized long hex bits. I've shown it here in the past.
I had that exact idea earlier this week and was looking for options. Interestingly, McMaster found a US-based company that makes square drive chucks. I was planning to put one on a spinner handle. Unfortunately, they don't sell a 1/4", and they don't list the diameter of the tool. It's also an impact tool, so I'm not sure if it would stand up to sustained torque, especially with moving parts. https://www.mcmaster.com/products/chuck-adapters/
I'm not sure if it's Apex behind these.
Probably, the Snap-On is the better bet anyway, because it's at least the right size.
Beerhippie
Far NE Oregon
The set @kyrbz shows above have one 9/32, which I'd rarely if ever need. Almost all the sets I found at the Jungle had the 1/4 and 3/8 paired with 5/16. I don't need two 5/16, but 7/16 is handy.
BTW: The two-bit set--four sizes--was about the same price as 4 discrete bits in those sizes--and easily cleanable.
kyrbz
midwest US
Actually the set I posted has one that is 1/4” & 5/16” and the other is 5/16” & 3/8”. I wish they didn’t overlap the 5/16” but that’s the way the individual bits in this style come. They also have a 7 in 1 set where the sizes don’t overlap. I’m not crazy about the way the 7 in 1 set works. Not as convenient as the individual bits, but it has more sizes.
Steel_Rain
I did not know HF had added a cordless hot stapler to their lineup. I am now forced to pick this up. :geek:
Hmmm. I think this would work to repair the front plastic air dam thing under the front bumper and tailgate top protector on my RAM 1500. Good excuse to go to HF anyway.
Full disclosure, while it’s a decent kit, it’s not worth $100 bucks, but it’s worth $60-70 on some type of sale price like this. It’s NOT type C, it’s micro, so that’s disappointing. That said, it heats up very quickly and works well.
I used it last night to fix a plastic panel on my son’s sled and I’m happy with it.
The other I would consider would be the Astro tools version:
That said Lance, you should still go to Harbor Freight (evil laugh). 🤣
LXCam
A refreshing of the unibit box n bits
And I bought the Klein square. Even though some of the info and predetermined set points look real handy for layout the fact is the ruler is only held in by a magnetic. You can’t lock it down, I got a feeling this isn’t going to fly for me.
But one thing did crack me up, the ruler only has hash marks to the 16th. Granted that’s fine for this trade, but it just doesn’t set right with me.
If you want a little chuckle, check out the vid (the box is backasswards).
willf650
Only one of these I actually needed, two I kinda could use but live without and one was an absolute frivolous purchase. You can guess which is which.
I already have one of these and they are decent. I had another brand plastic case start shattering due to the cold so looked to get another. It was $24.** for one at Home Depot and $31.** for two from Home Depot delivered next day. There was also another listing at on their site two for $49.** shipped. Their pricing structure is strange.
Wera gets the award for product packaging. They must be watching Apple with the iPhone.
This is a super specialty tip but if you need it you need it. It's a combo pozi drive/flat head. Hope you never need it but they do make it If required. It’s mainly an electrical thing with European style terminals on relays and contractors.
I got the new Milwaukee lock nut wrench set. I will test them tommorow. All others I've had are bad but these are slightly different.
And someone posted these and they are truly the most beautiful pliers of any type I have.
Motorman55
South Jersey
VEVOR Precision Table Saw Miter Gauge arrived today.
Its all metal (aluminum) with the exception of the two plastic knobs and the flip down stop. Once I had it assembled I checked it for 90o square and its dead on. I'll check the other angles once its mounted in the table saw. The fence has the micro adjustment ability and the fence itself expands to a little over 35". The white nunbers and lines are easily readable against the black body. Definitely my new favorite color combo for all measuring tools. Very satisfied with my purchase. It'll make a nice addition to the new SKIL table saw. 1768776998252.jpeg1768776922711.jpeg1768776853105.jpeg
willf650
I looked at the Klein square and opted for another empire due to that magnet.
swsman
Earthbound
No pictures, but I added Tsunoda chain pliers (vertical and horizontal version), and yesterday picked up a 1/4" flex head ratchet from HF (Pittsburgh Pro line).
Ratchet works very smooth, already used it earlier today fiddling around the F250.
Had Capri 1/4 flex head prior to this one, backdrag was very bad - ended up tossing it into trash.
Pliers will get some use for bicycles/motorcycles maintenance this summer.
I have slowed down quite a bit with tool acquisition - blasphemy I know.
