Straight cuts in bar stock
RickP330
Middle Island, NY
Hi guys,
I'm working on a project and it's getting ridiculous. I don't often do this, but I have to cut a 1" x 1/4" CRS bar into lengths. This is just a mechanics shop, not a production facility and I've tried an air saw, cut off wheel, hacksaw ect. It gets the job done but no two pieces are the same and it's really frustrating me. I can't even figure out a way to square it all up once I'm done. I only have a dozen or so cuts to make.
Do you guys have any hacks with simple mechanics tools to make production style cuts? Yeah, a cold saw would be great but space and limited need for one is a problem....
Rick
Wamsutta
Amarillo, Texas
Circular saw with a metal cutting blade will get you pretty square if you scribe a line.
You're going to want the bar stock fully secured in a vise or clamped down to a table.
Eye protection is mandatory in this case. Face protection would be good too.
MOS3522
Colorado
Used to do it with a portaband and a cutting arm rig, but it was never straight enough. I ended up buying a cold cut saw.
R
RickP330
Middle Island, NY
Mark the cut square, cut it (hacksaw, grinder, bandsaw).
Use belt sander and guide to square up and get it right to length.
If you scibe a line you can get pretty dead nuts this way
Yeah, belt sander is it. Mine died a long time ago, maybe time to fix that....
Swag table, HF saw, 1.25" bar. pretty straight.
Damm, that's awesome....
strength_and_power
Is this a one time thing or going to be a project that keeps coming up?
What kind of tolerances are you trying to hold? A straight cut isn’t going to mean much of the surface you are building on is best to hell and not flat.
Got any friends with a band saw that like beer?
Hannahranga
HF has a 2" baby chop saw, tbh I'd find space to stash a full sized chop saw but also I'd probably use it more than you.
LopezBart
Lopez Island, WA
A carbide scriber, vice, hacksaw and a good file will allow you to get pretty close (+/. 005) easily. Obviously, a belt sander, band saw, etc. will speed the work, but this can be done quite satisfactorily w/ simple hand tools and a modicum of care.
R
RickP330
Middle Island, NY
I'm looking for a solution that does not require purchasing new tools, but that never really works out, does it?
What I really need to consider which tool if I add one is most versatile for other jobs as well. I usually farm out my metal work, but this job is so small it's a shame to waste favors on it - and I probably need a little more versatility in the shop.
Space is at a premium for me, and the work is mostly automotive related. No tolerance, I just want it look professional and not like a child with a hacksaw. So it seems like:
* Some kind of 4" belt sander or the like.
* Portable band saw with a table.
* Small chop saw.
Any other ideas and which might be the versatile? I'm leaning towards the belt sander....
Much Thanks, Rick
PCustoms
VT
* Small chop saw.
Much Thanks, Rick
What are you using these pieces for and how many do you need to cut?
K13
St. Albert, AB Canada
I can't imagine not being able to cut 1' x 1/4" bar stock to a pretty accurate length with any of the tools you listed. At least to the point that a quick file job wouldn't clean them up. It sounds like either a issue with how you are marking them or just practice needed in using the tools. Are you scribing the cut lines or marking them with something like a sharpie where you have a line that is 1/8" wide?
R
RickP330
Middle Island, NY
I am building a spot-welding cart. The carry all is done and now I have added a platform and foot switch operation option. These parts are for the foot switch. I had all of the parts laser-cut and CNC bent, but I forgot two parts for a linkage. Next to the laser cut parts I just need something nicer than what I can do by hand. Plus, I need a dozen or so parts for a test fixture I am working on. This thing is already taking up a lot of real-estate in my shop, but I have a lot of work planned for it....
no704
Jigsaw with a good blade is what I would probably use if i had to do it with hand held tools.
PCustoms
VT
So you need two pieces and then never again?
Sharply mark it (hell a razor blade will mark it), Cutoff wheel proud of the like then a grinder to work your way to the line.
Sounds like a technique and not a tool issue...
alfadan
Augusta, ks
That's the nice thing about a hacksaw. You go slowly enough to see if you're veering off. Don't shove your whole body into it like you're John Henry trying to beat a steam engine, and let the saw do the work.
R
RickP330
Middle Island, NY
Seriously? You guys are supposed to talk me into spending massive amounts of money on tools - what's going on here?
RP
PCustoms
VT
RP
Idk, I would have wanted the job done this morning so would have used what I had available.
But
A Bridgeport would work
Best option would definitely be a laser table. You already paid someone else to laser parts for you? You should be ashamed
Beerhippie
Far NE Oregon
There's a trick to making a nice, square cut with an angle grinder and cut-off wheel: Scribe your line using a good square. Now carefully make a few very light passes on the off-cut side of the line with the cut-off wheel to establish a groove. Now the wheel will want to follow the groove as you finish the cut.
You'll be staring straight down the cut-off wheel while you do this, so wear a full-face mask--and a good one--and safety glasses/goggles. I'd advise a good, heavy jacket with the collar buttoned up. I use my welding jacket. Pulling pieces of cut-off wheel out of body parts is a PITA.
Keep in mind that having the sparks coming back at you means the angle grinder will kick away from you in case of a bind. Best advise I ever had about using an angle grinder. It's counter-intuitive to have the stream of sparks shooting right back at you, but it beats hell out of kick-back injuries.
I do this when I need a fast, straight cut and don't want to set up for and clean after up a guided plasma cut.
drmarkr
Tucson
RP
Since you asked, and since you're a legitimate member of this forum, get in gear and pick up a horizontal bandsaw, a portable M18 or M12 bandsaw, a 12-in disc/ 6-in belt grinder, a set of proper squares, and get after it!
You're welcome.
R
RickP330
Middle Island, NY
You're welcome.
Thank you! That's what I'm talking about!
RP
The Cobbler
maybe practice with an angle grinder & cut off wheels?
even if you cut it long, you should be able to scribe some square lines and grind up to them , sufficient for what you're building .
clamp the 2 pcs together while grinding & they will end up the same length ( within reason)
some years ago I bought a miter base for angle grinders , thought it was the cats *** at the time. in hindsight I very seldom use it .
zimman
Mark Twain National Forest
File? What is this file thing you speak of? LOL
I was going to start a thread and talk about why folks use all these electric and battery tools instead of a file.
Zim
R
RickP330
Middle Island, NY
Good to see you knocked it out
Now go grab a handheld bandsaw for next time
Yeah - Job is done and it came out very nice. Hand hacksaw and file with a angle iron straight edge. What did we learn? I need the following:
Milwaukee 6232-21 Deep Cut Portable Band Saw $430
JET Benchtop 6" x 48" Belt & 12" Disc Sander, 1-1/2 HP, 115/230V 1Ph (JSG-6DC) $1,870
Swag Table with foot switch and Miter gauge $270
Total = 😭
tarbellb
Oregon
Total = 😭
Ha yeah goals right. Learning to do it the harder manual way is always a good lesson, makes you appreciate the quicker or more accurate way later in life
If it was my money.....
HF corded deep cut band saw $100
DIY steel top $20
eBay foot pedal $ 25
HF 12" disc grinder $200
HF Hercules 2x48 Belt $300
ps. that JET combo sander has a lot of plastic parts, I would look other options
