Ceiling fan need physical switch?
jpcjguy
Richmond, VA
Hi all,
I am wiring my screen porch. We will have a single ceiling fan without a light. Does it need to have a physical switch by code?
I currently have a three gang box and will change that to a four gang that will have four independent lights (dining area lights, sitting area lights, flood lights, detached garage lights)
This is an existing switch panel in the house so I would have to cut it out and install an old work four gang.
It would be awesome if I don’t have to have the fan on a physical switch. I feel like most of them are remote controlled anyway.
I have not seen five gang old work boxes and since this is next to the door, I am not sure there is even space between the studs!
Bert_
NW Iowa
I always put the light on a switch, but you don't have to. I wire the fan to constant hot and just use the chain to control it.
I made sure any fan that I buy did NOT have a remote. I have removed and thrown away a few remote / receiver modules for customers.
mm08822
If it were the only light in a room, then it needs to be switched. You could also have a switched receptacle for a table/floor lamp.
I always run a 3-wire cable to any ceiling outlet, even if 1 conductor becomes a spare based on customer's purchase.
whateg01
doo dah, kansas, usa
For clarity for those who don't know... 3 plus ground
J
jpcjguy
Richmond, VA
It is a screen porch and there will be two areas with 4-6 gimbal lights each on their own switch. Fan will be stand alone with no light.
J
jpcjguy
Richmond, VA
Larry4406 - have to ask why the sad emoji on that switch? I have three of them in my detached garage for almost six years with a bunch of LED lights and working perfectly.
mm08822
Planning on remote control. my main question is if code requires a switch?
I plan to use the same brand new circuit I am running for the lights.
Code only discusses lighting for safety and you are already covered with that otherwise. So you are good with the remote only for the fan. (I'd still run a 3-wire.)
larry4406
Northern Virginia
The sad emoji was because my suggestion was negated by your desire to use slide dimmers. So, my suggestion of a stacked switch was not useful.
My house in the garage, I have (2) 2-gang boxes vertically stacked. Framing would not permit a 3-gang or 4-gang box. I’ve had to do this in new construction as well due framing limitations.
J
jpcjguy
Richmond, VA
My house in the garage, I have (2) 2-gang boxes vertically stacked. Framing would not permit a 3-gang or 4-gang box. I’ve had to go this in new construction as well due framing limitations.
Ah! Sorry - thought the sad emoji was because you had bad experience with these. I totally forgot about the stacked though, so your idea might be used elsewhere! 😃
sparky 1971
Central Iowa
Get a fan with pullchains and add an aftermarket remote. That way, when the remote fails, you can throw the remote away and either replace it or run the fan the old fashioned way. Fans that are remote controlled only are fine until they don't work.
Dig Doug
I have 3 ceiling fans in the garage tied to 1 remote control and they are All on high
the remote has a little holster and it’s next to the surface mounted light switch …
ripperd
Twin Cities, MN
That is essentially our screenporch config. 4 puck leds on a physical dimmer and outside the circle of the fan to prevent strobing. I hardwired the fan to always on power and the inspector didnt say anything. We use the remote 100% of the time for fan control. Although it does have a pull cord in case we cant find the remote.
