VISE REPAIR 101 all vise repairs, lubricants, sources for parts and the tricks to fix
Palantir
Newb question number 2:
Hope this is not posted in the wrong section. According to all I found on Reed there should be a 4 digit stamp on the left side of the dynamic jaw, where the screw gets in.
I have two stamps there- one sloppier and uneven 123 and another much nicer 425
What is the year my vise was made?
7.3444
Hey guys where would be the correct thread to ask questions about a odd date code on a old Wilton bullet vise?
Mintgrun
Kingston, Wa.
EDIT-- I just saw your posts in that thread and the suggestion that you try the main Vise thread. Here is a link to that one.
fishwatcher
Well.. my good neighbor said, no charge. Here it is with a little polishing on my part after he machined the jaw and anvil surfaces. IMG_1964.jpegIMG_1965.jpegIMG_1962.jpeg
In July 2025, I posted about getting my Wilton C0 jaws machined flat at the top. Before the modification, the jaw tops sat uneven in the vise and were pretty well worn. 1771224415292.png
My machinist neighbor did the work and the results were great (plenty good for me. there are some circular machine swirls I haven’t polished out.. and probably won’t). See the results in the post I quoted above.
I’ve since explored a few additional ways to get new jaw surfaces (not just the top).
I tried two different options from terrific garagejournal.com sources for vise jaws.
Recently, I sent in my worn original jaws to Kendrick Logan and had him resurface the toothy part of the jaws. They came out really nice! These serrations look good and are aggressive. He didn’t touch the rest of the jaws, except to remove burrs from the edges, and maybe give it a little extra polish.IMG_5294.jpeg
This is how they looked before the resurface.
I also ordered replacement jaws from Nick Carava (@autopts on eBay) and they look really really great on their own. All surfaces are smooth and edges are chamfered. They came with a flattened points surface, which should make them less damaging to any soft parts that are being squeezed.
You can see these placed on top of the resurfaced ones here. They are a little beefier than my originals, which is also nice.
IMG_5312.jpegMy vise makes these sit unevenly at the top.. which is why I got my machined top jaws resurfaced.
Apologies for not knowing the proper vise terminology. I’d be happy to learn the correct terms.
Thanks for reading!
AntiqueVises
Sadieville, KY
In July 2025, I posted about getting my Wilton C0 jaws machined flat at the top. Before the modification, the jaw tops sat uneven in the vise and were pretty banged up. 1771224415292.png
My neighbor did the work and the results were great (plenty good for me. there are some circular machine swirls I haven’t polished out.. and probably won’t). See the results in the post I quoted above.
I also ordered replacement jaws from Nick Carava (autopts on eBay) and they look really great. They came with a flattened points
Thanks for reading!
I also ordered replacement jaws from Nick Carava (autopts on eBay) and they look really great. They came with a flattened points surface, which should make them slightly easier on whatever parts are being squeezed.
IMG_5312.jpegMy vise makes these sit unevenly at the top.. which is why I went to get my machined top jaws resurfaced.
Thanks for reading!
The vise looks great, thank you for the business! I often prefer the look of them with the factory worn jaws after resurfacing compared to brand new ones.
drs3317
Western Maryland
I'm restoring a Craftsman 5196 that has seen better days. It came to me apart and is missing the center swivel bolt. I am sure no one has one to sell so I am hoping someone at least can give me the dimensions of the bolt so I can make one. Thanks.
Danny
If no one pops up with the dimensions, a pair of calipers and a thread pitch gage can tell you all you need to know, if you have the rest of the vise.
Danny
You can make a decent swivel center bolt with a bolt, a larger washer, and a bushing, a lot easier than making one from scratch.
drs3317
Western Maryland
Thanks guys for all the ideas. I was also thinking of making the bolt. However, since the threads are messed up I cannot get a good reading with my thread gauge. It seems to be a 13/16-14 tph but just not sure because the whole looks to be a lottle oversized and the threads in bad shape from rust and maybe somewhat stripped. If I knew for sure I would buy a tap and try to clean them up. I may just go oversize with a 7/8" which may make more since because I will have to buy the tap and if the 13/16" doesn't clean it up I would still have to then buy the &/8" tap.
Midwest Shop Supply
Northern Illinois
Here is a new product we have begun manufacturing, this is a pair of Pipe Jaws that will fit the early Wilton C1 bench vises that uses the two pin mounting system. We are also in the process of manufacturing the two pin mounting style Pipe Jaws for the early Wilton C2 bench vises as well, and pictures will follow soon. Let me know if you are looking for a pair of either style!
hose dragger
West Virginia
Thanks in advance for any advice I can get. My FIL passed away and we are sorting through his estate. He was a mechanic so there are several vintage tools he had in storage. I am completely ignorant about vises. I will attempt to post pictures of the made in England Record No. 6 he used at his business. Options I’m considering are: selling as is in the estate sale, doing a rehab on it and giving it to my son (it was his grand dad’s) he would use it so it wouldn’t need to be beautiful just functional. I’m pretty handy and like to work on things so not intimidated by working on it. Obviously it needs new jaws and the handle is bent but otherwise it seems to function fine. Appreciate any direction.
ALLFAST
I’m 99.9% sure that the modern Irwin vise jaw inserts commonly available on EB fit the Paramo/Record vise, and I’m pretty certain that Autopts on our forum has them in his EB store!
Keep this vise in the family !
zanyad
NE Ohio
Keep it! I’m sure your boy would love it. I know I would if I got that from my dad via gramps.
Another vote to keep it!
One of my uncles grabbed the vises off my grandfather's workbench after he passed last year. I'd love to have one.
