Honda Generator Surging Under load only
Razorhunter
Honda EM5000S generator in seemingly excellent condition, and has good fuel, air filter, spark plug. Generator does not surge at idle. Only surges under a load, and it's not always a consistent surge, meaning it will fluctuate slightly, and come and go. I can hold my hand on the governor arm/linkage assembly and somewhat stop the surging to a degree.
Is this typically indicative of a dirty carb and if so, what's the chances I can go in and handle the issue and back out, without spare gaskets/seals/etc?
This is a GX340 engine.
Also, what's the chances this is just the governor springs/arms up top? Is there a possibility that this is just the springs or arms out of adjustment, or is this always a lack of fuel, or too much air issue? What's the chances this is one of the "hidden" screen/filters these Honda engineers seemingly put somewhere within the fuel line I read about? My fuel sediment bowl was clean as a whistle. I have not found the other screen I keep reading about. I'll have to do more digging on parts diagrams to find this screen that should be checked for cleaning. Possibly it's above the fuel shut off valve in the tank bung?
I have honestly never messed with these carbs or had problems in almost 50yrs of being alive. Many a chainsaw carb issue, but never a 4 cycle carb issue to speak of. Guess I've been blessed.
ETA: Can someone confirm that the phillips adjustment screw on the governor linkage directly above carb is strictly for the idle adjustment zone? I read that somewhere this is the case, but I honestly don't know what that phillips screw adjusts, but it's definitely tied in with the governor linkage. NOTE I am NOT talking about the actual governor shaft that has the wrenching flat and the 10mm locknut on it, which is over under the fuel tank about 8"-10" away. This phillips screw adjustment to governor linkage is directly over the carb.
Thanks for any help. Honestly never had this issue before, but the minute I go and buy a used generator, it was bound to happen at some point, so all is well.
Steve_P
Agree that this is a typical indicator of a carburetor issue, usually a partially clogged jet or drilled passage. This is extremely common on snowblowers that still have last year's gas in it.
mm08822
It could be a dirty carb with simply a piece of small debris partially blocking the port controlled by the float. Drop the bowl and inspect.
Also note if debris in the fuel drained from the bowl.
Check the fuel filter and look for **** in the bottom of the tank.
Afterwards run carb cleaner in the gas.
Always run engine dry before putting away. I run mine dry with fuel containing stabilizer.
Steel_Rain
I’m pretty certain the GX motors all use the “in hose” inline filter at the bottom of the tank. Take the fuel line off the base of the fuel tank and you will see a 2” filter inside the fuel line. Obviously make sure that’s clear.
Before you do any of that, let it run without a load spray carb or brake cleaner around the carb/intake to see if the engine speed changes. You could have an air intake leak, exposed when under load.
Other items to check are the carb bowl, make sure the bottom screw is tight (not over tight).
Have you made any adjustments to the mixture screw?
Regardless, this is fueling problem.
finn
The UP, God's country
It’s lean.
Contrary to JG legend, Honda engines are susceptible to carb issues, just like every other gasoline engine on the market.
They don’t hold an exemption card issued at birth.
The Honda engine on my wife’s lawnmower is due for a carb freshening, too.
theoldwizard1
SE MI
Big fan of James Condon ! Buddy had a "well used" pressure washer with a Genuine Honda engine. Hard to start and surged. Clearly running lean, likely the idle/pilot jet ! Popped it out, Couldn't get any spray through it. Luckily I had some number drills and ran a #76 through it. Started first pull. Ran good !
After you have double checked everything, find a number drill that fits and drill it out 1 - 2 sizes larger !
R
Razorhunter
Ok so yes it turns out this was a dirty jet in the carb. I cleaned it and problem solved.
I wish parts were readily available for these carbs honestly. Maybe they are and I just don’t know it. I did find the gasket kit but that’s it.
Here is a pic of the adjustment screw (not mounted to the carb mind you) which has something to do with the governor linkage. It’s located directly behind air filter box up top under the tank on the left side opposite of the actual governor vertical rod adjustment.
Still not sure what this thing does.
Should I be checking the hertz output frequency of this generator? I’ve read that’s a thing to do after people have messed with the governor.
R
Razorhunter
To the guy who said to drill and bore the jet out oversized….Is that really a thing on generators? I assume it’s not really an engine performance mod, but rather just creating a larger hole so as to make it less likely for the jet to clog up in the future??? Please explain.
Here’s one final amateur question… If I’m using ethanol free gas and also stabil, at what point does this gas expire? Can it ever gum up and clog a carb? I have always wondered this.
sqznby
Coastal NC
I have used torch tip cleaners in the past to clean some of the passages but never drilled any out.
I use CRC Mass airflow cleaner to clean all of my carbs and 99 percent of the time I never even remove the carb. Pull the filter and the bowl and spray directly in every orifice of the carb and up through the pickup and done.
Metallitubby
ATL OTP North
At Honda, we don't recommend it, but most of us oversize mains. Some of the better carburetor tools have a knurled "wire" that makes just the right amount of adjustment to keep it from happening again in the future.
*Also note that when cleaning Honda carburetors, people often forget the transfer and/or pilot jets, which is usually why one "comes back".
R
Razorhunter
Is that the one that the float opens/closes? I actually forgot to clean this one than the float controls but engine is running fine.
Rinspeed
NY
That's your float needle, all it does is stop the flow of gas into the bowl when the floats get to a certain level. If you have a carb that flows gas onto the floor it possible the float needle is damaged, the seat the float needle goes into is damaged or the float level needs to be adjusted down lower. Sometimes a float can get a very small leak in them and not work correctly either so it's always a good idea when you have a carb apart to throw the floats in a bowl of water to check for any pinhole leaks.
