niget2002
Josephine, TX
Made a little chicken hotel for the 2 silkies. Chickens are pretty cold hardy, but we only have the 2 silkies. They don't sleep with the other birds because they can't get up into the roost. Wife and daughter are afraid they won't be able to keep each other warm enough, so we put them in the heated shop.
I know the shop heater won't keep up with the single digit temps, but it should stay above freezing.
Daughter was told she'd have to check on them twice a day for food and water. We'll see how that goes.
kaymccampbell
Upstate New York
A jacketed vessel circulates your selected thermal transfer fluid through your heaters/coolers and then around the inner vessel, which holds your ingredients. It's indirect heating. It allows you to use an extremely pure heat transfer medium, which allows you to preserve your boilers. A jacketed steam pot in a commercial kitchen is an example. So is the humble bain Marie in most home kitchens.
DGersic
DeKalb, IL
Finished the repairs on the Christmas decorations. Used some clear heat shrink to patch and reinforce the ends of the decorative candy cane lights. They’re ready to store for next year, but it’s -10F out and I don’t feel like taking them out to the shed right now.
Beerhippie
Far NE Oregon
We do use boiler steam for heating our wort in the kettle, where it's concentrated to the desired gravity for brewing. Our mash tun--where all the important chemical reactions take place that turn malted grain into wort--has a steam jacket, but we've learned not to use it. If you use the jacket to heat the water to the desired temperature for each reaction, it "gellifies" the starches, preventing them from breaking sown into sugars--in other words, it makes a useless mess of things. The hot water we make using the Rinnais is the "mash-in" water--which starts the reactions that break down the starch--and the "strike" water that's used to extract the resulting sugars from the mash.
We once had a hot water system that used a steam heat exchanger in the storage tank. It fossilized.
kaymccampbell
Upstate New York
So heat the water through a non-steam exchanger, then apply it to your goop. If you use filtered, softened water as the transfer medium for your jacketed vessels, you won't suffer from the fossilized heat exchanger syndrome. My residential water heater is just a big blue egg with a huge heat exchanger fed by my hydronic boiler. Because it's all just below boiling, it never builds up calcium, etc, unlike a steam plant.
Yes, it's more complex. Yes, it's not as efficient. But the savings in heat plant repair drama has got to make it up. At least it does for me.
jshillin
PA
Well, it's like everything, I have many toys because I have many interests. You can't do them every day, or they'd be work. So they get used while I'm engaged, then left til the next enthusiasm in their direction. Sometimes I lose the inspiration to do things in a specific line for years, but then suddenly the desire comes back again. It's been my life.
The nice part about enlarging my tool and skill sets is that when I go to do something adjacent that peaks my interest, I've already got the major part of the tools and skills, so I don't suffer that expensive hobby start or lengthy and disheartening learning curve. It also doesn't hurt so much to drop a hobby after a project or two, because I have the experience to know that although that particular thing didn't interest me, I understand that what I added to the tools and skills will be applicable to the next interesting thing.
Sounds a whole lot like me... I have a ton of different tools and skillsets that don't always seem to go together, but works well for me. Right now I have my 3D printer going more than anything. I have a couple of things I want to do on the wood CNC, I just don't have the time to deal with it at the moment.
dwall174
Southeast Michigan
Re: what did you do in your garage today?
Nothing, it's too damn cold here in Southeast Michigan to try heating my garage.
I have a couple of 240V heaters that will heat the garage, but it's just too expensive to run them when the high temperature is only in the lower teens. 🥶
Maybe by the end of February, I'll get back to working out there again.
jshillin
PA
I jumped my JD Garden Tractor with the Snowblower on it that sits in my little shed and got it moved over to my garage for the impending weather. I put it on the trickle charger and will give it a good once over tomorrow afternoon.
Beerhippie
Far NE Oregon
Understand, this one does not.
The heat exchanger fossilized on the heated water side. Short of the whole-house RO system, not much can be done about that problem. Heat high-carbonate water at atmospheric pressure--or just drop the pressure--and it leaves calcium carbonate behind.
Possibly a full jacket on the hot water tank would work... for a while. Lime scale is a pretty good insulator, so as soon as it builds up, heat transfer drops like a rock. Besides, getting a jacket installed... just ain't happening.
vwpieces
Hills, PA
Standard length
or long ?
Missed a Small detail
dwall174
Southeast Michigan
In the meantime, I'll be working in my basement on rebuilding the quick-change gearbox & the apron for a 13" South Bend lathe I've been working on for a while. I also need to wire-up the control panel for it which I also currently have in my basement. The lathe has a 3-phase two-speed dual winding motor & I'm planning on running it off of my 5hp RPC using a dual-speed starter along with a reversing starter.
Doug
kaymccampbell
Upstate New York
I didn't know. I've got wicked hard water. Left to its own devices everything crusts up with lime. The only thing that doesn't is my hot water maker, which is an Amtrol unit, that's urethane lined and runs off a zone on the boiler.
Maybe your water is harder. If mine were any harder I'd have gotten a full stainless jacketed one with an access hatch, so I could scrape it down occasionally.
Beerhippie
Far NE Oregon
Doug
Now, that's a proper distribution of outlets for a shop!
dwall174
Southeast Michigan
I have basically the same 120V & 240V lines on the other side of my garage.
Things were a little disorganized in this pic. but you can see the outlet boxes on the wall. A work bench is normally on the left side under the shelves, but it was moved into the center of the garage for cutting down some plywood. IMG_1116.JPGIMG_1117.JPG
bugnut
Central Ohio
@kaymccampbell Very well stated, I have tackled things and bought equipment to allow conquest of projects. Some I relish some I hate, but then for a while stuff sits. It's fun to try new things as usually the second time bores the hell out of me.
bmwrd0
Beaver Fever Oregon
Right now is why I am super happy to have a basement shop. There is a building on the back of the property that I had thought about using when we moved here, but dodged that bullet (although it would have been sooooooo much easier to move stuff into it.
Anyhoo, was busy with some crisis yesterday (like turning 55, among other things) to do much shop time, but did manage to get the change gears for the Logan inventoried and get some things packed for shipping.
budo55
Pure Michigan
Nothing as well. Also SE MI..... woke up this morning to -19 at the house; official NWS temp was -14....ugh...
413dan
Massachusetts
Not a damn thing done in the shop today. Woke up and it was -3 Fahrenheit. Won't be much warmer the rest of the day, too cold for working with hand tools in an unheated shop. I'd like to continue on rebuilding a small engine I have apart, but that'll be an early Spring project from what it's looking like. Stay warm everybody!
micromind
Fernley, Nevada, about 30 miles east of Reno.
Doug
Allen Bradley starters....the best there is!
Old Man Roger
Palm Coast Florida
I don't know why the well water being softer than the spring water surprises me, but it does.
My initial thought was the well water got filtered through the rock and sand but my well in south florida smelled like eggs and had enough calcium to form dinosaur bones.lol
hot water maker
You could have said water heater, but your way’s better.lol
dwall174
Southeast Michigan
Gotta clean it up and resilicone it up then throw back in
I bet you're not "Throwing" that transfer case back in with one hand & tightening it down with the other hand.
I replaced one by myself years ago in a K5 Blazer with just a small hydraulic jack & some 4" X 4" wood blocks. Laying on the ground & trying to lift the transfer case with the jack & get everything aligned with the other hand was a PITA! Not something I would want to try again.
vwpieces
Hills, PA
They may not advertise them as small body but they are. Same size as my snappy. I'll try to grab a pic.
those sets are same dimensions across the entire Tekton line
1/4 drive specs are very close to Icon G1. Guess that's why the Tekton 3/8in small body kits fit. I kinda like the thinner, less bulky plastic handle and 1/2in longer on Icon. Not sure why Tekton doesn't sell the prebuilt small body with soft handle but can be done with extra kit, $9.
