2001ZR2
Kansas City
Did a test run of my wife's truck with the single digit temps and snow. The codes didn't reappear and the truck ran fine. Also tested the new battery in the keypad on the garage door frame. The new battery seems to have extended the effective range of the keypad by 30+ degrees.
SweetD
Rhode Island
Got to tearing down my outboard lower unit for diagnosis, gearcase was full of water (!) when I pulled the boat for the season in November. As suspected, catastrophic seal failure at the drive shaft. Ordered parts and will tackle the reseal prior to boating season this spring.
Also cut the tip of my finger washing dishes and it bled thru pretty good.
IMG_20260124_120621564_HDR.jpgIMG_20260124_123606200_HDR.jpgIMG_20260124_132937323_HDR.jpgIMG_20260124_132903018_HDR.jpgIMG_20260124_123752656.jpg
SMOKEYBEAR
Snagged a few tools to assemble a drill press table/ fence I purchased. I watched lots of videos, made a list of features I liked, chased the components down, and then I came across this one from "Oskool" I used some of their clamps and stops previously. It has every feature I planned to incorporate into the one I was going to build. I couldn't build it the cost on the unit.
The other day when it was warmer I was able to get some color on a few pieces of the drill press project. More to go, it's going to be 2-tone so it isn't painted completely yet.
SMOKEYBEAR
Appears you need a new water pump too :LOL:
413dan
Massachusetts
I said I wouldn't be doing anything, but went to double check everything one final time. Snowblower gas tanks each filled, one at my place and one at my mom's where I also take care of the snow duties. Extra gas can filled at each location. Snowblowers placed where they can be started and put right into gear to start working. 12-18 inches expected from anywhere between noon tomorrow and 8am Monday. I am staged and ready to go, bring it on.
Beerhippie
Far NE Oregon
One more reason not to toss knives into the sink.
Got the trans back into the Brick:
It's been a while since I installed a VW transaxle--and I've never done one in a T3. A bit of a fiddle, as they say across the pond, but I got 'er done. Got a good start on all the **** that needs to connect to a trans--and then it was beer thirty.
Back at it tomorrow AM.
2001ZR2
Kansas City
garage adjacent as the temperature got up to about 4 degrees F today. My Dad had not one but two dremel 770 7.2V cordless units. They have been in my pile of things to something with someday so...
I was able to charge the batteries and one unit works at both low and high speeds but the other only works at low speed. Trying to figure out why
niget2002
Josephine, TX
I cranked the heat up in the shop and spent a lot of time trying to get bed leveling working on the big printer. I modified the bed some to make it easier to manually level it closer to flat. I ran the G26 test that marlin offers and it looks pretty good. Tomorrow I'll run some test prints.
rharman
SoCal
Got tired of needing the tractor to push my projects back inside the garage. Another upgrade was needed. Added concrete under the new lean to and in the driveway. I think I have used enough excuses. Time to get back on my Fairlane wagon project!
Looks good. Is there a reason you didn't add, at least partially, to the left of the drive to make a path to the lean-to?
vwpieces
Hills, PA
Snow prep.
New soles on the snow blower shoes. Used some good tortion bar stock from a VW.
Made sure it started, gassed up.
Jabbit hasn't been inside, but it gets a warm place till the snow is cleared from the lots.
Bring it on...
Fordguy1964
Houston County, Alabama
Went out to the garage today and looked around. Not able to do much today... it being my birthday AND my anniversary. Got a great gift for my birthday present. She puts up with me and my projects so I guess that is a plus. Took some measurements for some metal angle I need to pick up from the scrap pile at work tomorrow. 19495.jpg
PhantomEB
Medicine Hat, AB, Canuckistan
I bet you're not "Throwing" that transfer case back in with one hand & tightening it down with the other hand.
I replaced one by myself years ago in a K5 Blazer with just a small hydraulic jack & some 4" X 4" wood blocks. Laying on the ground & trying to lift the transfer case with the jack & get everything aligned with the other hand was a PITA! Not something I would want to try again.
Thats why my birthday present to myself was a 14x14 lift table capable of lifting stuff up to bench height or tailgate height.
a57belair2
Picked up this little lift table last night to assist in the tcase and doubler removal today. ******* out of the back of the transmission, hoping there’s a missing seal or I need to silicone up more on the back of the tcase.
Any info on the table? How do you like it? Thank you.
pancholasvegas
Been getting after it on the Econoline trailer this weekend.
I had gotten all the guts and spot welds off the wheel arch panel previously. Unfortunately, where it was cut off at the scrap yard was where the flange connecting the corner panel was located, so that meant I needed to graft in another section. Fortunately I had another panel from the original shipment I received - unfortunately, it had also been hit at some point in its life. The piece in question is on the lower left, beneath the top panel and to the left of the corner section.
I had removed that section and set it aside previously - I moved forward with removing all the spot welds and guts from the inside of the panel. I’ll spare you all those photos - very tedious.
I worked it for a wheel getting it back into some semblance of straight. Keen observers will notice that this thing got hit HARD as evident by the entire wheel flange behind pushed in and stretched straight (visible bottom left of panel).
Straightened it a bit more and then threw it on the original panel for some measurements.
Laid up next to the panel it will be grafted to.
Really fun part about working with vintage “oddball,” vehicles is that parts availability *****, so you need used parts. And all those parts have been crashed once already - even better when they’ve been wrecked in the same spot. 🙄
Manhandled the long panel through the “homemade” English wheel to get it back into orientation.
Then it was very tedious work - sharpie used as layout fluid and a scribe line struck. Then a tape line overlapping the scribe line to really sneak up on the cut. Repeat for each piece.
I sincerely apologize - I was in the zone and didn’t get any photos of the fit up before I started welding, but here’s a shot after a few stitches and during some massaging / measurement.
I worked on it a bit this morning finishing the weldment and doing some dressing - few areas I’m not happy with that got away with me and I had to use more filler than I would have liked - oh well, it’ll work out fine. Worked it with the hammer and dolly a bit and some DA Action, mocking things up.
Next cut coming up will be the top panel - I’m really hopeful this will be the last panel weld I’ll need to do.
This might be a lot of work, but check out what we started with!
Yeah the donor panels might be cheating, but I’ll cheat considering we want this thing painted by summer 👍
Beerhippie
Far NE Oregon
Froze my fingers working in a high-thirties shop this AM, but got something done. Everything is reattached to the trans--including the shifter assembly that I'll have to remove again to fill the oil. On the stock VW engine set-up, you can get to the filler with the shifter installed--but it's easier to do without--but with the Suby swap, there are now two cooling pipes in the way.
Heading back over in a few and hoping the shop might have gotten up into the forties by now....
GrayFlattop
Chicago
Got the snow blower out, put it away.
Did some picking up and unboxing in the woodshop. Fiddled about with the dust collecting piping and determined what additional bits and pieces I need.
And…. Back out to to the garage in and hour or so for round 2 of snow removal. Yay.
Notgrownup
Snow Hill NC
Testing my skills and using some new techniques. Building this little shelf from walnut & zebrawood. Dado stack came in handy and my miter gauge. Will update later, still have a lot of sanding and finishing to do. My Prozac
Beerhippie
Far NE Oregon
I'm declaring a small shop victory for the weekend:
Enjoying a well-earned beer right now....
Lots of fiddly **** to do still--like fill the transaxle, put a new bushing in the front mount, bleed the clutch hydraulics, fix the power door locks, wire up the trans oil gauge... and so on (and on and on and on and on....).
I actually got the shop up to shirt sleeve temps by the time I was done.
jblnut
In the Middle of MN
Twas yesterday but …. We setup for a customer appreciation event that I host for our seed corn business every year. All in over 130 people rolled through. It’s nice to get the shop cleaned up and shiny at least once a year. The kiddos were testing the food and tables before people showed up lol. From 3-midnight there was a steady flow in and out.
