The Ancient and Independent Order of Oddfellows (Adjustables, that is...)
MShaw
York, Pa.
I purchased some machinists tools from Hyperkitten Tool Company. While looking thru his website I saw these wrenches. If anyone is into old adjustables two for $15.00 plus shipping seemed like a bargain. Just thought I would mention them here.
Fred Knox
Nor Cal
I finally stumbled upon an “oddfellow” that has been on my want-list for a while - a “Wizard” ratcheting adjustable wrench manufactured by The Richards Mfg. Co. of Aurora, Illinois. It has adjustable jaws built into the head and is stamped on the face with "Patented May 21, '07" and "Other Pats Pending". It’s in great working condition, and honestly it is fun just to play with. I see @Oregon rock crusher recently picked one up too.
P
Nice find!
I must've missed that. Congrats to you, too, Ed.
Moldyjim
I found this pipe wrench at the flea market, paid too much but WTH, why not.
Looked at this entire post and unless I missed it this should be a first of this particular wrench. It has a series of teeth on the spring loaded catch and the main arm of the wrench. Similar to some others here but with a different jaw loading setup.
Moldyjim
Found the patent,
P
You're correct. It is a first. Good example of a quick-adjust. Nice find!
Please edit your post to include the patent number and patentee's name. I could do it right here in this one and direct future viewers to your post, but it's better for you to fo it. The search engine will not find it inside the DATAMP link.
Moldyjim
US Patent: 274,544 - patented by Frank Armstrong of Bridgeport Connecticut on 3/27/1883
Not looking to add to my pipe wrench count, but this ratcheting pipe wrench was too odd to leave behind;
The ratchet drives a gear to close the jaws and tighten them, bit also can be used, within limits, to ratchet on the turning of the pipe. the pipe itself, unless gripping a fitting below handle level, limits things before a full turn happens.
As noted by LS in the GS thread the finger grips seem bass akwards.
No makers marks., but A Google search ferreted up one NIP larked Lehigh international and same model no.:
P
@Mister Ed just found and posted one on the pipe wrenches thread a couple weeks ago, here, pointing out that the "RP-070" marking is often mistaken for "PROTO". If one is slightly dyslexic and/or the type of person who doesn't pay attention to detail, or is in a hurry, or both, I can actually see that happening.
Fred Knox
Nor Cal
Here’s a photo of my recent Baxter wrench find - a 6” one alongside his older bigger brother I posted previously up-thread.
Fred Knox
Nor Cal
A Bullard no. 0 “automatic” wrench, patented October 27, 1903. The company went out of business in 1909. It also manufactured a no. 1, no. 2 and no. 3, up to 17.3” in length. This one is only 5 1/2” in length.
A Helix 8” stainless steel quick adjust wrench in really good condition (made by Petersen Tool Co.). Works perfectly. @HeelSpur has one upthread.
HeelSpur
WV
Bullard also made a #4, 19 1/2".
P
Nice find! One of the "Oddfellows" (not screw or worm gear) that is still on my bucket list... :ninja:
Bullard patent 742,389 (1903)
// Spring-Loaded Self-Adjusting Jaw //
Kind of cool of any mfgr, but them, in particular, on top of the vise grip pyramid, to be working on a better mousetrap adjustable as late as 1971.
Indeed, and for those wondering about the mechanism, I posted the patent diagram in reply to his. It's very complex (spiral shaft and TWO bevel gears!)
If that works like I think it does, I have a later Asian knock off that I put into SWMBO's little tool kit as I cannot imagine its very tolerant of shop dirt/grit. I only got it for its oddness.
P
Nice find, Roy!
It's hard to see in that photo, but the wrench is actually made in halves, mortised together, with each half having one of the two jaws on each end. The diagonal adjuster moves both halves (and therefore both jaws) at the same time in equidistance away or closer.
Baxter designed, made, and licensed (to Greene, Tweed & Co., and a few others) TWO styles of these wrenches: this one, which has 22-1/2* angles, and an adjustable "S" wrench - which moved the adjuster into the center of the shank. The principle and two-halves construction are easier to see on the other style.
If you search the thread on "Baxter" you will find other examples of both styles (I have two "S" wrenches, different OAL's) and somewhere a post from @Fred Knox showing both styles in the same photo.
Making things even more confusing and harder to discuss when "Baxter" comes up is that there were two production periods. He "improved" (and extended the protection of) the design and was granted a second set of patents for each type a couple decades later.
While we have touched on this all before, your question presents a good opportunity to do it more comprehensively, which can serve as a handy link for next time it comes up.
DATAMP link to that marked up page here...
Fred Knox
Nor Cal
Holt’s adjustable “The Triplet Wrench”. It was patented August 19, 1913. Regular wrench has capacity to 7/8”; the capacity of the alligator wrench side is up to 5/8”, and the tap capacity is 1/8” - 1/2”.
P
A probable Russian adjustable wrench (marked 20-50 then a "H in a diamond, then 7813-0002). Happy to hear anyone's thoughts.
Hey Fred, look what the cat dragged in...
Fred Knox
Nor Cal
Here’s a recent find - a Pollock’s Automatic wrench.
It is also stamped:
PATENT PENDING
WISCONSIN STAMPED STEEL CO
MADISON WIS
It is about 9 1/2” long and expands to a 2” opening. Pushing on the top lever automatically tightens the jaws fairly securely and is surprisingly heavy! I believe @HeelSpur posted one upthread.
P
His is linked upthread HERE. Mine is linked upthread HERE. And if you scroll down from there you'll find my research, including several documents I pulled from Google Books, including this fascinating tidbit... :)
Charles V. Pollock tried making a go of it for a few years with his own outfit, then licensed to Wisconsin Stamped Steel Co. Per DATAMP, Pollock's great-grandson recently sent them photos of his great-grandad with only one arm - apparently, the inspiration for the wrench.
