what a fluke!
hguerrero
fort worth, texas
stopped at a garage sale today on the way to work.
picked up two usa made vice grips and this fluke multimeter...
always wanted one but didn't want to spend 200 to 300 bucks....
....just needed a battery
spent $5...
MattT
spent $5...
That's no $2-300 meter. IIRC they were under a $100 new. Still well worth what you paid though:thumbup:
scott37300
Wisconsin
I have that one also and it's a good basic multimeter, does voltage and ohms which is about all I have needed it for so far.
H
hguerrero
fort worth, texas
really? cause i'm not finding these online used for less than 150...did see a couple sell on ebay for 100...still...5 bucks...i can't lose...
MattT
It looks like one of the cheaper ones. What model # is it?
electrodude
Out in the wheat and lentils
It's a basic multimeter, not the fancy ones like my 87E-3 (which is now outdated).
Now, that said, I use a T-1000 Fluke day in and day out, my big multimeter never leaves the toolbox except once in a great while if I'm doing electronics.
The 87E-3 was over $400 when I got it, the T-1000 goes for under $100...
$5? Kick. ***! By the way, if the Amp setting doesn't work, I believe that meter has a built in fuse like the 87 series does, they're a couple bucks down at the electrical supply.
electrodude
You betcha!
I will not use any meter other than a Fluke. I've had the store brand ones, Greenlee's, and other brands, but for a digital meter nothing beats a Fluke.
What does beat a Fluke is my old Simpson 260 series analog meter! I love my Simpson!
jride200
Does anyone have suggestions for cleaning Fluke meters? I got a model 179 a few months back (USA Made!) and, no kidding, first time out of the box, I marked it accidentally with my ink pen. I've already tried alcohol, to no avail. I'm afraid to try any stronger solvents like acetone or MEK.
Ditchdigger
Eugene, Oregon
I know for a fact that acetone will melt the case of a fluke meter. It was all so innocent. Say this thing is pretty greasy, I should wipe it down with...OH ****!
afterburner
Everett, WA
To clean grease and grime you can use WD-40 on holsters or the yellow overmolded part of the 179 meter, not sure if it will take off pen ink though.
you could try some hairspray. just spray a little on there and wipe it off.
RLRRLRLL
Spearville Kansas
flukes are nice...i want one......i have a 20 dolla cman in my home box...and a cheapo walmart one in the box at school....but when im testing something that is more then just checking for battery voltage.....i use the instructers fluke.
mrholeshot
MEMBER EMERITUS
Throw that Horrible Fright meter away and pony up for a Fluke T-600. Using a cheap meter is like playing Russian roulette: you'll get away with it for a while...
I own a Fluke 88 and 87 (the 87 is a Kent-Moore/Fluke) and I also own a shitload of other DMM that range from cheap to expensive. In volts and Ohms they all read the same throughout the range. I carry a greenlee with thermal probe with me about all the time it's been beat around for 7-8 years. My Flukes are fragile. The displays will go out if you bump them hard. I use them in critical measurement because I'm confident in the accuracy. I also have a HF fluke look alike that is my go to meter. It won't do all the stuff a 88 will but the measuements that it does do are on the money.
joemh22
I believe flukes are the best handheld DMMs. I have a 73iii and have used a 77BN and a 179 for work. Metermans are garbage. Simpson's are great but old and bulky.
KenS
I've had success removing dirt and magic marker with non-chlorinated brake cleaner. Use just a little on a paper towel, wipe the permanent marker ink off and immediately follow with a swipe of WD40. You should open the case and test a little in an inconspicuous corner to make sure your plastic will tolerate it.
cnc-me
MI
My 1984 Amprobe bit the dust last year.
(with the rotating analog scales)
Sure do miss it. :(
