Acorn style table
zkdiesel
chicagoland cornfields
Dragged out my freebie table from storage building so my wife can start cleaning up on it and paint it
Think the damaged reed vice needs to leave as seems like a good spot for my Wilton 800s to fit.
Don’t know if I should cut the tool boxes off it or leave it as they are very crude but do serve a function to hold the tools
Radio Flyer
Suburban Chicago
My vote would be for boxes off. I’m a sucker for being able to work around all sides. It never fails, if you leave them on, you will always be moving your work because the boxes are in the way.
Oregon rock crusher
West of Salem
Nice table ZK and free is a damn good price! I do like a shelf or two under the table to keep tooling handy but prefer it be a screen bottom so all the **** that falls through the holes makes its way through to the floor. I also like a heavy vise near the platen but prefer a very solid mount off a leg with the top of the jaws level with the table. I also don't mind a smaller vise that I can drop in a hole anywhere around the perimeter when it's needed.
NUTTSGT
Northern Central Ohio
I think some 2x2 hitch sized tubing would be a great way to mount the vise... Slide vise in, slide vise out and allows for other mounted tools to be put in when needed.
Tool boxes gone, I would want full 360° access around the table and why I would mount the vise on such.
NUTTSGT
I'd still remove the tool boxes. I'm guess they were for welding clamps and such ? Is it possible to mount they underneath and a sliding type of tray ?
dr_clyde
Holland, MI
I have an acorn platen that I restored. They're worth spending a few bucks and some time to get back to nice.
Personally, I'd get rid of the boxes and the vise. You want access around the whole table.
I would also look seriously into getting the top re-ground. Yours is small enough that it should fit on a lot of larger Blanchards pretty cheaply. I would bet you could have that top ground in for less than a grand and it'll be like a whole new table. I paid $800 to have mine milled on a HBM and that was the hard way, mine was too big to fit on any of the local grinders. Just ask if any have the willingness to let it either sit around until they have free machine time, or schedule it to their liking. Don't go nutty with tolerances. I asked for just a clean up cut, not specifying any measured tolerance knowing the machines would hold a tolerance plenty fine for a weld table. I also told them to ignore any large gouges or huge voids/low spots so they didn't take off any more metal than necessary. Depending on wear, you would only need to grind off .05" - .125" max.
I also highly recommend if you must keep a vise on it you make the vise removable easily. You'll find having an uninterrupted flat top is very, very valuable. I made a bracket to mount my vise so I can easily pull it off when I don't want to use it.
Stronghand tools makes drop-in clamps for a fraction of the cost of the Weldsale/Acorn ones. Like, $100/ea vs $300-400/ea. They work fantastic and I see zero reason to pay big bucks for the Weldsale.
I will see if I can find some pics of my resto, it was a good project.
dr_clyde
Holland, MI
As-received.
I had the top sandblasted. Worth it.
I then modified the base to have trays to catch debris and painted the top. I’ll have to get a better shot of the debris trays.
I made this copper plate to attach ground clamps to.
Machining the top.
Nice and clean.
These are the strong hand clamps sitting next to their little brothers designed for the “normal” fixture tables. You can see how much heavier they are.
