The BendPak parking lifts I ordered in late January finally made their way to my installer’s warehouse and we agreed to begin the install on Monday. As my installer has not had much experience with these new lifts, he brought along someone who has installed a number of them. There are a ton of bits and pieces to these lifts, and the install is much more complicated than a normal 4-post install.
They began by setting the first base and drilling the anchors.
At this point, I had to leave to take my sister and BIL to the airport to return home to Portland. We had a really nice 6-day visit.
When I got back, they had the second base anchored and the main lifting arms attached.
I put a lot of labor into this install, partly because I wanted to see how everything went together and partly because without my help, they would probably still be at it! My first inclination that not everything was going well was when I saw how the “experienced” guy set the wheel pan. This is a pan at back end of the lift where the car wheels rest when parked. One side is sloped, the other is 90 degrees. He insisted the sloped edge go to the back! I ultimately won that argument. We also had to take a bunch of bolts back out in order to set the parking base pieces.
By the end of the evening (after 9PM!!) we had everything assembled finger tight and the hydraulic fluid installed. That’s where we left off.
Much to the disappointment of my installer, his “experienced guy” announced he would not be returning the next day!
Since we went so long Monday, work didn’t start Tuesday until almost noon. We got everything tightened up other then drilling the anchors for the right most base, as we wanted to make sure what we had put together worked properly.
We hit a roadblock with the electrical hookup. My installer professes not to be an electrician and the wiring on this is more complicated than just hooking up power. Add to that, the instructions were not very clear, and extra wiring was supplied without any indication on where they were to be used. So, I scheduled an electrician for the next day.
Once the electrician digested the instructions and got everything hooked up on the first lift, we ran it through its full range of motion. That’s when our biggest problem manifested itself. The platform would not fully lower, and the leftmost pier was being pulled in. The “experienced guy” f’d up the measurements for the middle base, and forgot the mantra “measure 3 times, drill once!” This shows how far off the measurements were.
So, we drove the anchors into the concrete and attempted to move the pier and outrigger. It just wouldn’t move. Finally, after lots of head scratching and explicatives, I discovered one of the anchors was about 1/4” proud of the floor. Once we fixed that, we were able to get everything into position and anchored down. What a bunch of wasted time!
Here are the lifts in use.
It’s just about perfect for the ‘34 with the suicide doors, but the approach angle is too steep even for the ‘34 and I have to use some plywood ramps to avoid dragging the headers and oil pan. I don’t need the extra space right now, but the Charger will likely occupy the other lifted space.
While these are pretty complicated to install, overall I’m happy and they meet the need.
