It arrived last night--carefully concealed, as always--and I gave it a good test.
I got the biggest tire I use, an 225/70/16
Aired it down to 20 psi:
Then refilled it to 40 psi--the recommended pressure for a Vanagon rear tire.
Two minutes ain't bad. Another test I like to run on a new, complicated tool with digitals is if I can use it for the basic function without reading the manual. Passed.
The inflator cycles on and off while filling. You can see the indicated pressure on the display get up to the target, then it shuts down, the indicated pressure drops and it fires up again. Repeat. This may be due to excess restriction in my DIY QR chuck converter:
I think I'll cut the screw-on chuck off and attach the QR one directly to the line and see if that helps with the cycling.
