Permit for any size shed
A1an
Tampa, FL
So I am still in the beginning stages of getting my garages sorted out and organized. Currently my yard equipment is in the garage. In the not so distant future I plan on throwing up a smallish storage shed in the fenced back yard to keep my mower, edger, etc.
Last night I shot an inquiry to my county asking about a fence (making sure we didn't need a permit) and decided I'd throw in a few questions about the shed. They responded within an hour to advise me we don't need a permit for the fence but for any size shed we are required to pull a permit with the county.
I was originally going to build something myself using some plans online to hopefully get this done fairly cheap but not I am not sure what to do. I have zero experience pulling permits, drawing plans, etc. Do I need to hire a contractor or someone to draw up plans to submit to the county on my behalf? Has anyone gone through a similar process for such a small structure on their property?
Once it is built am I subject to a county inspector like I would if I were building a home?
ErickForest
Minnesota
Usually all they want to see is a plan of the shed, which doesn't need to have a lot of detail. Also they would like to see a plan of your yard with where you want to locate the shed.
z28snksknr
Turnersville, NJ
I have the same questions in my county. I wonder if the sheds they sell at HD / Lowes require a permit before you plop them down in your yard.
Right or wrong, I plan on building my own like you but not ask permission about it. In my mind, a shed is not occupied or should even be considered a structure that needs to be "up to code". It's a large box to put tools in.
A
A1an
Tampa, FL
That is what I was thinking. I'm going to build my own after my less than spectactular experience with a kit from Lowes many years ago. If I build my own I could keep the roof line under my 6ft privacy fence and no one aside from the neighbor on one side would be the wiser. Granted I couldn't stand up in the thing but it isn't as if I'll be hanging out in the shed.
I just don't want to be caught with my pants down if we go to sell the place and they find we didn't pull a permit for the shed.
z28snksknr
Turnersville, NJ
I don't know anywhere in the home buying process (in my area that is) that checks to see if permits were pulled for any project. A home inspector may comment on work not done to code, but that's just info supplied to the buyer, not the township. A shed would be the least of my concerns as a potential buyer.
kmacht
Connecticut
For most wooden sheds, 10 minutes with a chainsaw and a trip to the dump with a pickup truck would take care of the problem when selling the house.
Keith
greencar
New Jersey
In New Jersey you do not need a building permit for a shed 100 sq ft or less. That being said the town or county may require a zoning permit which would deal with set backs,height and things of that nature.
Lou's Garage
Anderson, SC
Every building department varies by municipality so any suggestions I offer might be irrelevant in your area. My experience (in NY) has been that when it's time to build, sit down with a building inspector in person tell them what you'd like to do and ask exactly what you need. It helps if you bring a plot plan so the inspector can visualize your lot. They may have to tell you that you can't do what you would like but often they will suggest an easier to permit alternative. Once you have established a rapport with the inspector they will probably work with you until completion with permitting, making the necessary inspections, etc. For a shed, the plans you intend to buy online will probably be fine, just ask how many copies you need. It might even be a good idea to bring a set with you when you first approach the inspector. Often, for a deck or shed, the permit process may even accept a neat, legible hand drawing. You may require additional plans or diagrams if you intend to add things like electricity or plumbing at the time of construction so keep it simple and it will go easier. FWIW, that's my experience with permitting and acting as my own general contractor for decks, sheds, and garages.
Lou
Hmrhead
Rochester, MI
At the beginning of this year our township instituted a new code for sheds. Any shed over 25 sqft needs to have a permit pulled and drawings submitted. Level of drawing detail varies based on size of shed. My neighbor found out the hard way a few days after I helped carry out the the base frame from his garage. A couple of days later I walked over and asked if he needed help with raising the last two walls as I figured it would have only taken a day to put up all the walls, he is retired and it was only a 8x12 shed. He said he got red tagged and his SIL, who is part owner of a lumber yard, was putting together drawings for the building dept. The lumber yard, who supplies a large portion of the building materials in the township, was unaware of the change as well.
GarageEnvy
Fresno
Uhh I do. I work as an appraiser and I call about permits all the time. In my area you can build a 120 sf shed w/o a permit but ask me about this in another month. I built a 14x18 w/o a permit right in the back corner of my lot. When I went for permits they asked for the location of all sheds, pools and outbuildings. I can shrink it, permit it or remove it prior to getting my final. I've been advised to roll the dice since it might get overlooked when they do the final inspection. The stupid thing is I could have as many 10x12 sheds as I want wherever I want as long as they were 6' apart from each other.
ADaughen
Do they require permits for "temporary structures" in your area?
Locally, I can build a shed without a foundation (skid floor, etc) without a permit.
wineslob
The Northstate
Same thing here. No foundation and under 120 square feet, no permit, setbacks ect, ect....
jwh
Rochester NY
Here in Irondequoit NY (Monroe County suburb of Rochester) permits are required for sheds, fences, and swimming pools. Also, there was a law here (maybe still is) that you couldn't have a fence on your property between the front of your house and the sidewalk (or street if there is no sidewalk.)
I've heard that one of the applications of Google maps and the similar programs is the building depts. looking them over to corrolate whos been naughty and nice with un-permitted construction.
People who have bought/sold houses around here lately have been required to search permit records for what work was done.
All that being said, there is the Zoning Board Variance route you could go if you have to. I'm underscoring that because in my dealings with that (once) you need to have your ducks in a row or you will get shot down. If your neighbors don't like the idea you will get opposition from them. Also you need to present alternatives and why you could not do them.
Hope this helps.
GarageEnvy
Fresno
I can confirm that our building department uses google earth and streets to check up on people. Prior to that they used to subscribe to an aerial photomapping service.
luvair
Check with Planning and Zoning. It varies of course by towns and states. I think generally if it is under *** sq feet they do not need to approve plans. In my town, it is 600 sq ft.
lupinsea
Many of the local building departments around the Seattle region have fliers and hand outs that help walk home owners through a permitting process. And I've found the building department officials can be helpful letting you know the next steps you need to take. Might be worth stopping in the office for a visit.
And as others have said, it varies whether or not you need a permit.
In my home town, any shed under 200 sf does not require a permit, nore does it need to conform to setbacks. And there don't seem to be any restrictions on the number of 200 sq ft sheds either, only an overall impervious coverage limit for a building lot.
The codes also didn't say anything about restrictions on foundations or not so . . . I'm in the process of building this as my shed, it has 3 ft tall foundation walls, almsot 4 ft if you go down to the bottom of the footing:
6768rogues
Western NY
We have to get a permit for any structure. For small sheds they are more interested in the location. It has to meet setbacks, be spaced from other buildings, not interfere with drainage, not be located in an easement for utilities, etc.
nate379
Palmer, AK
No permit needed here. Under around 500 sq ft you are fine (I think it's 460 or 480 but I don't remember for sure).
Even on a house they just need inspections on the septic and foundation and that is pretty much it. You can get inspections on other stuff I am told, but I think 98% of the time it's just pencil whipped anyhow.
drooartz
Utah, USA
I just finished adding a 16' x 16' deck to my house. Where I am this required engineered plans, permits, inspections, the whole shebang. This was the first time I'd ever done permitted work, so I had no idea what I needed to do. I found my local building inspector folks to be very helpful -- a quick call to them and I had all the information about what I needed to give them for the permit process.
Be very careful about the "beg forgiveness" method. If your local building folks get wind of it, it's quite possible they can make you tear it down. Again, I didn't find the permit process difficult or particularly expensive, and now I've got all the paperwork to prove that the work was done to code.
Every local municipality is different and has different requirements -- I'd give the city another call and they'll be able to tell you exactly what the process entails.
denis4x4
Durango CO
Check my avatar. These are two portable shipping containers with a roof that meets county snow load requirements. Portable = no permit in our county.
Speaking of google, I'm seeing businesses listed in residential areas that are not permitted!
nate379
Palmer, AK
Google earth around here is at least 7-8 years old. The area where my house is shows as just woods and the first houses where put up in the early 2000s. Don't have google street other than the couple main drags.
Dominico
Has anyone ever considered a vinyl shed like they sell at Lowe's or Home Depot? I know there not cheap compared to a stick build, however they can be moved very easily if necessary and are maintenance free. Even though they don't compare to a wood shed (quality & price) they are manufacturing them better and better every year. I don't believe you would need a permit for it either. A 10 X 12 is about $1,000 - $1,200 at Lowe's with a lifetime guarantee.
Scout Driver
South Dakota
Just an opinion from my perspective.......
I work as the zoning administrator for the county that I live in. The best person to ask your questions to is your local zoning admin. Every jurisdiction is different in reguards to regulations. If you ask questions and make the effort to learn the setbacks, permit requirements etc, you will make entire process easier.
Building permits are for the benefit of everyone. They protect citizens by allowing sufficient setbacks from property lines, roads, easements, utilities etc. In my area, a filled out application (or partially filled out, ask for help if needed), a very basic building description, and a rough perimeter drawing in reguards to property lines and road right-of-ways is enough to obtain a permit. Pretty painless and easy.
Scott
Brad1234
"It' easier to ask for forgiveness than to ask for permission". Your first mistake was to ask about the permit for something as small as a shed. Now you have to get one. As long as neighbors don't complain you probably would not have had a problem. All they need is a quick sketch that show the size & the location on your property. You might want to check for any zoning rules about set back from your property line.
ADaughen
This usually works for the spousal unit, but this normally doesn't work for the Assessor's Office. I deal with their offices all over the US Monday through Friday 8am-5pm EST. :thumbup: The results vary greatly depending on the jurisdiction and who you know...
denis4x4
Durango CO
I find that that only works if you have met every requirement on setbacks, foot print, etc along with meeting all building codes. Another fact to consider is whether or not your property improvements match the files in the planning department when you go to sell your house. It could be a deal killer.
Snake87
I recently put up a shed in my backyard. I read through the specific guidelines for my village online, and made sure the shed I picked out met the requirements. In my case it was no more than 100 sq feet (bought a 10x10), and no more than 13 feet high (ended up being around 11.5).
It may be different in your situation, but for mine, it was a very quick and painless process. All they really wanted was an overhead drawing of the property with the location of where the shed was going to be placed in the yard. Again, it's probably different in your case, but in mine, the shed can be no closer than 15 feet to the house, and 5 feet from the property lines on the sides and back. I just drew a box where I wanted it on the drawing, marked out the dimensions of how far away from the property lines it would be, drew in the dimensions of the shed and that was it. The woman took a quick 5 second look at it and wrote up the permit. I'm now waiting on the village to come and inspect it (I imagine just the roof, as another poster already mentioned snow load.) Good luck!
