Kennedy Kits Tool Or Tackle Box Age
TimmoTool
Nope.. Missed that one. This puts the Kennedy Kit 600 series in production as far back as 1923.
The question becomes… When or did Kennedy ever put a reference to “patented” on the logo under the 600 series?
Thank you
Tom Graham
Oklahoma
Congratulations. You have already determined a much closer date range for your Kennedy Manufacturing Co. box (tool or tackle) than most.
What you can personally continue to contribute further here on GJ will likely add to the overall body of knowledge.
In the absence of an original sales receipt, dating our vintage or antique collectibles is an inexact science, whether date of manufacture or date of purchase (from inventory).
I do believe that the original decal (when present) in use on your box is one of the indications of some of the very earliest boxes -- in each series.
But you should be aware that it‘s only one clue — and Kennedy used at least three different variations of this same gold Kennedy Kits decal on different boxes over time and of different series:
1) no reference to Patent, 2) Patent Pending and 3) Patented.
  • Like
Reactions: RTM
Tom Graham
Oklahoma
Stamped patent references can be helpful in approximating age, but only when the referenced patent and date are verified. Even when a patent can be confidently identified, the patent date typically establishes an earliest possible manufacture date, not an exact one. In this era, U.S. utility patents were valid for 17 years, so hardware based on a 1916 patent could plausibly have been manufactured anytime between about 1916 and 1933.
For those Kennedy boxes with the hasp lock stamped “KENNEDY PAT’D 9-16-16”, the date September 16 is not an exactly accurate date for a patent application or issuance.
However, I do believe the year 1916 of the patent reference is correct for the hasp-lock. After a lengthy search, a compelling match for the hasp hardware often stamped “PAT’D 9-16-16” on Kennedy Kits and similar Corbin-supplied locks is:
🔗 https://patents.google.com/patent/US1202002A/
This is U.S. Patent 1,202,002, filed August 11, 1915 by E. B. Stone, granted October 17, 1916, and assigned to The American Hardware Corporation—the parent of Corbin Cabinet Lock at that time.
So my question is: Isn’t this (US1202002A) likely the 1916 patent intended?
Looking good. I was working on a brute force search, using Sept in my terms, thinking that was the easy part to get right. Couple of possibles have come up, but yours looks far more possible, and with the parent company being there, seals it for me. Well done.
TimmoTool
This is fantastic research… My Corbin Lock is simply stamped “Kennedy”, and the decal doesn’t reference “patented”. If the 1916 patent lasted 17 years, does a lock that is only stamped Kennedy combined with a Kennedy Kit Logo mean that the box was produced beyond the patent expiration in 1933?
Family History would align with 1920’s -30’s for this Model 621 Tackle box
TimmoTool
Or before the patent was “pending”…
Anyone know when the Model 621 went out of production?
On a side note, I now have Working Corbin Factory Keys and a restored - Re-Skinned Leather Handle…
Thanks for help
Tom Graham
Oklahoma
@TimmoTool*,
“Anyone know when the Model 621 went out of production?”
One of your very best sources to narrow down the date range for your tackle box is to search the Fishing/tackle and sporting goods magazines. Since you have at least one ad for the Kennedy tackle boxes, search successive years and identify when your specific model first appeared (obviously gives you an “at least by this time”) and then search successive years to see whether other models continue but then your model is dropped (this would give you a likely/possibly dropped before this date)(I.e., They wouldn’t continue to advertise after it was discontinued .)
Personally, I would be hesitant to use the absence of a “Patented” reference to confirm anything other than…
unlikely to have been manufactured at the same time as an identical model with provenance positively tied to a date / range that does have a Patented reference.
“Patent” references by the Patent holder were likely primarily a marketing strategy (and an attempt to reduce the likelihood of copycats/infringement.
In the case of the Corbin lock patent, I’d like to think that Kennedy was not trying to imply that they held the patent, but that it might have been a licensing requirement of Corbin for Kennedy to use the Corbin lock patent.
*presumably the same as @LaneFowler, the OP?
TimmoTool
Yes to presumption… I have been working on this a long time.
Based upon input…The Ads… The Patent Info… The Logo and random use of logos… Direct Contact to Kennedy… The use of Corbin Hasps and Locks… The box without the corner support brackets… The Leather Handle and the Half Moon shape of Handle … This Kennedy Kit Box dates to the 1920’s - 30’s … Unless proven otherwise… .:)
I have keys and a renewed leather handle… The restoration continues now with bodywork and paint…
  • Like
Reactions: RTM
rust in the eye
Chicagoland
Can any of you fellows put a date on this one? Looks to be model S19 shown in the last page of the catalog pages posted by four.cycle. No date on that literature though. It is for sale and I've been representing it as from the 1970s, just want to be sure I'm representing it correctly.
Tag inside(no model number on it, just blank)has same type font as the catalog page I refer to. Plastic handle, square corners, no corner gussets, side catches by Worcester T&S (Tool & Stamping?), Rochdale Mass.
Think 1970s, based on this link
Font of the Kennedy, and the plastic handle seems to be about right in my brain, but who am I to argue with documented information.
And FYI, I put the page into Google Lens, and a few choices down it found @Pexto 's thread. All good tool searches come back to GJ.
rust in the eye
Chicagoland
Thanks RTM. That font does scream late 60s- 70s. That is the same brochure I saw in four.cycle's post, your direct to the Pexto tread has helped to put a likely date on it.
Looks like it is a refuge from the Nixon administration.
orangeblood
Texas
I too am interested in any thoughts from GJ members on how to replace this style leather handle on a tool box. If not "how to replace" hopefully where to find someone that does this type of work. Thanks.
I'm also interested in GJ member thoughts / sources for replacing a vintage leather handle like this
