PhantomEB
Medicine Hat, AB, Canuckistan
Cut,sanded and attached a maple butcher block top to a medical cart and covered it with Watch walnut Danish oil. To make it a new addition to my storage solution.
I plan to go butcher block tops too on my work benches.
It got drunk out yesterday with the 500 on and brisket on the smoker…..today is put the side box out into the cargo trailer to map out that project In there. Then pull everything out from the west wall to sweep up and vacuum before the **** storm rolls in. Got some shovels that could be cut up and put in the trash. Rather get a new shovel every 2 years.
CoogarXR
Went out and put the new yearly registration stickers on my cars. Unfortunately, the van in the driveway musta been too cold or damp or something, the sticker wouldn't stick to the license plate. I had to take the plate off, bring it in, clean it, and super-glue the sticker on, lol. Wadda pain in the ***.
Notgrownup
Snow Hill NC
The wheels on a cabinet I built 10 ago delaminated.
I bought some steel wheels the same size and swapped them out. I did have to chuck the new spacers up in the lathe and take off about 3/32 so they’d fit in the existing frames.
They don't roll quite as well, but I only move that cabinet a few times a year, so it isn't a big deal. I've had 5 of 6 of these casters delaminate like that. All were purchased from Woodcraft.
Lee
Won’t go flat
dwasifar
Last time I changed the oil on my wife's Forester, I discovered the oil filter had failed. The filter media had torn away from the end caps due to bad pleat spacing and inadequate glue. I got a dozen of these from RockAuto.
It's been a few hundred miles since then, and I decided to pull the filter and inspect it. In that short time, it had failed in exactly the same way, for the same reason.
Here are pictures:
You can see the glue line where it was attached, and how the pleat flattened out against the inner core.
This is the other end, and it's a lot worse. When the glue failed on one end and pushed the pleat flat against the core, the other end simply tore and left a big hole.
I wrote to RockAuto, but it's past the 30 day return and warranty period so I doubt they'll do anything. Though I did point out that 30 days is not enough time to use 12 filters and find the flaws in them.
They were listed as private-branded Pro-Tec by Wix filters, and they came with AutoExtra branding. Caveat emptor.
Follow-up to this.
As expected, RockAuto won't do anything. So I contacted Wix. The nice lady confirmed it is their product, but she states these filters are past their shelf life and should be discarded. I schmoozed hard on the call, and she agreed to look at some photos, which I just emailed her, so maybe someone at Wix will do a courtesy exchange. I have ten of these left.
I did not know that oil filters had a shelf life or were sensitive to storage conditions. I have a hard time believing that second part, considering the wide range of conditions they experience in use, but I did not want to start an argument on that call because schmoozing. Let's see if anything comes of it.
2001ZR2
Kansas City
As clean as bottom will without repaint of the drawers.
Rust on bottom drawer and the bottom of the cabinet is much worse from the mice.
The top has lots of patina on the drawers maybe too much and again the bottom is rough and rusty because mice have no bladders.
Has more of a mustand yellowbrown hue to me in person. But other drawers are the same.
M.Brane
1 hr N/W of LA LA Land
It'll be fine. The patina on a classic box like that is a badge of honor. Clean it, clear coat it, and don't look back.
LeonardY
Southern California
Once you fill it with Grid infinity grids and boxes you'll forget all about the rust. ;)
SMOKEYBEAR
Saturday was "make a 2004 Mustang radiator fan fit a 1973 Mustang radiator" day. 1f642.png
Between other tasks, Sunday was "make a radiator cover" day. Just like the '65 C10 build, even though we're in a hurry to get this car built, it doesn't mean we're going to cut any corners. The top of the radiator needed some dressing up. Dad will get it painted this week and we'll hopefully do the final install of the radiator next weekend.
This started out as a pallet rack brace. A little choppy chop, weld, rotabroach, and dimple die later, we've got a radiator cover.
My position on "the scale" is going to require you to center that fan on the radiator.
SMOKEYBEAR
Kitchen table bench is in the first stage of the glue up/ clamps. I have 6 pieces that will get glued and screwed to the inside of the skirt next. Probably wrap it up tomorrow then put some finish on it later this week. I'm thinking it's the last wood working project for a bit. Boat maintenance and fishing prep is next and some PM on my mom's new to her vehicle.
If the pics every get to my email. I'll upload them...
Beerhippie
Far NE Oregon
A great day doing some of my favorite things!
Cleaning a Rinnai.
Cleaning and unclogging the grease trap for the kitchen dishwasher. Oh, joy! Be still, my beating heart!
A previous coworker installed the trap. It sits on the floor and he did put in a clean-out next to it so the drain for it could be snaked. The cleanout is level with the bottom of the trap. The trap is full of nasty, slimy, grease slurry.
So you can't unscrew the pug on the cleanout--which you can barely reach, anyway--until the trap is empty. I used one of those drill-driven self-priming pumps that I bought for glycol transfer to empty the grease trap--three five gallon buckets full. Spilled rotting grease slurry all over my boots.
Decided that was beyond stupid so I fixed it.
Now the cleanout is above the level of the grease trap--and I can actually get to it.
Still cleaning a Rinnai.....
Mike S.
Charlotte, NC
I've been cleaning up some steering knuckles that I picked up from the salvage yard. Normally I would just hit it with a wire wheel and then powder coat. This time I picked up some Evaporust to try out. Wow, what a difference.
I've always assumed that cast iron was just a dark brownish color when it was cleaned up... and all this time I've been powder coating over a hard coating of rust.
nkachur
Manitoba Canada
I tackled a project long overdue. I inherited my grandfather's leg vice and have been using the piss out of it for years now. The handle was used with a snipe at some point to press something out, likely by my grandpa. It has been a giant pita everything I have used it.
Today we made it better. Bought a piece of 5/8 tool steel a few months ago and did a little surgery. Saved the old ends for the rod.
Lathed them down cross drilled and pinned them in place in the new rod. Almost like a new vice but 1000x better.
ObnoxiousFumes
Southwest Sask
Gasoline is a pretty effective fire starting material too.........
Given the vast number of terrible stories of gasoline explosion burns I’ve heard, even on this site alone, let’s maybe not recommend that method… lol.
Best way I’ve found if you have to use gas is pour a little in an empty tuna can or similar, set it under what you want to burn and light it. It burns slow because it only burns what is evaporating off the top. Works great.
nah, burns off too quickly on the PNW wet wood, I've heard diesel is the way to go.
This quote was supposed to be below Kay’s, I messed up lol
Yep, styrofoam dissolved in gasoline. Sticky mess but burns a long time.
Motor oil, used.
Used oil or diesel for the slower burn, but cut it with a little gasoline to get it to ignite a little easier.
mm08822
While pushing a broom around wondered how I've been able to accumulate so much **** while at the same time tried to figure out where I can fit more stuff that I have yet to buy in there...
If you really want to beat yourself up, ask yourself what year did each item get brought in.
And then, what have you done with it since then? (Playing tetris with it doesn't count.)
And then, when will I use it/fix it, etc?
bmwrd0
Beaver Fever Oregon
Spent yesterday getting all of the stationary equipment in the shop placed where I wanted it, as much as possible.
and the other side
The shop is a 11'x13' room in the basement, so not much space to fit all of this, but I made it work, if just barely. I will probably switch the grinder with the small Gerstner stack, but other than that I am pleased that I was able to make it work.
Now, time for the cleaning and purging.
M.Brane
You always wear sandals while metalworking?
WisJim
Menomonie, WI
I appreciate seeing what you are doing with that amount of space. I have about 11x23 in my room but there's a deep row of shelving along one long wall. I have a 9" South Bend and a 12" Atlas lathes, a Grizzly mill-drill, a Craftsman floor mounted drill press and an Atlas horizontal mill, plus tool chests and grinders. And a large vise and an arbor press on a bench also take up space. I need to do more organizing of space and the stuff stored on the shelving along the wall.
bmwrd0
Beaver Fever Oregon
I should probably put together a tiny shop thread. I did one years ago on the vintage side, but could stand to expand on it.
CoogarXR
The new garage doesn't exist yet, but I was virtually "inside" it today, drawing up the bathroom floorplan, designing the drain pipe placement. I've gotta get those pipes dug in pretty soon, but I obviously need to know where they'll be first, lol. I kinda wanted to dig them in today, but it's so mushy and wet out there...
Then I started the Cougar up and drove it up and down the driveway. Just a little bit longer, and it'll be "fun car" weather.
Then made a little redneck solar light for my wife.
Beerhippie
Far NE Oregon
Put stuff away from yesterday's plumbing project. The pub is closed Mon-Wed, so there was no hurry.
Since we've recently reduced staff, I was informed that cleaning the grease trap weekly is now part of my job. Oh, joy.
Worked on the solar light system for our sign out front. I've been keeping one 15AH LiFePO4 battery on the charger overnight (trickle charger) while the other was in the sign, then swapping them out every day we're open. Not all that onerous, but I have solar panels out there for a reason.
I realized that the trees had grown, shading the panels longer in the morning than they used to, plus I'd swapped out the 4 Watt lights that were on the sign previously for some real purty 15 Watt floods. While the big floods looked great and really lit the sign up, they were too much for what the poor panels could replace during the day--especially the short, dark winter day.
I replaced the 15 Watt light fixtures with some new 4W ones. They're made by the same company, so still look nice, but have easily replaced and inexpensive bi-pin bulbs.
A fifteen minute job. I think I might have spent less than two hours on it. I had to remove the old lights, bring them back to the shop--it's miserable outside today--solder on some extensions on the cords for the new lights, heat-shrink the splices, etc. Then wallow out one of the holes through the posts for the sign as it had swollen nearly shut, snake the new wires through, and... the damned threads on the lights that are supposed to be 1/2" NPT aren't threaded far enough to go in the plumbing fittings I have on the sign.
I mean, really, these light fixtures ain't cheap and I still have to do this?
Anyhow, got 'er done:
I just have to wait 'til after dark to do the final adjustment on them and then LocTite the pivot knobs to keep the feral children from unscrewing them--again.
Taking the sign down and getting it repainted by a local artist is on the Spring to-do list.
Now to chase a glycol leak in the fermenter hall....
kaymccampbell
Upstate New York
Wrote and tested the time lapse cam code. Wrote the Sonoff plug corruption code, so it plays in my ecology. Spent hours testing, hating, putting on the jumpers, rewriting, reloading, ad nauseum.
Moved the power strip in the printer enclosure. Installed the remote plug. Powered up the printer. Printed a couple cam cases. Took a couple tries. Installed the cams in the cases. Installed the burner cam case in the burner. Powered down the printer.
Made an epic mess.
IMG_20260217_151108.jpgIMG_20260217_175319.jpgIMG_20260217_175349.jpgIMG_20260217_175625.jpg
img_20260217_175728-jpg.2492214
