Pneumatic spindexer and Collet ID
no704
Looking for one? Found this, not a precise application, so this might be acceptable. Anyone know of any similar units that might be a little more quality?IMG_0023.jpeg
N
no704
Holds and spins a little 3/16”x2” capsule and spins it while another stepper motor drives a tube cutter to open it. Im currently using a manual spindexer modified with a solionid to lock the draw tube while another stepper the same one that does the rotation can tighten or release the 5C collet. It’s kind of overly complicated and difficult to get a positive confirmation of the state of the collet. The pneumatic closer could simplify this a bunch.
RoninB4
Under My House
-How many of the capsules need to be done per batch? There's several makers of spin fixtures (doesn't sound like you need indexing) that range from multi-thousands (Newbould) to relatively cheap (Chi-Wan), some are motorized. What does narrow the field is your wish for pneumatic actuation. That's going to drive the price up, as all things in the world of automation are. The mechanical tightening is far more simple/inexpensive. If I understand your application you really don't need the concentricity the first 4 makers below are capable of. You can always shop E-vil Bay for a used one at a greatly reduced price, I bough 2-3 of them in good working condition. A motorized attachment could be easily rigged or purchased. I'll leave it to you that know what will work to research the names below.
Newbould
Harig
Suburban
Schmidt
Chi-Wan (some of them have a collet closer
N
no704
Newbould
Harig
Suburban
Schmidt
Thanks for the reply! Sounds like you have some experience with this sort of thing. Im always interested in of the shelf options! The challenge with this one is the tube being opened will be highly radioactive. So this needs to work, reliably with at least 50’ between it and any person. Can and will have cameras on the subject. This initial stage would only be for test runs and one radioactive sample. But what is learned will be applied to later production runs.
N
no704
We are just a little start up company, but we have a great team of very talented people. If you would like to consult I would certainly be open to that! Working in a space that is pretty much brand new we have to be creative to find soulitions to our challenges.
RoninB4
Under My House
-With spin fixtures and indexing fixtures, yes. On the job I used them daily and sometimes all day long. Both are pretty much a standard piece of tooling in die shops that gets used a LOT.
-A large criteria for these is concentricity, you don't seem to need that so very much. With all of the most common models I've mentioned (except the Chi-Wan models) you'd be paying a lot for something you won't even use.
-Something I should have expected to show up with you. Won't this make the fixture radioactive as well? Pneumatic driven rotation may not have enough torque for a parting tool or tube cutter. What is the capsule made from?
-Which is why you asked for pneumatic actuation. Will electric work? I'm at the end of my radioactive knowledge.
-If the fixture will become radioactive this is all the more reason to hold the expense down, no point in making an expensive spin fixture untouchable for further use.
-Interesting application
N
no704
Rotation is handled by a stepper motor. Fixture should not get (very) radioactive! Cuts a 3/16”dia 0.019” wall Ti tube.
N
no704
Slow boat from china finally arrived!
Of course this thing doesn’t take 5c collets. Any idea what kind of collet would fit this. Here is a rough sketch. Thanks.
N
no704
Got a collet closer. But its not a 5c. Any idea what type of collet would fit this thing? Rough skecth
N
no704
Might be a 3AM? Thx for the chart! Ill have to try and pull it apart to check the threads.
N
no704
Nearist i can find on charts is a Hardinge 32S. They seem to be unobtainum. Hardinge wants $400 for one! I have a message out to the ebay seller.
N
no704
noid
I know nothing about collets, but the latest AI model says 3AT?
RoninB4
Under My House
-Thread is way undersize for a 3AT, so is body OD, overall length isn't nearly long enough either for threads to engage IF the OP drawing is correct and those are external threads. If internal threads then the OP needs to work on making a better drawing.
alfadan
Augusta, ks
-Thread OD, body OD (less critical), and head angle are wrong.
-32S may not match the OP supplied drawing. Thread designation important to determine (inch/metric) but not on OP drawing
I was mostly going off that the ad he has in the other thread, says it's a type 15 collet closer and that appears to be a common size in some places. I do think some more measurement is called for.
Cruzan80
Denver, CO
I am reading it as he is claiming "A" is .775, "C" is .675" and "B" is 3.13. Which post to more of a chance of being a 3AM (if he accidentally measured the root of the thread as .675 (essentially D, but I know that is for an internal thread), vs the outside of the thread). Especially if he was using something like a ruler vs a caliper/micrometer.
N
no704
I did turn down q hunk of uhmw today and screwed it into the collet closer. Turned to .695”’and treaded it into the the closer. Came out .710 od and 24 tpi near as i can tell wasn’t even close to any meter piitch.
N
no704
I used a caliper and a telescope gauge to make these measurements. I wish i was with in mic measurements!
N
no704
Please keep in mind that that i am measuring the holder, not an actual collet. So i would expect a little slop in that.
N
no704
Why anyone even the Chinese would ivent a new collet size is a mystery to me? I was fully expecting a 5c.
RoninB4
Under My House
-That was not made clear in this thread but you drew the collet. Hazard of two separate postings on the same subject.
-Not to be a d*ck about it but I would expect:
1) More/better detailed info from someone doing nuclear work
2) A more clear explanation of what/where the dimensions came from
3) Some standard markings/symbols on the drawing like (ID/OD, TPI, major/minor diameter, etc.) for clarity on dimensions
4) A far better drawing than what was submitted. I took 3 minutes to sketch what you posted, it's far more legible and none of my lines are straight. If it was important enough to post this wasn't it important enough for the rest of us to decipher it? The multiple replies, besides mine, displayed confusion and warranted better info.
-This should not be construed as a personal attack.
RoninB4
Under My House
Turned to .695”’and threaded it into the the closer. Came out .710 od
-Do the math, converts to a nominal metric size.
and 24 tpi
-Also converts (nearly) to a common metric thread pitch
-Geez all that expensive equipment and you don't even have thread pitch gauges?
-In light of more info it probably isn't a "new" collet size.
-Ordering equipment from Chi-Wan and expecting what is commonly used in America? The domestic market here no longer dictates what they make/sell. They have developed their own market over the decades that demands we all dance to their tune for the most part. There are several reasons for them to use proprietary components, this instance just happens to be outside of those reasons. JMO
N
no704
Sorry im not up to your standards! Was just the sketch i made while on a zoom meeting. I wasn’t expecting anyone to build a part off of it. Just some general dimensions if someone was aware of something close. And ive had a rough week. Dad got a pacemaker inserted after passing out during breakfast, and they are installing a new gas line in my backyard.
RoninB4
Under My House
N
no704
Ebay seller replied its takes a 25 Type closer. Have not had anu luck finding such an item. Waiting on reply on where to purchase?
PCustoms
VT
I'm confused, are you looking for a collet or a closer?
These threads are very unclear
Cruzan80
Denver, CO
So you are measuring a holder, need a collet, and the seller (who sold you the holder?) told you it takes a "type 25 closer". Is all that right? If so, why did you buy a holder for collets you don't have, without knowing what it takes?
