nadogail
Coronado, CA
Made, what I think is enough legs to complete all the planter boxes I had under construction.
It appears that I will be scaling back my workshop activities, my legs just aren’t what they used to be.
Because my family has decided I need to be limited to “Protective Custody” so that I won’t hurt myself; I will be giving some serious thought to shutting down my shop.
dwasifar
Fixed an audio mixer.
I had two Behringer eurorack 602 mixers, one with a damaged output jack that wouldn't accept a plug, the other with a flaky level control pot. Tore them both down and replaced the flaky pot on the second with a part cannibalized from the first.
Works fine, though I cannot answer why I felt this was worth my time for a 21 year old bargain basement device that currently sells for about $20 used. Maybe I just wanted a project.
2001ZR2
Kansas City
I am becoming convinced that the mouse odor is embedded in the rust from them not being house broken.
Those are the 20 slides from the upper box after being soaked in all purpose cleaner and cycled through the ultrasonic cleaner. Replaced the one missing clip. So they are good to go.
The plastic tub they are sitting on has the slides from the lower 12 drawer cabinet. Need to replace 4 missing clips and another that seems bent up.
Removed some double sided tape from the front of the upper box.
Not the longest work session but productive.
DGersic
DeKalb, IL
Weather here is crazy. Record setting warmth yesterday at 66F. Upper 50s, pushing 60 today. Taking advantage of,started tearing down this Workmate I picked up last fall.
A trip to Menards for supplies. Cut some 3/4” plywood and 3/16” “dry erase marker board” to size.
Laminated with contact cement.
Touched up the paint on one of my bird houses.
SMOKEYBEAR
It's offset to provide clearance to FEAD; the components on the driver's side are a full belt width closer to the radiator.
I figured there was a functional purpose, your project is to nice to have it off set/ asymmetrical otherwise.
SMOKEYBEAR
Retrieved clamps to glue up the bench. The task of getting pictures from my phone to the computer has been a challenge, I send them and they arrive when ever. It about wrapped up. It has its first coat of Tung oil on it as of last night.
Oil pump for the Mercury showed up yesterday. The bench project will be complete by Sat am. Boat is next.
Hooked
League City, Texas
Two ways I solved the phone to computer problem. First was to connect my phone to the computer using usb cable connection which worked okay but kinda time consuming. Second, and current, method is to connect via bluetooth and selecting individual files to transmit. Very quick and easy (once you figure it out the first time).
Hooked
League City, Texas
Put stuff away from yesterday's plumbing project. The pub is closed Mon-Wed, so there was no hurry.
Since we've recently reduced staff, I was informed that cleaning the grease trap weekly is now part of my job. Oh, joy.
Worked on the solar light system for our sign out front. I've been keeping one 15AH LiFePO4 battery on the charger overnight (trickle charger) while the other was in the sign, then swapping them out every day we're open. Not all that onerous, but I have solar panels out there for a reason.
I realized that the trees had grown, shading the panels longer in the morning than they used to, plus I'd swapped out the 4 Watt lights that were on the sign previously for some real purty 15 Watt floods. While the big floods looked great and really lit the sign up, they were too much for what the poor panels could replace during the day--especially the short, dark winter day.
I replaced the 15 Watt light fixtures with some new 4W ones. They're made by the same company, so still look nice, but have easily replaced and inexpensive bi-pin bulbs.
A fifteen minute job. I think I might have spent less than two hours on it. I had to remove the old lights, bring them back to the shop--it's miserable outside today--solder on some extensions on the cords for the new lights, heat-shrink the splices, etc. Then wallow out one of the holes through the posts for the sign as it had swollen nearly shut, snake the new wires through, and... the damned threads on the lights that are supposed to be 1/2" NPT aren't threaded far enough to go in the plumbing fittings I have on the sign.
I mean, really, these light fixtures ain't cheap and I still have to do this?
Anyhow, got 'er done:
I just have to wait 'til after dark to do the final adjustment on them and then LocTite the pivot knobs to keep the feral children from unscrewing them--again.
Taking the sign down and getting it repainted by a local artist is on the Spring to-do list.
Now to chase a glycol leak in the fermenter hall....
I had some lights very similar to those to illuminate my flags. However, I discovered (too late) they lens were not sealed sufficiently to prevent leakage so the housing filled with rainwater and destroyed the fixtures.
I'd be interested in the brand you are using. May work for my flag light.
Beerhippie
Far NE Oregon
I'll have to check the brand. I got these from Azon, but they're dead-ringers for the much more expensive PAR 36 fixtures I got from Volt lighting.
On both, the front lenses have very nice gaskets. They wrap the edge of the lens, like a thermostat gasket in your vehicle. I've never had a problem with them leaking over about twenty years of use outdoors.
Ah, here they are:
They're identical to the Volt fixtures--other than size and bulb type--in every way, including the not-quite 1/2" NPT mounting.
I have several of the Volt PAR 36 15W fixtures with bulbs, in good condition, that have been surplussed from the pub yard over the years. If you're interested, drop me a PM. They'd do fine for flag lighting.
M.Brane
1 hr N/W of LA LA Land
Have only visited the beer fridge lately since I've been working 12hr night shifts all week. Was an interesting night last night. There are only 2 of us on a shift to cover nearly 100 lane miles of remote mountain road with no communications. It was pouring last night, and the wind was intense. Flooding, debris flows, large rocks, downed trees, 40+ miles of snow, and subfreezing temps. WOOHOO! I just have to make it until December. So done...
Beerhippie
Far NE Oregon
The fermenter I installed a couple of weeks ago was leaking coolant. Not a lot, but every little bit matters.
After careful examination, I was able to narrow the leak down to which fitting it was: All of them! Our local plumbing/electrical place carries some Made in Vietnam SS threaded plumbing fittings. They're a biatch to get to seal. I think part of the problem is that the very hard SS threads aren't conformable--they don't deform on tightening--and they're being threaded to equally hard SS ports on the ferm.
I spent far too long getting the glycol coolant drained and getting the thickest pipe dope I have worked deep into the threads. I seem to have gotten it--but it wasn't leaking immediately after I put it together the first time, either. Fingers crossed.
I also realized that I appeared to have been drinking heavily (I wasn't) when I installed the ferm the first time around. For reasons unknown, I had the solenoid valve in entirely the wrong place--in between two of the three cooling jackets. The problem with that is that the solenoid opens and closes FAST, causing a hydraulic shock upstream of it. With a flex line to absorb the shock, it's not a problem. When the valve is mounted directly to the fermenter, it would eventually cause the welds of a jacket to fail.
This is the proper way to plumb it:
Coolant enters through the solenoid valve at the top of the jackets and exits the bottom.
Now to check and make sure I didn't install the valve backwards again.
Wrench97
Southeastern Pa
Sometimes you need tape(the thicker kind) and pipe dope together to make them seal.
Beerhippie
Far NE Oregon
Two of the male NPT ports of the fermenter are located on the cone, making the use of tape nearly impossible.
I did use Gold End industrial-grade tape AND Rectorseal T plus 2 dope last time. This time, I used Gold End dope and no tape, That Gold End stuff is nasty, but it seals. Getting the male threads clean and dry enough for the dope to stick and get worked down into the threads was the hard part. Pipe dope just plain ain't stickin' to threads contaminated with glycol-based coolant.
micromind
Fernley, Nevada, about 30 miles east of Reno.
I've always ran coolant in the bottom and out the top. This way, it keeps air out of the system.
Beerhippie
Far NE Oregon
We've had problems with stratification and the bottom of the ferm freezing doing it that way. Having the cold come in at the top seems to establish a thermo-siphon action inside the tank, preventing stratification.
Our glycol system is "open", so a little air doesn't matter as much as in a "closed" system.
ObnoxiousFumes
Southwest Sask
Yeah we always use Wolverine Brass’ “The Beast” tape (it’s nice and thick) and Masters Metallic dope on all our stainless steam systems, rarely if ever do they leak.
HOWEVER, you cannot use Masters Metallic on food/beverage systems as it has a rather high lead content.
But yeah, tape will help the dope to stay put on the otherwise slippery threads of a stainless pipe.
GrayFlattop
Chicago
I’ve had a hell of a time getting stainless npt fittings to seal reliably. It seems like there is always one or two that end up weeping. This happens even after chasing the threads with a fresh tap and die. For me, the only reliable solution has been -all of the above - plus using the modern version of thread packing cord- loctite #55 packing cord. Apply the cord exactly as the instructions describe. Plus a little extra. I also use loctite 567 goop.
Beerhippie
Far NE Oregon
Just for fun, after I knocked off, I spent an hour back at the office move project. Hauled away two more 55 gal. trash bags of... well, trash. Did I ever throw anything away?
I'm also discovering that I own HUNDREDS of music CDs I didn't know about. I mean, like real retail studio CDs, still in the jewel cases, some still in the shrink wrap! How did I accumulate so many? Why didn't I rip them, when I had the ideal set-up? How did I forget them?
I'd love to rip them all and then sell them, but I may just be too damned lazy--and greedy. If I get a buck each for them, that's a fair amount of foldin' money. I have a few hundred I've already ripped, so I have a decent digital music collection as is... but it could be a lot bigger if I'm not too lazy.
But I may be too lazy. And greedy. Project Vanagons are expensive.
GrayFlattop
Chicago
But I may be too lazy. And greedy. Project Vans are expensive.
Too bad you’re so far, I’d ****** em up. I still believe in physical media. Vinyl is preferred, but a well recorded cd can be quite enjoyable.
LeonardY
Southern California
The battery on the truck was close to the end of it's useful life. I have charged it a half a dozen times. It dies after less than a week.
Took the old battery out. Headed to Costco early since they give executive members an extra hour of shopping time.
The truck takes a 27F or a 24F. Originally had a 27F but my Costco didn't carry them. When I got there I saw that they had the 27F size and it was $20 less than the 24F. Score.
The only thing that is difficult is lifting the old battery out and putting the new one in. It's done.
Beerhippie
Far NE Oregon
There's 600+ CDs on my shelf as i sit here looking at it. Cant remember the last time i listened to one - usually i'm pulling one down and ripping it to a lossless flac file for my phone
Yeah, I'm also remembering that ripping CDs isn't as onerous as vinyl. It was kind of cool being forced to listen to the entirety of a vinyl album to rip it, but it took a while. Then Audacity for another hour to set tracks, levels, titles, etc. I did a couple of hundred over a couple of years.
That was a while ago. It's probably even easier nowadays.
bmwrd0
Beaver Fever Oregon
Vinyl is to listening as hardback books are to reading. The entirety of the experience is more than just the sounds/words, but also exists in the viewing of the cover art, the reading of the liner notes, the enjoyment of the font, the tactile feel of the book in your hands, the smell of paper, and so on.
Both create an immersive experience, one that takes you away from the modern, digital world.
Hooked
League City, Texas
Ah, here they are:
For some reason I thought you had battery/solar lights for the signs. I have no electric to my flag pole or I'd take you up on the old lights. Thanks.
DGersic
DeKalb, IL
Been there, did that. It’s not.
Vinyl recorded to digital with Audacity. Track separations. Maybe some edits.
Export to WAV. Export track labels to text.
WAV processed to remove clicks and pops.
WAV to MP3 processed with LAME. Tagged with album, artist, and track titles.
MP3 imported in to iTunes. Cover artwork added. iTunes to phone.
But now I get to listen to all of my vinyl stuff again.
Along the way, Audacity changed their file format, and the new version cannot read the old files. Fortunately (?), it’s an XML file, and I spent a lot of my career hacking XML. I was able to reverse engineer the changes needed from old to new, and hand hack the changes in to my old files to the point where Audacity would read them again.
Beerhippie
Far NE Oregon
One thing I learned from ripping vinyl to digital files--I mostly listen to MP3 at high sampling rate--is the difference in dynamic range. The vinyl has a much higher range--the difference between loudest and quietest sounds--than even 32 bit MP3. When setting the levels, you have to decide what to lose--if you "clip" the high levels, it comes across as as loud CLICKs in the sound. If you clip the low levels, you lose them--but without audible artifacts.
But now I'm entering the second half of my seventh decade and I find that any difference between audio recording tech is inaudible to me, anyway. Hell, I can barely hear the difference between my Bose 901s and a pair of Radio Shack speakers anymore.
I do have solar--which is why I switched from the 15 W PAR 36 lights to the 4 W bi-pins. If you have a better solar set up, you could still use the 15 W fixtures.
Skyman
Central Maryland
I'd be interested in hearing what CD titles you have to sell, Timm.
