A hydraulic driven molar or bicuspid?? I would just use a chain to pull out a fence post or the thumb on an excavator.Is this for teeth in your mouth . . . maybe not? Something on a tractor bucket? Some kind of device that goes into the hole on a split rail fence post and pulls it out? Incisor, molar, bicuspid?
Winner. Lots of ingenious people out there. Thought someone may have built their own and would share a few pics.A wood post incisor puts small cuts in the southern yellow pine before pressure treatment to ensure enough chemical gets into the wood.
YesAre you trying to treat lumber you have sawn and dried?
That sounds interesting. Any idea how deep you need to incise?
Thinking 3/8". 100s of posts. I have a tank with and apparatus that will fully submerge at least 20 at a time. Still brainstorming on the building of the incising part of it.That sounds interesting. Any idea how deep you need to incise?
How much are you trying to do?
I looked up the process used commercially to make PT lumber.
Key details about the pressure treatment process:
Modern pressure-treated wood generally uses copper-based preservatives to prevent rot and decay.
- Methodology: A typical treatment involves an initial vacuum to remove air, followed by flooding the tank with preservatives and applying 140–150 psi for several hours.
- Alternative Pressure: Some methods may use 160 pounds of pressure to ensure maximum saturation.
- Final Stage: After pressure application, a final vacuum is often used to remove excess chemical from the surface.
- Moisture Content: Because of this intense, liquid-based process, new pressure-treated wood is usually very wet and heavy, often requiring time to dry out before use.
Wow, that's legit.Thinking 3/8". 100s of posts. I have a tank with and apparatus that will fully submerge at least 20 at a time. Still brainstorming on the building of the incising part of it.
I don't think an infeed roller can apply anywhere near enough pressure for this. They are applying just enough force to introduce the material to a chipper bladeLook at the infeed roller design on commercial wood chippers, that should give a basic idea of how it would look. Where the wood chipper uses a segmented type roller to grab the stock an incisor uses what looks like saw blades put on backwards.
That's easy enough to overcome with some flow control valves and creative thinking.I don't think an infeed roller can apply anywhere near enough pressure for this. They are applying just enough force to introduce the material to a chipper blade
Coastal doug firWhat species of wood are the posts?
I suspected as much. Incising for treatment is not done on SYP east of the Rockies. SYP accepts the treatment under pressure alone quite well.Coastal doug fir
That would make this a lot easier for myself.I suspected as much. Incising for treatment is not done on SYP east of the Rockies. SYP accepts the treatment under pressure alone quite well.
How do you know treatment was after drying?I have found that purchased lumber that was treated after drying has a much more deeper, more complete penetration, Of course it's all SYP in OK, but the difference is obvious, especially on 4" stuff.
Maybe instead of the incisor, a dryer kiln?
The info is in the stamp or tag on every board.How do you know treatment was after drying?
I've only ever seen KDAT called out which is drying after treatment. It's much nicer to work with as it's considerably lighter and doesn't shrink as much
KDAT deck boards stay nicer looking for far longer.
Dam, you stole my joke!Hire a beaver & program him for just taste it mode.![]()
This is VERY interesting to think about. An ever so slight upward and outward angle on the sprocket shaft to match the infeed rate as to not "push/pull" the sprocket. My initial thought was that the sprocket is too blunt. Maybe I could sharpen one to a point for better incisions or cut out a 1/2" steel circle, 6" diameter, 1" bore on a 1" shaft or so, with my track shoe spikes drilled/tapped every 3/4" around it. Now you got me thinking.Round post makes it a trickier perhaps
I'm envisioning a motor driven system that spins the log and pushes it through
Something like sprockets set at a angle, they would not only push and spin but also penetrate the wood.
Set a few up on a drive chain, small electric motor with infeed outfeed tables and go to work
