Wrench97
Southeastern Pa
The frame is 37.5”. Cab and chassis used 2.5” springs, so not what I am dealing with.
That's Ford engineering for 38" frames................ :lol:
No it changes by the year some are 37.5 other years are 38 but everyone calls them 38", sometimes when you look up fuel pumps it asks if it's a 38" or 34" frame, different size tanks take different pumps.
swsman
Earthbound
Not my garage, but at a friends repair shop.
2011 Impala 3.9V6.
Back valve cover gasket had a leak.
What an ordeal to get the valve cover off.
Coolant crossover pipe assembly covers one of the 8mm bolts for valve cover.
Remove serpentine belt
Alternator has to come out - for one of the three bolts a half moon wrench is needed to get it off
Remove three pulleys to get to 15mm bolts for the crossover pipe
Power steering pump has to be moved too
Some other bits
Not done yet, tomorrow I will install 2 new coolant crossover gaskets and button it up. Fresh plugs, will be getting new coolant as well.
Friends and family, tell them to avoid these cars unless they can do their own work. Quality is meh.
At 95000 I have replaced rack and pinion, passenger side engine mount, passenger side wheel hub assembly (ABS wiring broke right at the sensor - could not solder what was left), HVAC actuators (2 on passenger side). It was my parents second vehicle, not abused.
As soon as it is all back together up for sale it goes. Much prefer working on Honda/Toyota/Mazda passenger vehicles myself.
Edit.
Car is done, both front and rear valve cover gaskets have been replaced.
New coolant crossover pipe gaskets.
New spark plugs.
Not really a lot where one can shave time, save for when it comes to front valve cover gasket. No need to remove a bunch of stuff.
I loosened inlet/outlet heater core steel tubes (2 13mm bolts holding the brackets).
Removed front 3 sparkplug wires.
Removed passenger side dog bone mount (upper only).
This gave me plenty of access to remove front valve cover. Had access to all four 8mm bolts with 1/4 drive ratchet/small extension/deep socket.
I also have to compliment both 1/4 drive flex head ratchet (Pittsburgh Pro), and my recent addition - Tekton 3/8 stubby. Each gave me plenty of access and no noticeable backdrag, which made the work in tight quarters great.
wolfhawk73
Eastern North Carolina
The fermenter I installed a couple of weeks ago was leaking coolant. Not a lot, but every little bit matters.
After careful examination, I was able to narrow the leak down to which fitting it was: All of them! Our local plumbing/electrical place carries some Made in Vietnam SS threaded plumbing fittings. They're a biatch to get to seal. I think part of the problem is that the very hard SS threads aren't conformable--they don't deform on tightening--and they're being threaded to equally hard SS ports on the ferm.
I spent far too long getting the glycol coolant drained and getting the thickest pipe dope I have worked deep into the threads. I seem to have gotten it--but it wasn't leaking immediately after I put it together the first time, either. Fingers crossed.
I also realized that I appeared to have been drinking heavily (I wasn't) when I installed the ferm the first time around. For reasons unknown, I had the solenoid valve in entirely the wrong place--in between two of the three cooling jackets. The problem with that is that the solenoid opens and closes FAST, causing a hydraulic shock upstream of it. With a flex line to absorb the shock, it's not a problem. When the valve is mounted directly to the fermenter, it would eventually cause the welds of a jacket to fail.
This is the proper way to plumb it:
Coolant enters through the solenoid valve at the top of the jackets and exits the bottom.
Now to check and make sure I didn't install the valve backwards again.
I had to plumb a test system at work that had over 600 threaded stainless joints (fittings made in China) from 1/2" to 3". Our engineer said to use some soft-set garbage and no tape. I argued, but he was adamant, so half of the joints leaked. I told him to go away and let me fix it. I spent four weeks replumbing it with lots of cheap Teflon tape and Rectorseal Tru Blu. The pressure in the system alternates every 3 minutes from zero to 5 bar for 8 weeks per test. No leaks in the seven years we've had it.
Beerhippie
Far NE Oregon
Pushed snow. Puttered around the brewery doing chores and putting out minor smoulders. Spent some more of someone else's money.
Knocked off for the afternoon and worked on the Vanagon again. Threw more money at a problem I'm having with it.
Got the ladder remounted and de-rattled:
I'm building a roof rack basket for it and will need some way to get up there. It also adds to the general bad-assery of the lifted Van.
De-rattling it was fairly easy:
The piece of hose puts enough pressure against the jack point I had to use a clamp to compress it enough to get the pin in.
Added some horsepower to the engine:
I figure an OEM Subaru badge has to be worth at lest five ponies, don't you?
I wanted to get more done, but it started into snowing and blowing again.
dscheidt
I fixed my square. One of my PEC 12" squares has never clamped the blade right. Several years ago, I bought replacement clamp assemblies for all of them, because it seemed silly to pay $10 to ship a $2 part. I normally use a different square, but the bad one was out, so I was using it, and it pissed me off enough that I remembered I had a new clamp. IMG_5127.jpg
I can't imagine why it didn't work right.
SMOKEYBEAR
Swapping out the oil pump on the 2 stroke. Its been seeping and it's time. Pricey $$$ sumbitch, but so is a new motor and it feeds the compressor which is a significant component to the fuel system and motor on a Pro XS series Mercury.
Ike Carlson
Wisconsin
Well, either way it’s going back together the way it is. I need the shop space and have other projects to do. Have to make some $$$ so my wife can get her audiobook made.
67CarGuy
Outside Boston, MA
Darlin' has been picking up a co-worker the last couple nights because her 2007 Cobalt rear brakes are making a terrible grinding noise. Young, single mom can't be without a ride, and dreading the bill. I rode along last night to her place and drove it back here. I ordered new shoes and drums the other day for $110. Pure metal on metal. Nothing left of the shoes. Mileage is 175K, so guessing original.
Newer style with the one big horseshoe spring. Have owned a Cavalier, Monte Carlo and a Cobalt with the same setup. Much better than the old style with ten springs jumping out at ya and puncturing a finger or catching a flyaway spring in the face. Front discs looked fairly new. All fluids checked OK. Raised the front and rotated the tires. She drove it home this morning. She asked how much she owed me. I said to just fill up Darlin's tank and we're good. And to save for some rear shocks. I want no part of those :LOL:
I know I'm a bit late on this one, but...
You're a good man, Charlie Brown!
PassnThru
Bowling Green KY
With all this CD ripping talk, I have a question. Why do my playback devices not read/play certain tracks? I know nothing about any of this really. I rip CDs on my laptop with microsoft media player (I do prefer the older one), then put those onto a thumb drive or onto my phone. Whether using an aftmarket or factory unit in my cars (I use thumb drive in the cars) or different players on my phone (VLC & double Twist) there are a lot of tracks that wont play/arent recognized. What am I doing wrong?
This is a problem I only encountered in the last few generations of MP3 players. I have over 4,000 tracks in my collection and my newer players only seem to recognize a few hundred.
need to fix that. Maybe a better MP3 player?
I've had recent experience with this. Back when I bought a 08 Taurus for the kids to learn to drive in I replaced the factory radio with an aftermarket JVC unit to add hands free phone along with a backup camera. It included a USB in jack so I replaced one of the power ports with a USB jack. They all had a USB thumb drive with their music on it and all was well.
Later my oldest son bought a 2013 Honda CRV and as I recall he had some minor issues with certain tracks not playing. I don't know what the resolution was (if any) - he is old enough to figure it out himself.
Then my middle kid got a 2017 Taurus and a lot of the tracks on his drive wouldn't play. I don't know if he ever resolved that because again - he is old enough to figure it out.
I know I sound like a bad Dad but they are old enough and tech savy enough to figure it out for themselves if it bothers them.
I don't know why it's happening and I don't know the solution but yes - I've seen it personally.
Beerhippie
Far NE Oregon
That's why a GOOD dad would make his kids not only figure it out, but FIX IT FOR HIM.
I restocked on utility knife blades.
Unfortunately, they came in this:
The only brand the first store I went to had. I have a hate/despise relationship with that style of dispenser--I just struggle to get them to dispense properly.
But I'd just emptied this:
Which is the best functioning dispenser I've ever used. Amazingly, there were no extreme efforts made to the packaging to make it impossible--or even really difficult--to refill the De Walt dispenser.
Is it safe to store Stanley blades in a De Walt dispenser? Could it result in spontaneous combustion--or worse? Stay tuned for the exciting conclusion this time next week!
dscheidt
I’ve had a dispenser like that on the wall for about 10 years. The same one. At the rate I am going through it, I may have it another 10. The utility knives all hold blades, which I refill from another source, better quality and a box that doesn’t stop you from taking three at once. I actually don’t mind it, if I wanted one blade at a time working in a fixed position, or I only used a utility knife twice a year. There’s a little trick to get the blades out , but I can’t ever remember what it is.
Motorman55
South Jersey
Got a few things done in the Hobby/Craft room.
1. Finished painting the wifes storage cabinet green with a cream interior. Added the new black drawer pulls that she wanted. Tried to find the correct size door hinges in black, but they were too big, so I re-used all the original metal door hinges and screws after cleaning off any old white paint on them.
2. Added the first of several wall shelves to come. This one measures 35"L x 11-1/2"D pine board with 3 black wood brackets to hold the TV and tape player.
3. Got a little more work done on the 7' common bench. I doubled up the top and bottom stringers with additional 1x4 pine boards. These I attached using black 5/16" lag screws and washers into the original bench stringers. This brought the stringers facia flush with the legs. Also added black 1/2" lag screws and fender washers to the top and lower legs.
Now all I have to do is add a pair of sliding doors to the left side and it'll be done with the exception of applying some type of rub on finish to all the raw pine.
Beerhippie
Far NE Oregon
With the DeWalt, you open the pivoting drawer and there's a blade just waiting for you there.
I do the blades on a half-dozen ute knives around the brewery and pub. They bring them to me as I guess pushing a button, pulling the blade out and inserting another is hard.
It still took about two years to go through the 75 that were in the dispenser originally, so these 100 should do for a while.
kaymccampbell
Upstate New York
Since I've never seen the second type of dispenser, I just rip open the hated type of package and dump them into a little plastic tub on my wall-o-tubs. Then, since they're above eye level, I fish blindly for blades when it's time.
After seeing one in action, I may just go out and buy one and dump the Terror Tub™.
Prospecter
Maine
Wouldn't you think S&B would go with it's better design for both brands?
PhantomEB
Medicine Hat, AB, Canuckistan
Started to layout the tools from the tool roll that is kept in the daily driver. Had pulled it to bring to the shop when I worked on Ranger Ric. It was a mess and need to re-organize and assess what I'm missing....
I have similar in the back of the truck In a Kuny Bag to boot. But a few multibit screwdrivers in their respective forms, screw drivers, and Torq bits as never know what ya gonna run into. Wrenches are all in rolls and Sockets are in a blow molded case. Need to get pliers and vice grips into rolls too. I am sure I can go to a smaller bag to boot As this bag usually gets plans to thrown in the back of the bronco for its dirt therapy time.
Beerhippie
Far NE Oregon
You just open the drawer
and there's one blade, nicely presented and safe--every time.
larry4406
Northern Virginia
I like that drawer dispenser system. Have not seen that. I have the other style which I rate 5/10 or maybe 6/10.
That high? You must also have come from The Tub of Terror, which I went back to because the stupid black plastic dispenser sucked so bad.
The blade dispenser with the slide out single blade drawer is clever.
Burt Shaver
Iroquois, Ontario Canada
IMG_7165.pngIMG_7124.jpegIMG_7121.jpegIMG_7016.jpegMy brother in law had given me this 05 Ski Doo SDI about 3 years ago. When I first got it I put new pistons and rings in it, new used stator, new used magneto flywheel, rebuilt the rave valves, had the injectors cleaned and I had it running good. But the recoil on it would only catch about half the time so I bought one from market place and put it on, it didn’t work at all lol, so I set th snowmobile aside and didn’t look at for 3 years lol.
Last week I decided to take a few days and figure out those rewinds, rebuilt the original rewind that I had in a box, installed it. Machine wouldn’t start so I ended up draining the tank , had to clean the injectors again and change a fuel tank grommet that the pick up tube goes in, changed the in line fuel filter, go it back together today and it’s working again. 🙂
