supposed to be getting these in blue next week off the truck!Got the 9" LN47ACF set in today.
Already had a use for them as soon as they came in. Used them to pull my tensioner spring on to my mowers pulley after a drive belt change. My old pair of needle nose always seemed to slip off just when I was about to get the hook in on the pulley arm. Not this time though, got it done on the first try
I have the stainless steel version. Great knives for great prices.Today was "inexpensive sharp things from developed nations" day!
Morakniv, carbon steel, 3.6" blade - Sweden - $10.97 Amazon
https://www.amazon.com/dp/B01K27GPUE
Kotobuki thread scissors - Japan - $12.64 Amazon
I already have these -- two knives in the shop, one at each end. Now I want one in the middle. (It's a long shop!) One pair of scissors for house, one for shop.
I have a few Mora knives and they are awesome. You are going to love them.Today was "inexpensive sharp things from developed nations" day!
Morakniv makes great knives. I have one in every tackle bag and several on the boat. They are great and affordable.Today was "inexpensive sharp things from developed nations" day!
the solution to that problem is in that picture....I’ve gotten a lot of mileage out of these small pliers, but I’ve often found myself wanting for cutters to make a quick cut here or there. Enter these 4” cutters from Snapon:
Placed next to my fastback for reference. Haven’t really used them yet but they fit in my cargo pocket without me noticing their presence, which is what i was looking for. Just wish they were offered in a bare steel handle like the pliers ….
I purchased a similar one, with fewer adapters. It makes filling a notoriously hard-to-fill Vanagon cooling system a breeze!
We use Wurth for supplies at work, their hand soap comes in a canister 10"? in diameter and the lid had a 1" hole in it, works great for a catch bottle.I purchased a similar one, with fewer adapters. It makes filling a notoriously hard-to-fill Vanagon cooling system a breeze!
Be aware you'll need a "blow-off" catch bottle for the exhaust of the compressed air. It blows a fine aerosol of coolant.
I have those Olfa scissors in my work tools and my garage. They have been terrific.Thoughts on these if you have used them yet? My Wife says we need to replace our kitchen scissors and I'm eyeballing these. I want to get 2-3 pair if these are good. Amazon rates them very highly and they are made in Japan, so I'm down based on your thoughts.
I have a Deen pair of nippers about that size that I got from my GJSS this year, they're really not meant for large, thick zip tiesFollow up: about 24 hours after taking possession, I was cutting through a large zip tie when I felt the pliers yield and I looked down to find that one of the cutting heads had broken. Not impressed! Sure, I can warranty and all that, but it’s still a bit of a hassle to send it in and wait for a replacement. Let’s hope this was a one-off defect and that I have better luck with the replacement
No, to remove the grips…The knife? No way, the risk of the knife slipping and cutting some neighboring component is too high for my liking. Much safer and easier to use a pair of cutters. Call me clumsy but after an incident where i sliced an air hose wide open while cutting a zip tie, I’ve always used cutters for those kinds of targeted cuts.
If there is room for thick zip tie I cut flush using a razor blade.Follow up: about 24 hours after taking possession, I was cutting through a large zip tie when I felt the pliers yield and I looked down to find that one of the cutting heads had broken. Not impressed! Sure, I can warranty and all that, but it’s still a bit of a hassle to send it in and wait for a replacement. Let’s hope this was a one-off defect and that I have better luck with the replacement
I'm looking at the surface finish. Is it how Snap-On manufactures and sells tools now, or the nippers had rough life?Follow up: about 24 hours after taking possession, I was cutting through a large zip tie when I felt the pliers yield and I looked down to find that one of the cutting heads had broken. Not impressed! Sure, I can warranty and all that, but it’s still a bit of a hassle to send it in and wait for a replacement. Let’s hope this was a one-off defect and that I have better luck with the replacement
yea, looks grinded downI'm looking at the surface finish. Is it how Snap-On manufactures and sells tools now, or the nippers had rough life?
The Tsunoda products are excellent. So much hype about SO, I have a few but not a big fan of SOThose SO cutters do look like ****, straight from the factory floor.
I've been very pleased with these Tsunoda flush-cutters for removing the entire tail from zip ties. The quality of manufacture and finish is excellent, and they deliver a true flush cut. I haven't broken them yet on zip ties, and I don't expect I ever will.
maybe i´ll add a long hose so the aerosol is directed awayI purchased a similar one, with fewer adapters. It makes filling a notoriously hard-to-fill Vanagon cooling system a breeze!
All you need is a bottle--like an empty coolant bottle--and a rag over the top to catch the fine stuff. The hose for the exhaust goes in the bottle, then wrap the rag around the top.maybe i´ll add a long hose so the aerosol is directed away
