1920-60s DELTA / ROCKWELL picture thread - Post your Delta!
Mintgrun
Kingston, Wa.
I shared a pair of saw stands I found back in August along with this photo of a cobbled-up doubled-up table saw. (post 1,076)
I decided to exchange the saw on the right with another one out in the carport that was on a wooden stand and make use of the two new-to-me stands; along with the cast iron wings on the other saw.
I mocked it up upside down and learned that there's a quarter inch height difference between the two stands. Adding little pucks under the feet of one saw seemed like the cleanest solution. This photo shows a shim between the saw and base, but that looked wrong.
Those dust chutes on the underside help pull sawdust away, but the open backs on these saws are a problem. I made a simple cover that works well while the saw is in the ninety-degree position. The dado saw has one, since it's only used vertically and I made a second one for the carport saw before ripping a bunch of aluminum; to help contain the glittery mess.
The local Habitat store recently had one of those home-shop-kits, with a table saw, jointer, sanding disc, drill press and maybe one other accessory (?). They had not priced it yet, but I knew better than to bring another one home regardless. It was missing the base though and I was tempted to go back to the store to donate the large base (in the first image), but wasn't up for another hour and a half of driving.
Tom
chargedmr2
WA
Well, here’s my next project. I’ve been wanting one of these for a long time! I haven’t picked it up yet, so not sure when it was manufactured. Is there any rhyme or reason to the different stands on these. Some have straight/vertical legs, some are much more angled for a wider stance, some are welded together, and some are bolted. And then the motors…I see a few different configurations there, too. Just curious what I’ve got here. IMG_5659.jpeg
jmarkwolf
Southeast Michigan
Your motor is newer than mine, but I've got the same sander with the same stand, vintage 1945, inherited from my dad, and still use it frequently.
Pics of my resto project posted elsewhere in this thread.
chargedmr2
WA
Any idea if the newer style motors like mine were originally paired with the welded stands? Wondering if this was original or if someone added the stand at a later time?
I dug up that pic of your restoration. Looks fantastic! I'm planning to give this one a full restoration as well, bearings and all.
Jayman17
Seattle, Wa
Just curious where you found this, FBMP or somewhere else? Nice find, I've wanted one of these but no luck
jmarkwolf
Southeast Michigan
Any idea if the newer style motors like mine were originally paired with the welded stands? Wondering if this was original or if someone added the stand at a later time? I dug up that pic of your restoration. Looks fantastic! I'm planning to give this one a full restoration as well, bearings and all.
Don't know about motors and stands.
You know how to look up the manufacture date of your sander correct? Go to https://www.owwm.org/ and check your serial number (or post your question). A lot of good info there.
Try to find a dust chute for your sander. They throw off a lot of dust. Some wood dust can make you sick. There was a guy in Freeland Michigan that provided a lot of parts for vintage Delta machines but I think he retired. Before he did so, he was making very nice new cast aluminum dust chutes. I was lucky enough to snag one and I hook it up to my shop vac every time I use the sander. I was considering fabricating a 3D printed one before I found my cast one.
bugzilla46310
Demotte, IN
I believe the stand is a Delta as it matches my 10” tilting table saw my dad bought used after WWII. There were no additional non OEM holes drilled in the stand and I kept it that way. The grinder was in similar condition. The bolts are unique as they are formed to match the depressions in the leg stamped holes.
I shifted the grinder and motor to the right and will be mounting a planer blade sharpener jig I’m about done making on the left side.
chargedmr2
WA
I haven’t picked it up yet, but will definitely be checking the serial number when I do. I’m already on the lookout for the dust shoot. I bet 3D printed ones are out there, but I’d really love an original cast iron one.
jmarkwolf
Southeast Michigan
Genuine article here:
chargedmr2
WA
Has anyone had Sherwin Williams color match Delta’s 1930s green-gray color? Would love to have the info on it, if so.
I saw @Hoorn and @Snip's color matched using Ace and Napa, but it seems that info doesn’t translate to Sherwin Williams.
H
Hoorn
Glendora, CA
@chargedmr2 mine was Benjamin Moore Advance paint in satin, merely mixed at Ace. I would imagine BM and SW would be able to match our duplicate each other's colors.
Advance is awesome in terms of the open time and hardness; it is cabinet paint after all. Only thing I would do different if I lived outside of California is go oil base.
chargedmr2
WA
@Hoorn, I’ll try taking your info from post one in this thread down to Sherwin Williams to see if they can do that. I did try with the info @Snip's posted (I hadn’t noticed your info on page one, or I would have brought that as well), and they said it was based on a different system that they couldn’t duplicate. But I sure do like that green-gray, so I’m going to see what happens with your info.
Fortunately, we do have access to oil based paint up here in WA and I’ve been pretty happy with the results so far.
Snip's
Just noticed this 12" Delta Disc sander on FBMP...
I don't recognise the electric motor on this machine...
It includes the DS-21 dust chute and rare blower motor...
There are still gems to be found of these wonderful built machines...
Screen Shot 2026-03-19 at 7.14.07 AM.png Screen Shot 2026-03-19 at 7.14.38 AM.png
Screen Shot 2026-03-19 at 7.15.12 AM.png Screen Shot 2026-03-19 at 7.15.38 AM.png
chargedmr2
WA
Nice find! Did you make room in your shop for that one? Looks like the motor might be three phase?
H
Hoorn
Glendora, CA
@Snip's that is an absolute needle in a haystack find, wow. Interesting that it does not have a Delta motor, more than likely that is a Porter-Cable badged repulsion induction motor that was made by Master Electric Co. from Dayton, OH. To have the sawdust blower and dust chute still attached, unbelievable. What was the asking price, and has it been sold?
I'm always looking for an excuse to drive across the country!
Snip's
It was listed at $325.00... Marshall, Michigan
SOLD (But not to me...) Heh
chargedmr2
WA
This one isn't mine, but I saw it listed on FBMP a couple days ago. Unfortunately, I'm located on the opposite side of the country, so buying was out of the question. But I think it deserves a spot in this thread given how unusual it is. The lucky owner has already posted about it over at OWWM so more details there. Direct current motor with brush caps on the back. I've never seen one of these before.
@Hoorn I recall you had a Tauco marked grinder, but I can't remember if the marking was only on the pedestal or also on the motor housing?
H
Hoorn
Glendora, CA
@chargedmr2 that is an exceptional grinder, with all the Tauco branding and a wartime oil-board serial number badge. An outstanding example and fairly rare.
On my grinder, only the pedestal badge was a Delta badged over a Tauco.
chargedmr2
WA
@Hoorn thanks for the reminder. Yours is the only other one I’ve seen with that branding.
chargedmr2
WA
Okay, I didn't need this one, but I couldn't resist. Delta Triple Duty grinders rarely pop up for sale in my area, so when I saw this one show up on FB marketplace a mile-and-half down the road, I couldn't say no!
I don't think this grinder saw much use at all. It was tucked away in the back of a garage in the historic district of our small rural town. The owners were very old and just trying to clear out the old garage.
Anyway, here it is. It's a 1948 vintage and while the paint is not perfect, it's all original. I think the grinding wheel on left is even original to this grinder!
The paint is by no means perfect. It has the usual scratches, chips, etc. but it's all original. I don't plan to give this one a full restoration like I usually do. I'm planning to clean it up really nicely and put it to use. I'll probably crack open the motor and replace the bearings, but other than that, this one is good to go!!
I was really happy to see that the tool rests are nearly flawless. They still have their original paint and have hardly been touched by the wheels.
chargedmr2
WA
And here's that original wheel on the left side with Delta part number 23-815 on it. The part number dates back to the 1940s, but I'm sure the part number probably carried forward for decades as well.
chargedmr2
WA
Starting to clean up this delta grinder. Was pleased to see all of the original colors left from the hardening of the adjustment bolts for the tool rests. My first triple duty grinder had none of this coloration left at all. Just metal in the white. IMG_7655.jpegIMG_7658.jpeg
MikefromNZ
New Zealand
I’ve recently purchased this for $50nzd
I believe it is one from the 30s?
Shame about the stand
H
Hoorn
Glendora, CA
@chargedmr2 that grinder is in outstanding condition for its age. Did it come with the quenching cup as well? That accessory alone made the purchase worthwhile.
First rate.
jmarkwolf
Southeast Michigan
Did you have to remortgage the house? :)
There was a guy in Freeland, Michigan that sold and serviced vintage Delta equipment and manufactured replacement parts. He had cast aluminum replacement for these chutes a few years ago. I bought one. They look, fit and work just like the original. Alas, I think he retired or went out of business.
chargedmr2
WA
I think I might have seen one of his replicas in the past. It might have been a longer version of the chute if I remember.
This one cost $75. Not too bad, but my disc sander only cost 100, so it was a little spendy for what it is.
jmarkwolf
Southeast Michigan
Found some pics of my cast aluminum DS21 dust chute (below). I think I paid more than you did so you did well.
The ****** fits a 2-1/2" shop vac hose. It vastly minimizes the dust thrown into the air. I recommend using it all the time.
chargedmr2
WA
Very nice! Where did you get the plastics flange/******?
chargedmr2
WA
Thanks gentlemen. I’ll see what I can find. Maybe I can find one with no holes drilled so I can match it to the hole pattern in the dust chute.
jmarkwolf
Southeast Michigan
Saw a FB post today from a company providing vintage Delta parts:
They also apparently provide new cast dust chutes and similar.
shoot summ
Pretty sure I picked mine up from their ebay store.
Jgaz
Such a great source. Thanks for posting it
