That reminds me of the time we pulled a little field mouse out of a blower fan cage on a customer's civic. I just visualized that this poor little mouse just kept running and running until he couldn't run no more.Aww,.....how cute. Little guy must of got tuckered out and decided to nap it off. LOL!!
Sounds about right. We of the northern snow country persuasion have a way to go before we see spring.Started cleaning, flinging and reorganizing. Found a couple unfinished projects. Spent 3 days soldering, testing, and coding. Wound up with a nice upgrade to the laser burner.
That's a neat lamp. Can't say I've ever seen one like it.Finally finished the preservation/rebuilt of some vintage 60s/70s lamps SWMBO acquired and loves. They live in our guest room. I had already installed new wiring and 3 way sockets, but the old felt bottoms were in horrible shape and needed to be replaced. SWMBO had some felt that I could use. I was all prepared to have to glue them on until I realized that they already had adhesive on them.....
1st order of business was to trace the old felt onto the new felt..... .and then cut them out...
...scraped and removed loose glue/******....
..there's still some on there, but it was hard and not coming off easily. Figured the adhesive wouldn't have an issue sticking...good enough.
....finished
What is that surface you're working on? It looks vaguely familiar.finished product....
and back home where they belong.....
They call them Genie lamps… checkFor some reason, I Dream of Jeannie came to mind when I saw that photo.
What would you use for sound dampening?
For the floor, I was planning on livestock pad--the stuff they put in horse trailers. It's about 1 1'2" thick rubber with a little give to it.Two kinds of noise to dampen. through the air, and transited (Floor). So maybe keep a pallet under it, rubber pad some 1-1/8" flooring on top of that and rubber pad the feet.
Louvers in the back wall are good then box it in; can you lay hands on some big thick sound room deadener? The type with the cones?
Nice. I use a chunk of EPDM.
You could hang a few layers of corrugated cardboard around it. Rip the skin off one side to leave the ripples exposed to the sound source.What would you use for sound dampening? How much ventilation will I need? The bay is on an outside wall, where noise matters less than the other walls. I can cut in a couple of louvered vents on that wall.
You roofed your workbench?Nice. I use a chunk of EPDM.
That is one tough looking compressor, I see it was made in Barrie Ontario just north of Toronto. With proper maintenance it should last a lifetime.Here's the comp we're moving:
That'll be fun. A couple of floor jacks should get it out to where I can get to it with the forklift.
Here's where it's going:
The comp is about 6' long, just over 2' deep, plumbing included, and 4' tall. The bay is 8' long, 4' deep and 5 1/2' high. The comp is driven by a 7 1/2 hp motor. Here's the data plate from the comp:
Outside of the opposite side of the warehouse is outdoor seating for the warmer seasons. We'd like customers seated there to be able to carry on a conversation with the comp running.
Yup. I've got a chunk of black and a chunk of white. I've also got a lot of half sheet pans that I line with white printers wipes. Depends on what I'm working on. I roll the EPDMs up and tuck them alongside the bench.You roofed your workbench?![]()
I’d use actual vibration isolators under the compressor. They are quite effective, but might stretch the budget (but they could be added later). For the walls, I’d use unfaced mineral wool batts. Flameproof and quite sound absorbent.For the floor, I was planning on livestock pad--the stuff they put in horse trailers. It's about 1 1'2" thick rubber with a little give to it.
As for the sound deadening panels, probably out of my budget, but I'll check on it. I was wondering about using the stuff for automotive cabin deadening, applied to rigid foam boards.
Finished first of two saw horses with a chunk of W6x25 a neighbor gave me. Kind of embarassing, went full Garage Journal.
