External lock 4 post lift question
svtrichie
Troutman NC
Any real issues with the external lock 4 post lifts. Picked one up pretty inexpensive and seams to work good. Just looks to be an older design
kbuhagiar
Escondido, CA
None that I am aware of. I've owned one of similar design for almost ten years now.
After leveling the lift front-to-back and side-to-side, check lock engagement and, if necessary, adjust the cables so that (a) all four locks engage fully; and (b) all four locks engage at the same time. This is VERY important.
It's not common, but one issue I've heard of (actually, with all lifts) is failure of the cheap momentary contact button switch which controls the pump. They've been know to fail and stick in the 'on' position while raising a vehicle. Make sure you either (a) have an emergency shutoff switch wired in or (b) have easy access to the plug so you can pull it out of the receptacle if the switch sticks in the 'on' position.
If this is your first lift, get familiar with proper operating procedure. No distractions! Focus COMPLETELY on the lift when raising or lowering the deck. This alone will eliminate 99% of risk.
svtrichie
Troutman NC
Thanks. I have had a few 4 posts and have one currently now but with the internal lock ladder. But buying this new one for $1200 I couldn’t pass up. Here is my other lift
