Above 1200 Sq/FT Bald is Beautiful - 7k sq feet+ of Gruntledness
T
tig
Durango, CO
What size and brand is that one? I've been looking at them for the past couple of years since losing my paint shop option, but I keep seeing mixed reviews on the inflatable booths.
Thanks.
I believe it's this one: https://www.vevor.com/inflatable-pa...icles-large-furniture-painting-p_010119213766
This one is fairly used and shows some quality issues. There are places where duct tape has been added to stem leaks in seams. The seams around all the "windows" are leaking a bit.
Lighting inside is weak via the windows. I put stand up LED lights inside, but that was barely sufficient.
So, not perfect. But for $500?
bepjrfan
North Dakota
Thank you for the follow-up. It somewhat matches some of the other things I've read. Much appreciated.
Mike, I had one as well for a couple years. They work pretty well, just have to make sure to clean up/sweep before folding them up when done. Otherwise paint dust will accumulate. Lighting, as mentioned previously, isn’t the greatest. They work great at containing a paint mess though! Used one to build 3 different kitchens before I got my new shop And never had an issue!
zmotorsports
Northern Utah
Thank you for the feedback. I appreciate it.
T
tig
Durango, CO
Sorry I've been remiss on updating as I've done things...
My stepson is using Penny as his HS Sr. Project, and we're on a tight timeline to get it drivable so he can take it to the last day of school on May 14th. It will not be complete/finished, but we will get it drivable!
Tons of progress. Sorry I've been remiss on updating as I've done things...
As we started prepping the body, I noticed the oil cooler intake piece was pretty mangled. One of the donor cars had a much better looking one, so I decided to try my hand at actual body work involving welding (which I've failed at before).
Test fit:
I don't weld; I grind.
No good after photos, but it came out great.
For the body; to recap the plan: I'm focusing on getting the stuff you don't normally see perfect. I will get the exterior prefect at a later phase, afgter the car is back on the road. However, while the body is disassembled, getting all the little dings and dents out is a worthy endeavor. I have a local PDW guy who is awesome, so I had him come by and spend a day straightening everything he could.
The driver's door and fender have a pretty gnarly dent/scrape. The goal was to get it so the worst of it was straight so it wouldn't bind when closing anymore and enable a real body guy to fix it later. The door may need to be replaced at that point; but I don't think so.
T
tig
Durango, CO
Next up was the front suspension & steering.
The steering box is in great shape and is of the later style. It just needed paint.
The idler box has also been replaced. Note the gap between it and the frame?
I elongated the bolt hole for the bolt you see to the right here so that it fit properly, figuring the adjustability of the steering arms would accomodate.
But then, later when everything was together, I found the inner arm and bushing rubbed on the inner part of the frame, so I re-mounted it as shown in this pic (with some washers in there so that there's less stress.
Getting the front suspension together was a two-steps-forward-one-step-back affair. Glad I resisted torquing anything down until much later, as I did need to pull things apart multiple times after realizing I had things backwards or sideways.
I lost count of the times I had the hubs/spindles on and off because I goofed/forgot something. For example, those locking plates were not on there originally. I only realized I had done it wrong, using lock washers, after noticing them in the parts boxes and saying "Oh ****, where do THOSE go?".
I also lost count of the times I had the calipers assembled and needed to disassemble because I had gotten something wrong. Turns out each piston goes in a particular location and rotation. Wish I had read the Tech Wiki first. Lol.
T
tig
Durango, CO
The engine...
I really didn't want to pull the head. I was certain I could get the timing cover on without damaging the head gasket. I was wrong.
I'm now really glad I did. When I pulled the head bolts they were REALLY tight. And there was coolant in at least 3 of the head bolt holes. Ugh.
Clearly, when I was running the car last summer, I overheated it and blew the HG. I did have a few moments where it MIGHT have gotten pretty hot
I'm no pro at reading the tea-leaves of used HGs, but it didn't look great. I also thought I could see signs on the surface of the head and block, but nothing defnitivie.
Praying the head wasn't warped, I carefully cleaned it and the face of the block. Then I did the DIY "is this head warped" test and I couldn't get even a 0.0015" feeler gauge under the straight edge anywhere. Whew.
I had already bought a new HG. I also bought a set of ARP studs. After reading up more on the OE studs and issues with ARPs (and finding the nuts were a really tight fit with the camshaft caps), I decided to just use the OE studs.
Next up was the 93mm Denso alternator mounted on the right side. All went together nicely, as did final fitment and config of the carbs.
Oil pan and gasket...
Yes, the pan has dents. I probably should have pounded them out; but it's character!
T
tig
Durango, CO
Meanwhile another Gruntled get-together happened. This beauty showed up.
And I went to New Zealand and hung with my buddy who has a collection of Volvos... they are building a "Classic Volvo for hire" company called The Rolling Swedes. They have a dozen or so cars including several STRETCH LIMO Volvos from the 80s.
Matthew let me drive this.... A very cool mishmash of Volvo, Lotus, and Renault. I have first right of refusal if he ever sells. Fits my eclectic taste.
67CarGuy
Outside Boston, MA
Man, seeing body-on-frame cars come together is always a treat!
And that Aussie Volvo/Renault/Lotus (Volotault?) mash-up is an impressive '80s timewarp - those wheels just seal the deal.
T
tig
Durango, CO
The trusty cradle was with a friend in Seattle. He finally shipped it back to me. Still works great.
Yep, rear main seal is done. The input side of the ****** is fine, but the ****** is still toast.
I would never admit my mistakes. Especially when I try to transfer the engine to the stand without using my hoist, because said hoist's hydraulic cylinder has decided to stop working. And, in the process the engine/cradle tip over, causing all oil and remaining fluids to Valdez across the floor, and causing the oil pump pully to get bent.
A 3-hour round trip to Farmington and Harbor Freight later....
T
tig
Durango, CO
Luck: When opportunity meets preparation.
Bottom end seems fine. I am going to carefully clean off the piston tops to make double sure though.
Not quite sure how all the rockers aren't broken. Until I get an "iron maiden" spring compressor (one inbound), I can't really see how the valves are bent, but I'm assuming they all are.
T
tig
Durango, CO
Clean, again. At least underneath.
I put the subframe and steering components back in, but didn't reconnect the steering shaft. Thinking this setup would let me move the car around.
That was dumb, because now the car is basically stuck were you see it because the dolly wheels sink in. This morning's job is to rectify that so I can get another car on the lift to do some work on it while I wait for parts.
cccoltsicehockey
Charlotte, NC
Looks like you are making some good progress.
Yikes on the dolly wheels sinking in. I was planning to store a car that way in my garage with Swisstrax, but apparently that won't be happening. Thanks for the unfortunate test.
kmcteer
A Paul Burke Head. What cam are you going to run on this? I also see that increased compression is worth a consideration :devilish:.
-Kelly
T
tig
Durango, CO
-Kelly
The head i broke was the same specs as this one, built to Paul’s specs. It has an n21 in it. 10.5:1.
T
tig
Durango, CO
This tool is called an Iron Maiden. Supposedly, it's possible to compress the rockers springs with a collection of screw drivers, 6 strong German men, and a lot of beer. But I think that's fiction. This thing is needed to get the camshaft out.
I found this place via a friend, and they did a great job of rebuilding the PS lines... and very fast turn around. Would recommend:
T
tig
Durango, CO
Did a deep clean on the engine bay.
And fabricated this heat shield that mimics the one that came on the M5. I found the aluminum material on Amazon. Great stuff!
The car previously had a prototype version of the HGL blade-fuse fusebox upgrade kit in it, so I used this as an opportunity to put in the most recent production design.
I also, finally, ripped out the PO's hack wiring for the headlights and cleaned up all the related wiring.
T
tig
Durango, CO
If you have a classic BMW with a G260/6 or G265/6 transmission, you know what "Death Rattle" sounds like.
Now you know what it LOOKS like:
This transmission was getting worse and worse. Each fluid change had tons of metal on the plug magnet and the noise was becoming almost unbearable. I had parted another 87 535is years ago and kept it's G260/6 as a spare. The input shaft felt significantly less loose than the old one, so I bet it was just in better shape.
Taking off the input shaft cover made me wonder though:
Ugh.
I decided to go ahead and put it in, using the 2 best shims.
T
tig
Durango, CO
By 11:30pm:
Sadly, while we had it running, the car was not drivable in time for the drive4corners drive saturday morning. It was overheating because, of course, I had put the t-stat in backwards.
So I drove the 911 instead.
By about 2pm after the drive Saturday, I swapped the t-stat and took off the Fikse's which I really don't love; they were just on the car so I could use up the rubber.
35 degrees of final torque...
Now with BBS RS VLAD IS BACK, BABY!
I've now been on several spirited drives and the car feels great!
T
tig
Durango, CO
The head unit in Vlad seems to have lost the rear channel.
I decided to give the Blaupunkt Skagen 400 DAB a go (see https://forums.mye28.com/viewtopic.php?p=1549915#p1549915).
Vlad has a po installed amp and sub in trunk.
Fantastic. Simple. Clean sound.
Haven’t tested BT calls yet as it has a 2.5mm in and my mic has a 3.5mm out. Adapter should be here tomorrow.
