Above 1200 Sq/FT Knucklehead 61's 2 car garage with room to store a few antique motorcycles & parts
K
knucklehead 61
What an awesome build! Looking forward to watching it progress. It is always exciting planning and setting up a new shop. I’ve found that the bigger the shop, the more stuff I put in it. LOL
thanks!
my old shop was just over 7,000 sq ft & packed tight. i'll have some breathing room in this one for a while i hope.
K
knucklehead 61
got a delivery of 180 Maxlite 4' led ready fixtures yesterday. the 360 bulbs should arrive soon.
upper roof is now 100% finished. gutters are being formed & installed now, then downspouts, then the last few lower roof panels & trim will be installed.
runit
Raleigh NC
What an awesome build! Following!
Retired at 49 and cross country road trips on 100 year old HDs! Tell us the secrets! Ha!
K
knucklehead 61
no magic here...
no college, so no student loans. went to work in hvac.
good paying job. saved & invested heavily in the stock market.
lived way below my means. drove a work truck, didn't own a personal car a lot of the time.
bought lots of rentals between 2013-2016 when prices were in the toilet.
did a lot of the rehab work myself while working 60 hr weeks at my job.
married the right girl, never had kids, never got divorced.
buy & sell lots of Harley motorcycles & parts for 41 years, turning a profit over 99% of the time.
K
knucklehead 61
day 2 of hanging drywall.
2 guys yesterday, 4 today.
all ceilings on both floors are done & about 1/3 of the walls are done.
they should be close to finished monday, then it's on to tape & texture.
K
knucklehead 61
day 3 of drywall installation & the guys have t all hung.
something like 460 sheets.
most are 4'x12' but a hundred or so were 54" x 12', all 5/8"
over 50,000 lbs worth!
over 1/2 of an acre of walls & ceilings!
these guys worked fast.
hopefully the mud crew starts slinging goop on monday.
also, I bought a bunch more shelving friday at a REI moving sale. about 80' of 8' high racking.
IMG_1640.jpegIMG_1641.jpegIMG_1642.jpegIMG_1643.jpegIMG_1644.jpegIMG_1645.jpegIMG_1646.jpeg
K
knucklehead 61
i need to start designing a "door" for the 22' x 25' fabrication room.
it has a 9'w x 8' tall opening. i want to close it off as the main entrance is a set of double doors.
the big door would only be used occasionally to allow a truck or other large item to be rolled inside.
i don't want to use a roll up door.
i am thinking of building a wall that pivots like a gate to close off the opening & keep grinding dust inside the fab room.
any suggestions?
LXCam
Would a sliding barn door with brush seals work for you?
LXCam
that would be the easiest way, but would prevent benches or shelves to be placed on a 9' wall next to the opening for clearance.
that's why i'm thinking it should be mounted like a gate.
Yup, copy that. Guess it’s too late for an industrial sized pocket door eh?
K
knucklehead 61
another thing i need to figure out quickly is the color to paint the ceiling in the museum.
the room is 21' wide x 99' long.
i am thinking either matt black or grey.
the sheetrock walls will be covered with 1x8 pine boards, floor to ceiling i think.
no work will be done in this room, it is only to display my collection of antique motorcycles & memorabilia.
this pic is my old "museum" room, 22' x 59'. it was too industrial looking.
i'll be using the same glu lam beam shelves & welded chain brackets that i made before in the new room.
no more strip led lights, it will have 3 rows of track lighting instead to spotlight the bikes on display, with additional lights over the raised platform lounge area.
LXCam
How are you set up for lighting. I know you’ve discussed it before but bud, those details are lost on me every time you show your toys. I end up forgetting all about the construction.
The reason I ask is my preference would be a black matte lid but with two lighting packages. One for daylight and one for accent. Your collection is far too nice not to take advantage of it being a very serious display.
LXCam
Back to the swing doors. I did go looking for a pivot hinge to recommend and that search sucked using my phone. But if it were me I’d go that route with a metal frame covered in whatever finish material you want. I’m not a fan of that wide of a door hung off a standard mortised hinge unless both the jamb and door are heavy duty metal.
Btw, I build detention facilities for a living. It’s not often but we do large ballistic rated swing doors from time to time in finish area like courtrooms and admin entrance points. That’s why I feel the way I do about a hinge or hinge type assembly.
K
knucklehead 61
i figured the wall/door would weight around 500 lbs, so i'll probably build a timken bearing mounted to a plate anchored to the floor & another mounted to the header beam.
K
knucklehead 61
the museum room is roughly 22' x 99'. it has 3 lighting wires roughed in the ceiling, one in the center, & one on each side of that.
the thought is a run of lamps about 96' long down the center aisle & a 96' run centered over each row of bikes.
i'm looking into the low voltage cables that mount with turnbuckles along the ceiling that would have clip on lamps. might look more "old timey" for the theme of what i see in my mind for the room.
rust in the eye
Chicagoland
Diggin' on those century old bikes.
BIG bummer that bearings failed so close to completing the trip. "back-up" bike implies less than roughing it but these primative machines gotta be hard on the bod. How many hours or miles are tolerable in a day on them? Cruising speed?
K
knucklehead 61
the longest day was 360 miles, many were 300. i greatly prefer the 250 mile days!
typical speed is around 50 mph, all on back roads.
when the bearings failed i was still about 1300 miles from the finish line.
already signed up for the next one in 2027!
K
knucklehead 61
sunday update:
all taping & sanding is done.
hopefully the spray texture guys show up tomorrow.
i cut most of the holes for the led puck lights in the office, bathroom, sink area, & around the elevator/hallway/stairs area.
still contemplating what lights to use in the museum as well as what to paint the ceiling. probably going with matt black, but could be grey.
andyvh1959
Green Bay WI
You may already know him, Steve, the owner of Doc's Harley in Bonduel WI. He has done some cross country rides on his 20s vintage Harleys.
K
knucklehead 61
i want something to stain & seal my new slab.
hopefully something that keeps oil drips from my motorcycles (antique harleys, they all drip...a lot!) from soaking in.
looking for suggestions.
had been planning on epoxy, but with quotes well over 20k i am rethinking it.
a friend just finished his new antique motorcycle garage/shop/display with acid staining, solvent based sealer, & wax & said he's happy with the results & oil puddles are easy to clean up.
i need to figure this out quickly as it will be ready to go in about 2 weeks.
Krfjkm
Charlotte / Mint Hill NC
K
knucklehead 61
lighting & electrical progress!
i have all the lights finished on the second floor, other than wanting to add 2 more led pucks in the bathroom as it is a little too dim.
got all the plugs & switches finished upstairs as well, & started installing plugs & switches on the first floor now.
IMG_1847.jpegIMG_1866.jpegIMG_1867.jpegIMG_1868.jpegIMG_1869.jpegIMG_1872.jpegIMG_1877.jpegIMG_1878.jpeg
