The VISES of Garage Journal
Beerhippie
Far NE Oregon
Thought this idea was more beneficial for shins.
I don't have a tailgate.
I saw a truck one day with a bumper sticker that read "Guns don't cripple people. Receiver hitches do."
When not in use, I'll stow it.
Not an uncommon adaptation. since the hitch is wasted anyway, maybe consider adding a post to it for a bit more height?
I realize it's nothing ground-breaking.
I'm trying to keep the weight/bulk down. I'm not all that tall, after all.
I'm also considering making a folding camp table to go in the receiver. That, too, would be right handy. There's one available that mounts in the jack points of the Vanagons: $175, because Vanagon.
harris.jasonm
FINISHED! Update, with the new Jaws from Logan and mounted.
royce
fairbanks ak
Wrapped up a couple of vises this week for a good friend on the island. George and his son. Got a couple Columbians to work on so I built a couple Bronze wear plates with my manual CNC. Back in the 70’s we didn’t have CNC’s instead we had Rotary Tables with a Cross Slide or a Volstro Head, a rotary cutter head attached to a Bridgeport. Really awesome tool, you can cut radius’s tangent to an angle just like the CNC’s.
Now on to a 5-1/2” Bonney for my good friend in Alaska.
Hey Kevin,
I looked at your set up and wondered how you cut those wear plates without a rotary table.
That is too cool
Tom Graham
Oklahoma
Sourcing a No.1 wrench for a small Charles Parker vise (9/16” or 19/32”)?
Was the original No.1 wrench for a small Charles Parker vise (e.g., 973) a 9/16” (as I thought) or 19/32” (or 5/8”)? And if it was originally soft cast, how can we know?
If you need but are unable to source an original No.1 wrench for a small Charles Parker vise, (as I have been for months!) one of these vintage lathe (tool post) wrenches may serve as an alternative until you do:
  • Williams USA No. 802 19/32" Lathe Wrench - 6 Point Hex Box End, Single End
The real trick for me has been to finally give up searching for a 9/16” alternative, and be willing to allow a 19/32” be close enough.
(There are several of these currently for sale on that auction site for less than $20, all-in.)
I appreciate GJ member, Private Lugnutz for answering the question that member larry_g had posed in this thread: “Looking for a unicorn wrench 9/16 6pt box single ended”.
In that post, Lugnutz drew attention to the Williams, Armstrong and Billings & Spencer SBE machine wrenches. He said Armstrong used the same part number, whereas Billings & Spencer used part number 1902 early, then 802-A.
Edit: CAUTION: In retrospect, and without a larger sample size, I cannot recommend 19/32” on a “user”. In my case, this 19/32“ may be added to the small vise for aethsetics, but only with a warning: The measured head (on the swivel brake bolt) on my 973 is tapered from 0.558-0.573. And since even 0.005”–0.010” slop is noticeable and 0.03125” is excessive, a 19/32” won’t get solid engagement, will be “spongy” or loose and likely to slip before reaching proper torque. A quality wrench will likely round the corners on the bolt head.
[image credit: Private Lugnutz ]
PeterPeter
Newburyport
Hey there. Got me a Prentiss No. 26 with a swivel jaw that needs a pin. Does anybody make them, or have an original to sell?
The existing pin was a hand tapered bit of motor shaft. Had to drill it out.
Thank you in advance, Peter, Peter.
Edit: turns out, the taper is the same as MT2. I have an old taper for a chuck that I can sacrifice.
Andy FitzGibbon
I was pleased to find this Parker 474 locally. It's rusty from sitting in an outbuilding, but everything is free, it has no broken or missing parts, and from what I can tell it's never been painted or even used very much.
I started in on cleaning this one up. Never had a Parker apart before... behind the meatball was a stack of four steel shims. Original, or user added?
Thanks.
Beerhippie
Far NE Oregon
Thanks.
I suspect user-added to take up slack. I used a sintered bronze thrust bearing for the same purpose on my Chas. Parker. I also added a shim between the nut and the pin that retains it. Very little play in the screw now.
PeterPeter
Newburyport
I have seen shims in most of the Parker’s I’ve worked on. Not sure what, if any, are OEM. My last one, a 945 1/2 was super sloppy, and full of shims. So sloppy, I was able to press a shouldered bronze bearing into the face of the dynamic jaw. Just had to grind down the shoulder of the bearing a bit. Now, it’s the smoothest, tightest Parker I own.
peter, peter
akasrick
south jersey
Thanks.
A wrt. washer shows in a 1912 catalog, my Parker has only one washer and could probably use a second.
*** edit mine is steel same as yours. ***
akasrick
PeterPeter
Newburyport
Anybody recognize me?
Looks a little square, and plain, like an Asian casting, but I don’t know. Also looks too old to have come from there. I don’t recognize the swivel lock…
Thank you for the help, Peter, Peter
PeterPeter
Newburyport
Head of the main screw has an American Scale vibe to it. The swivel lock more Prentiss?
The meatball and jaw pads are both American Scale like. It’s three-toed like a Prentiss, and lock seems to be Prentiss-ish, in that it looks like it is pulled up to reset, but the knurled knob is not at all Prentiss like.
PP
micahd1997
My first thought is a Prentiss with an after-market swivel base lock, thicker jaw caps, and a replaced spindle. That said, that’s a lot of seemingly unnecessary after-market adaptation for what appears to be an excellent condition vise. Please keep us updated!
PeterPeter
Newburyport
Well, the only update I can give is that it sold to somebody else. I get the feeling it was a good one; priced at $100, it went in less than a day. Hope a member got it.
winsome, losesome, peter, peter.
micahd1997
I appreciate the update, Peter! Just so happens I somehow know of the guy who purchased it. He posted pictures of a vise he just bought, and I though “boy, why does that look so familiar…”
Mystery Solved - it’s a school vise. It looks to’ve been modeled after a Prentiss. I’ve seen several vises made by other institutions that have appeared to be modeled after the general Prentiss design, and it’s always fun to compare. In great condition and a pretty neat school-made vise, but not exceptionally valuable among collectors.
Andy FitzGibbon
Cleaned up the 474. It's in excellent condition, and was never painted. At first I planned to preserve what was left of the original paint, but with about 99% of it being gone I ended up just removing it. Will probably do linseed oil eventually, but at the moment I'm busy with other things.
Unfortunately, Parker bored the counterbore that the screw shoulder sits in out-of-square with the slide, to the point that the end of the screw hits the inside of the slide before the shoulder makes full contact with the bottom of the counterbore. When I have time, I'll put it in the mill and square the bottom surface, then make a bronze wear washer to replace the steel shims that came out of it.
