PWC Repair
Arkansas
I started in on a Rotax 717 rebuild. I removed the rotary valve drive shaft so I could replace an o'ring and the front seal. I also threw the mangled head up on the mill and gave it a smooth surface again.
M.Brane
1 hr N/W of LA LA Land
Pondered the mounting options for my BT headset in my new helmet. Gonna have to make some mods, but I think I can make it work. Not gonna spring for the $400 Shoei Sena kit after dropping $1K on the helmet. I like my Interphone even if it's a bit old. Too damn hot to ride this week anyway might as well think on it a bit.
Beerhippie
Far NE Oregon
And people will ask: How can it be too hot to ride? It's gotta be cooler with the wind.
Truth being, above a certain temperature, it's hotter because you're passing through more hot-*** air.
I learned this in Big Bend, TX. 120F was about the line--and that was before we wore the kind of protective clothing y'all have now.
NUTTSGT
Northern Central Ohio
People without band saws just don’t understand.lol When I was actually fabricating parts for a living I had 2, but even before that, I don’t know how I lived without one for so long.
Exactly, at less than $120 used, I find it has been one of my better investments... and it was a good road trip for the wife and I.
Beerhippie
Far NE Oregon
I get to play outside today!
With fire!
Unfortunately, my former coworker who made most of the piles has no idea how fire works. I'm having to take them apart and re-stack everything. I also want to save that nice pile of aspen wood so visitors can use it for campfires--if we have a campfire season this year. Bend area already has mandatory evacs due to a fire.
Same coworker used our (formerly my) saw last fall, and brought it back sharp as a brick.
But that gives me a chance to play with my new-to-me vintage brass Oregon Chipper Chain file holder/guide.
I'm used to free-handing the file, but this significantly stiffens the file and gives me a second grip at the far end.
Back to burnin, baby!
pima67
Tucson, AZ
Changed the motor oil and filter in my 2010 Ex 4.6 at 119,151 miles. Till about 113,000 a;ways used Val 5-20 dino at 3,000 mile intervals. Then changed to Val Advanced full synthetic. Hardly any, if any, oil used by this change. But for fun purchased a Blackstone oil analysis to verify. Walmart was $10 cheaper for 5 gals than O'R and AZ. But I think this was my last oil change using ramps for access.. Too old and some health problems make this not "fun" anymore. So will farm this out even though more expensive.
Also treated the old girl to new hood and rear glass struts (old ones passed their gas), plus new front and rear glass wipers (original ones getting ratty). Not that we get a lot rain around here and I avoid ,if possible, driving in the rain. Also replaced the head light bulbs (original ones) for better night driving but again I avoid it as much as I can (cataracts).
And about time again for fuel filter, PS and brake fluid changes. I do the coolant myself. Have done the ****** 3 times and next is due at 125,000 miles. Gotta keep the old girl running until I shuffle off to wherever!
67CarGuy
Outside Boston, MA
Went out just before noon to head off to a job site, only to find "Check fuel cap" flashing on the dash of the daily. Huh, wasn't doing that last time I drove it, and it's down to 1/4 tank, so what changed? Shut it off at the end of the driveway, redid the gas cap, started up again, no change. OK... Drove to the job, did the job, redid the gas cap again, and when I started up again there was no warning any longer. :dunno:
My guess is changes in temperature might have caused a pressure change in the tank, leading the sensor to think the cap was off? Don't know why it didn't correct the first time, but did correct the second time. One of those mysteries of life, I guess.
Wrench97
Southeastern Pa
Mopar? Usually a leak detection pump(ESIM) failing.
Crazyjake8493
Upstate NY
Built a better door for our storage area under our porch, where I keep my smokers, garden hoses, and lawn chairs. Saved the door from a shed I took down, and rebuilt that to fit this opening. Still have to prime and paint it and I'll hang it this weekend. The old doors are totally rotted out.
M.Brane
I used to be able to ride in triple digit temps. Not anymore. Low 90s is my cutoff now. My perfed leathers flow just enough air to keep me cool while I'm moving without getting dehydrated.
Just a couple of years back maybe 4-5? I started a hunting "scouting trip" in my Samurai with no AC, during a central valley heat wave. I got to my planned overnight camp ( no dispersed camping allowed just then with extreme fire restrictions) and the planned CG was completely full. I landed on 5 near Yreaka 7 hours from home and decided Eff it, and drove home. Most of the trip it was 117-119 degrees inside my rig. I just kept sucking down water and using a spray bottle to wet my face, neck, tee shirt, and cutoffs with water; stopping every so often for another chocolate milkshake. I was wasted when I got home...
17 hours in 117 - 119 deg temps...
kaymccampbell
Upstate New York
Those rides were 60 some years ago. The bike, the tent, Rhonda, me.
Beerhippie
Far NE Oregon
No AC in the Brick, so looking forward to some hot action this summer. It hit 80 today.... I guess I need to fix the power windows.
Beelzeboss
Sydney
I started some light machining :LOL:
This is right at the limits of the largest piece I can machine on my lathe without removing the gap bed.
It's 1045 steel I'm machining into a custom 1UZFE flywheel that will take a standard Falcon XR6 Turbo clutch, which I believe is the same as a Mustang 10.4" pattern
rollinlower
Rogersville TN
IMG_8122.jpegalternator mount in, alternator tested, got a lil hot glue to help me hold wires while i route them to the voltage regulator. now waiting on a order from fcp euro for a bmw dual temp sensor and wiring for the dual electric fan since i dont think ill have room to put it all in after the alternator is in.
BonzoHansen
Anyone ever experienced this? I opened a quart of paint. Half used, maybe 6 months old. It stunk, kinda smelled burnt for lack of a better description. Otherwise the paint was fine.
rollinlower
Rogersville TN
back a couple years ago when i was working for uncle sherwin, they told us smell was the biggest tell tell on paint going bad lol iv got 15 gallons in my barn still waiting on me to finish the sheetrock btw have i mentioned how much i hate sheetrock?
kaymccampbell
Upstate New York
Some of the oil based stuff can smell kind of burnt-ish as it's catalyzing. When the smell goes away, that's when you know the item is ready for use.
welder4956
Birmingham, AL USA
Spent the last couple days tinkering on getting the Sports Coupe cleaned up and back together. It is getting pretty close. After that I'll be back onto the wagon. Soon I hope. I can't wait to be able to take this one out and enjoy it again.
Nice! I have a 63 hardtop waiting to be restored.
welder4956
Birmingham, AL USA
Put away 3 new vise grips that were delivered yesterday, then disassembled and repaired a cracked Dewalt battery case with hot staples after I dropped it on the concrete a few weeks ago. Then started repairing a cracked rear spoiler from the Mustang while I had the hot staples out.
niget2002
Josephine, TX
Ran out to the garage and installed the power supply mount that 3d printed late last night. Checked on the logo and saw the varnish is curing a lot clearer than it originally sprayed on (it had a yellowish tint when first sprayed). I really should have tested the clear more than what I did before spraying the logo. Live and learn. The varnish was still tacky when I went to bed last night and you can still smell it walking into the shop this morning. Can says fully cured in 24 hours, but I'm finding that hard to believe.
BonzoHansen
But it's latex. I did some googling. Seems latex can "spoil", especially if it freezes. This didn't freeze though. I dunno. Weird. I've opened old latex that likely has froze and never ran across this.
Old Man Roger
Palm Coast Florida
I’ve used spoiled paint on out door stuff that seems to be fine, but the smell alone would keep me from using it on anything indoors. I just hit it with the mixer and painted as usual. YMMV
