What colon prep did you use?You both worry me![]()
Go Litely... not named correctly but funny as hell. Comes in gallon jugs... at the register... buy a bulk pack of toilet paper with the enclosed coupon.What colon prep did you use?
Dude, I want one of those, lol. I just haven't had a specific need to justify buying one. They haven't come down to the super-cheap levels of boroscope cameras yet. Well, not that I know of, I haven't shopped for one in a while.Next adventure into GJ heaven... Get a Thermal camera...
Ahh, good ol' Go Litely. I told the doc it should have been named "Go Loudly".Go Litely... not named correctly but funny as hell. Comes in gallon jugs... at the register... buy a bulk pack of toilet paper with it.
You’re going to give this place a bad name for not holding out for the $1700 SnapOn version.I got a cheapy on Amazon awhile ago, that plugs into the phone, and it works well enough for me. It's handy and was cheap.
I used my Depstech https://www.amazon.com/dp/B0928Q3T42?tag=atomicindus08-20 on a bathroom sink with a very slow drain. Turns out water doesn't drain real fast with a toothpaste cap backed up by a hair spray pump cap stuck in the pipe. Drains great now that the obstructions are gone. The camera was extremely helpful to see where to grab.
When I open the link I have various results. Is this the one you have?The first couple I bought were the type that connect to your phone...they were absolutely horrible.
So I bought this same one and it works pretty good. I have used it a ton in all kinds of deferent scenarios and it hasn't let me done.
I'll get hate for this but it is better then snap ons...to be fare though the one we compared it to was an older unit and I can't remember the model. I'll have to look when I get back to the shop.
I tape my boroscope camera to fiberglass wire fishing rods when I need to go down long, straight runs.Use a piece of dead soft copper or aluminum tubing as a bendable guide for times when you need some support for the end of the scope.
If you're going to do colonoscopies, be sure to get what is called an "obedient" or "articulating" borescope/endoscope. They have a controller so the scope can bend and turn as needed while it's in there.At home colonoscopies.
Got a part #I bought a Klein at Lowe's for $34 clearance and it's Android based to the phone.
Any reccomendations on a make / model for this purpose?If you're going to do colonoscopies, be sure to get what is called an "obedient" or "articulating" borescope/endoscope. They have a controller so the scope can bend and turn as needed while it's in there.
I believe Olympus is still king of things that "go there." Although I think it's now a subsidiary to another company since the parent company had the accounting scandal a few years ago.Any reccomendations on a make / model for this purpose?
I borrowed one of these earlier this week to look for a dropped cross bar in an electrical box. The "cable" was so stiff I could not rotate it easily, and had trouble bending it to see the cross area of a 4" conduit. I could not make it move across the diameter from the top.That Depstech is the one I bought last month for $48 and it works well
You might want to try an articulating borescope (if I recall my verbiage correctly).I borrowed one of these earlier this week to look for a dropped cross bar in an electrical box. The "cable" was so stiff I could not rotate it easily, and had trouble bending it to see the cross area of a 4" conduit. I could not make it move across the diameter from the top.
Articulating is the correct term! What ***** is they don’t make them very long (longest I saw was 5.5ft) and that hinders in what areas you can access.You might want to try an articulating borescope (if I recall my verbiage correctly).
An articulating scope can "bend/curve" at the end under control. For example, you could poke it into the cylinder, then have the head bend upward to see the valves.
An obedient scope (likely what you had) has a sheath inside the length of the (sometimes partial) of the lens attachment so you can "prebend" it to curve around an obstacle (for example). But those can be a little unwieldy because some of them can be really stiff - so maybe not the type you want to use for a colonoscopy (or maybe one does). That stiffness, however, can make it hard to maneuver if you can't see what you wanted to see and have to reposition.
How does that work? Is the camera part just on a USB cable or something? Mine is 3M long but it's USB so I think I can do that. But on one with an integrated display, you can still only see so far... I bought a 11.5ft Depstech back in 2018 and it's still going.
I've gone farther than this one should by taping it to some fiberglass wire fishing rods.
Nice ZRX. How many miles do you have on her?I keep the unit in the cab and run it out the open window and place the camera hanging over the tailgate. My truck is not inside the shop so I took this photo to show you the image I see.
$12!Thank you Sir, this one has a little better reviews and is even cheaper. Probably made in the same damn factory.
https://www.amazon.com/Endoscope-Ad...nspection/dp/B0DMK8VRYF/?tag=atomicindus08-20
35k on this one, 55k on my 99 1100, and 90k on my 03 1200. So about 180k on the three of them. Great bikes.Nice ZRX. How many miles do you have on her?
Let us know! I got the teslong version coming. Pretty similarGot the DEPSTECH Dual Lens Industrial Endoscope today. Just playing with it, the images it provides are great. Going to use it to scope a drain line hopefully tomorrow or Sunday when I pull a toilet.
